Hey - does anyone know if there is a specific driver for this lux sensor, or a generic one that will work? I've tried a bunch of the existing ones referenced on the site that support the 01LM but they don't work with this device.
Any ideas?
Any ideas?
GZCGQ11LM
lumi.sen_ill.agl01
@stephane did this newer model Aqara lux sensor work for you? Which driver did you use?
@iandogherty you can try also the Aqara P1 driver - make sure you have first installed it or updated it from this link, then obligatory pair it again to the HE hub. This driver should be automatically selected during the pairing process. Verify whether the Device Details Data section is filled in with the Model and Manufacturer data. Often, Aqara devices require several pairing attempts.
@kkossev that's worked partially i think. the details look right and it's recording an illuminance reading but it's 3 billion. can't be right?
Definitely not… Can you enable the Debug logs option and then copy and paste as a text whatever you see in the live logs when the illuminance changes?
Can you paste the debug logs as a text, please? The picture above includes 650 milliseconds period only ... I don't have this Aqara device model, so I will need to see the device responses from the time, when it was paired as a new device to HE, until the illuminance is changed few seconds later (just cover the sensor).
Please first delete the device from HE (click on the REMOVE DEVIC red button at the bottom of the web page), then pair it again.
It is working for me.
The driver i use is: Xiaomi Aqara Mijia Sensors And Switches. It's in the Hubitat Package Manager. I also enabled the option: Enable Presence Detection.
firmwareMT: 126E-2388-0000001B
manufacturer: XIAOMI
model: lumi.sen_ill.mgl01
softwareBuild: 0000001B
Sorry Stephane, it was my mistake - your sensor is different… it is the old Xiaomi (Mi) light sensor .
@iandogherty your light sensor Aqara lumi.sen_ill.agl01 is a newer model and at this time it is not supported by the Aqara P1 driver.
hey - understood re the newer model point but thougt i'd post the text logs anyway, just in case:
dev:17752023-04-22 10:11:46.493warnHouse Illuminance Sensor 01 ignored value 00 cluster 0001 attr 0020 for lumi.sen_ill.agl01
dev:17752023-04-22 10:11:46.491debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:6ECE0100010A20002000, dni:6ECE, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:00, clusterInt:1, attrInt:32]
dev:17752023-04-22 10:11:46.483infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:46.481tracehealthStatus online
dev:17752023-04-22 10:11:46.479debugHouse Illuminance Sensor 01 parse: description is read attr - raw: 6ECE0100010A20002000, dni: 6ECE, endpoint: 01, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: 00
dev:17752023-04-22 10:11:46.399infoHouse Illuminance Sensor 01 illuminance is 3576844 Lux
dev:17752023-04-22 10:11:46.391debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:6ECE0104000C000021FFFF, dni:6ECE, endpoint:01, cluster:0400, size:0C, attrId:0000, encoding:21, command:01, value:FFFF, clusterInt:1024, attrInt:0]
dev:17752023-04-22 10:11:46.384infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:46.382tracehealthStatus online
dev:17752023-04-22 10:11:46.380debugHouse Illuminance Sensor 01 parse: description is read attr - raw: 6ECE0104000C000021FFFF, dni: 6ECE, endpoint: 01, cluster: 0400, size: 0C, attrId: 0000, encoding: 21, command: 01, value: FFFF
dev:17752023-04-22 10:11:46.314debugHouse Illuminance Sensor 01 Received Configure Reporting Response for cluster:0001 , data=[00] (Status: Success)
dev:17752023-04-22 10:11:46.281debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0104 0001 01 01 0040 00 6ECE 00 00 0000 07 01 00, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:17752023-04-22 10:11:46.274infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:46.272tracehealthStatus online
dev:17752023-04-22 10:11:46.270debugHouse Illuminance Sensor 01 parse: description is catchall: 0104 0001 01 01 0040 00 6ECE 00 00 0000 07 01 00
dev:17752023-04-22 10:11:46.183infoHouse Illuminance Sensor 01 Received bind response, data=[10, 00] (Sequence Number:10, Status: Success)
dev:17752023-04-22 10:11:46.180debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 1000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[10, 00]]
dev:17752023-04-22 10:11:46.172infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:46.170tracehealthStatus online
