Your Aqara P1 motion sensor is not successfully paired to the C-8 hub. If you look at the device details Data section, you will see that it is missing the model and manufacturer data.
First, delete the device. Then, pair it again to the hub using this workaround. Most likely, you will need to pair the device a second time (without deleting it) so that the P1 sensor starts sending motion events.