dev:17752023-04-22 10:11:46.168debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 1000
dev:17752023-04-22 10:11:45.996debugHouse Illuminance Sensor 01 Received Configure Reporting Response for cluster:0400 , data=[00] (Status: Success)
dev:17752023-04-22 10:11:45.989debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0104 0400 01 01 0040 00 6ECE 00 00 0000 07 01 00, profileId:0104, clusterId:0400, clusterInt:1024, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:17752023-04-22 10:11:45.982infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:45.979tracehealthStatus online
dev:17752023-04-22 10:11:45.977debugHouse Illuminance Sensor 01 parse: description is catchall: 0104 0400 01 01 0040 00 6ECE 00 00 0000 07 01 00
dev:17752023-04-22 10:11:45.676infoHouse Illuminance Sensor 01 Received bind response, data=[0C, 00] (Sequence Number:0C, Status: Success)
dev:17752023-04-22 10:11:45.673debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 0C00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0C, 00]]
dev:17752023-04-22 10:11:45.666infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:45.663tracehealthStatus online
dev:17752023-04-22 10:11:45.661debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 0C00
dev:17752023-04-22 10:11:45.580infoHouse Illuminance Sensor 01 Received bind response, data=[0B, 00] (Sequence Number:0B, Status: Success)
dev:17752023-04-22 10:11:45.576debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 0B00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0B, 00]]
dev:17752023-04-22 10:11:45.567infoHouse Illuminance Sensor 01 is online
dev:17752023-04-22 10:11:45.564tracehealthStatus online
dev:17752023-04-22 10:11:45.558debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 0B00
dev:17752023-04-22 10:11:45.463infoHouse Illuminance Sensor 01 Received bind response, data=[0A, 00] (Sequence Number:0A, Status: Success)
dev:17752023-04-22 10:11:45.459debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 0A00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0A, 00]]
dev:17752023-04-22 10:11:45.457debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 6ECE 00 00 0000 00 00 0A00
dev:17752023-04-22 10:11:44.964debugHouse Illuminance Sensor 01 sending ZigbeeCommands : [zdo bind 6ECE 0x01 0x01 0x0400 {54EF44100065D51F} {}, delay 50, zdo bind 6ECE 0x01 0x01 0x0000 {54EF44100065D51F} {}, delay 50, zdo bind 6ECE 0x01 0x01 0x0001 {54EF44100065D51F} {}, delay 50, zdo bind 6ECE 0x01 0x01 0x0003 {54EF44100065D51F} {}, delay 50, zdo bind 0x6ECE 0x01 0x01 0x0400 {54EF44100065D51F} {}, delay 200, he cr 0x6ECE 0x01 1024 0 33 10 3600 {0500} {}, delay 200, zdo bind 0x6ECE 0x01 0x01 0x0001 {54EF44100065D51F} {}, delay 200, he cr 0x6ECE 0x01 1 32 32 3600 3600 {} {}, delay 200, he raw 0x6ECE 1 0x01 0x0400 {10 00 00 00 00}, delay 200, he raw 0x6ECE 1 0x01 0x0001 {10 00 00 20 00}, delay 200]
dev:17752023-04-22 10:11:44.954debugHouse Illuminance Sensor 01 Minimum Update Time: 10
dev:17752023-04-22 10:11:44.947infoHouse Illuminance Sensor 01 Received device announcement, data=[D3, CE, 6E, 1F, D5, 65, 00, 10, 44, EF, 54, 84] (Sequence Number:D3, Device network ID: 6ECE, Capability Information: 84)
dev:17752023-04-22 10:11:44.941debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 6ECE 00 00 0000 00 00 D3CE6E1FD565001044EF5484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6ECE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D3, CE, 6E, 1F, D5, 65, 00, 10, 44, EF, 54, 84]]
dev:17752023-04-22 10:11:44.937debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 0013 00 00 0040 00 6ECE 00 00 0000 00 00 D3CE6E1FD565001044EF5484
dev:17752023-04-22 10:11:44.755warnHouse Illuminance Sensor 01 if no more logs, please pair the device again to HE!
dev:17752023-04-22 10:11:44.709infoHouse Illuminance Sensor 01 device model lumi.sen_ill.agl01 manufacturer LUMI aqaraModel GZCGQ11LM deviceName was set to Aqara T1 light intensity sensor GZCGQ11LM
dev:17752023-04-22 10:11:44.692infoHouse Illuminance Sensor 01 InitializeVars... fullInit = true (driver version 1.4.1 2023/04/20 9:47 PM)
dev:17752023-04-22 10:11:44.676infoHouse Illuminance Sensor 01 configure...(driver version 1.4.1 2023/04/20 9:47 PM)
dev:17752023-04-22 10:09:22.251debugHouse Illuminance Sensor 01 sending ZigbeeCommands : [he raw 0xC41B 1 0x01 0x0400 {04 6E 12 00 00 00 00}, delay 200]
dev:17752023-04-22 10:08:52.221warnHouse Illuminance Sensor 01 if no more logs, please pair the device again to HE!
dev:17752023-04-22 10:08:52.173infoHouse Illuminance Sensor 01 device model lumi.sen_ill.agl01 manufacturer LUMI aqaraModel GZCGQ11LM deviceName was set to Aqara T1 light intensity sensor GZCGQ11LM
dev:17752023-04-22 10:08:52.144infoHouse Illuminance Sensor 01 InitializeVars... fullInit = true (driver version 1.4.1 2023/04/20 9:47 PM)
dev:17752023-04-22 10:08:52.129infoHouse Illuminance Sensor 01 configure...(driver version 1.4.1 2023/04/20 9:47 PM)
dev:17752023-04-22 09:17:40.245tracehealthStatus offline
dev:17752023-04-22 09:17:40.238debugHouse Illuminance Sensor 01 pollPresence()
dev:17752023-04-22 08:17:40.216tracehealthStatus offline
dev:17752023-04-22 08:17:40.208debugHouse Illuminance Sensor 01 pollPresence()
dev:17752023-04-22 07:17:40.186tracehealthStatus offline
dev:17752023-04-22 07:17:40.179debugHouse Illuminance Sensor 01 pollPresence()
dev:17752023-04-22 06:17:40.157tracehealthStatus offline
dev:17752023-04-22 06:17:40.150debugHouse Illuminance Sensor 01 pollPresence()
dev:17752023-04-22 05:17:40.124tracehealthStatus offline
dev:17752023-04-22 05:17:40.117debugHouse Illuminance Sensor 01 pollPresence()
dev:17752023-04-22 04:17:40.091tracehealthStatus offline
dev:17752023-04-22 04:17:40.083debugHouse Illuminance Sensor 01 pollPresence()
dev:17752023-04-22 03:17:40.056tracehealthStatus offline
dev:17752023-04-22 03:17:40.049debugHouse Illuminance Sensor 01 pollPresence()
and the device data
Thanks!
Yesterday I updated the driver version with some changes related to lumi.sen_ill.agl01 initialization sequence, that I was able to find in another HA system. The updated driver version is 1.4.1, time stamp "2023/04/21 9:54 PM". Can you try it?
First, update the driver - the quickest way is to locate the driver code in your HE Drivers Code page, then click on it, then click on the Import button on the top. Click on Save.
Next, pair the sensor again to HE. This is needed, because this is a 'deep sleep' type battery-powered device and the surest way to reconfigure it correctly is when it is paired again to HE.
If it still doesn't show the illuminance correctly, please copy the debug logs again, starting from the time when it was paired to HE.
that's great, thanks for your help. really appreciate it. have re-paired with the new driver but now i'm getting this:
dev:17752023-04-22 11:42:16.681warnHouse Illuminance Sensor 01 UNSUPPORTED/b> Read attribute response: cluster 0400 Attributte 0000 status code 86
dev:17752023-04-22 11:42:16.678debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0104 0400 01 01 0040 00 276E 00 01 115F 01 01 000086, profileId:0104, clusterId:0400, clusterInt:1024, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:276E, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:01, direction:01, data:[00, 00, 86]]
dev:17752023-04-22 11:42:16.674debugHouse Illuminance Sensor 01 parse: description is catchall: 0104 0400 01 01 0040 00 276E 00 01 115F 01 01 000086
dev:17752023-04-22 11:42:15.764debugHouse Illuminance Sensor 01 sending ZigbeeCommands : [he raw 0x276E 1 0x01 0x0400 {04 5F 11 00 00 00 00}, delay 200]
hi @kkossev did you manage to do any more investigation?
Hi @iandogherty , unfortunately, I didn't have the time to research further on GZCGQ11LM specific s. Hopefully I will have the chance to get back to this driver soon.
I will try to write more detailed instructions on how to provide the debug logs, that are very important for remote debugging , when the developer does not have exactly the same device.
This is needed because without having the debug logs from the start of the pairing process, the few log lines showing the final negative result are not very useful, as I can not see what went wrong before.
hi there, taken me ages to get back to this!
is this what you're looking for?
dev:17762023-05-09 10:29:50.067debugHouse Illuminance Sensor 02 sending ZigbeeCommands : [he raw 0xC121 1 0x01 0x0400 {04 5F 11 00 00 00 00}, delay 200]
dev:17762023-05-09 10:29:20.844warnHouse Illuminance Sensor 02 UNSUPPORTED/b> Read attribute response: cluster FCC0 Attributte 0102 status code 86
dev:17762023-05-09 10:29:20.841debugHouse Illuminance Sensor 02 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 C121 00 01 115F 01 01 020186, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C121, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:01, direction:01, data:[02, 01, 86]]
dev:17762023-05-09 10:29:20.833infoHouse Illuminance Sensor 02 is online
dev:17762023-05-09 10:29:20.830tracehealthStatus online
dev:17762023-05-09 10:29:20.828debugHouse Illuminance Sensor 02 parse: description is catchall: 0104 FCC0 01 01 0040 00 C121 00 01 115F 01 01 020186
dev:17762023-05-09 10:29:20.707debugHouse Illuminance Sensor 02 Unprocessed FCC0 attribute report: cluster=0xFCC0 attrId=0x0000 value=0x0005 status=null data=null
dev:17762023-05-09 10:29:20.676debugHouse Illuminance Sensor 02 parse: Desc Map: [raw:C12101FCC00C0000210500, dni:C121, endpoint:01, cluster:FCC0, size:0C, attrId:0000, encoding:21, command:01, value:0005, clusterInt:64704, attrInt:0]
dev:17762023-05-09 10:29:20.664infoHouse Illuminance Sensor 02 is online
dev:17762023-05-09 10:29:20.661tracehealthStatus online
dev:17762023-05-09 10:29:20.655debugHouse Illuminance Sensor 02 parse: description is read attr - raw: C12101FCC00C0000210500, dni: C121, endpoint: 01, cluster: FCC0, size: 0C, attrId: 0000, encoding: 21, command: 01, value: 0500
dev:17762023-05-09 10:29:20.648debugHouse Illuminance Sensor 02 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:17762023-05-09 10:29:20.639debugHouse Illuminance Sensor 02 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 C121 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C121, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:17762023-05-09 10:29:20.635debugHouse Illuminance Sensor 02 parse: description is catchall: 0104 FCC0 01 01 0040 00 C121 00 01 115F 04 01 00
dev:17762023-05-09 10:29:20.161debugHouse Illuminance Sensor 02 sending ZigbeeCommands : [he wattr 0xC121 0x01 0xFCC0 0x0009 0x20 {01} {115F}, delay 50, he raw 0xC121 1 0x01 0xFCC0 {04 5F 11 00 00 00 00}, delay 200, he raw 0xC121 1 0x01 0xFCC0 {04 5F 11 00 00 02 01}, delay 200]
dev:17762023-05-09 10:29:20.132infoHouse Illuminance Sensor 02 Received device announcement, data=[D3, 21, C1, 85, CF, 65, 00, 10, 44, EF, 54, 84] (Sequence Number:D3, Device network ID: C121, Capability Information: 84)
dev:17762023-05-09 10:29:20.127debugHouse Illuminance Sensor 02 parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 C121 00 00 0000 00 00 D321C185CF65001044EF5484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C121, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D3, 21, C1, 85, CF, 65, 00, 10, 44, EF, 54, 84]]
dev:17762023-05-09 10:29:20.120debugHouse Illuminance Sensor 02 parse: description is catchall: 0000 0013 00 00 0040 00 C121 00 00 0000 00 00 D321C185CF65001044EF5484
dev:17762023-05-09 10:29:20.043warnHouse Illuminance Sensor 02 if no more logs, please pair the device again to HE!
dev:17762023-05-09 10:29:19.961infoHouse Illuminance Sensor 02 device model lumi.sen_ill.agl01 manufacturer LUMI aqaraModel GZCGQ11LM deviceName was set to Aqara T1 light intensity sensor GZCGQ11LM
dev:17762023-05-09 10:29:19.924infoHouse Illuminance Sensor 02 InitializeVars... fullInit = true (driver version 1.4.1 2023/04/21 9:54 PM)
dev:17762023-05-09 10:29:19.908infoHouse Illuminance Sensor 02 configur
hey, @kkossev just tagging you in case you missed this, or need more info!
Hi Ian, no I have not forgotten, will come back to this during the weekend again. Thank you for the logs!
Can you try the dev.branch version 1.4.2 ?
You need to pair the Light Sensor again to your hub. Don't remove it, just pair it again. If it doesn't work, send me the debug logs again, starting from the time of the new pairing and ending 3-4 minutes later.
hi @kkossev , looks like still not working. here are the logs for you.
dev:17752023-05-15 09:41:38.898debugHouse Illuminance Sensor 01 sending ZigbeeCommands : [he raw 0x0682 1 0x01 0x0400 {04 5F 11 00 00 00 00}, delay 200, he raw 0x0682 1 0x01 0x0400 {04 6E 12 00 00 00 00}, delay 200]
dev:17752023-05-15 09:41:08.868warnHouse Illuminance Sensor 01 if no more logs, please pair the device again to HE!
dev:17752023-05-15 09:41:08.823infoHouse Illuminance Sensor 01 device model lumi.sen_ill.agl01 manufacturer LUMI aqaraModel GZCGQ11LM deviceName was set to Aqara T1 light intensity sensor GZCGQ11LM
dev:17752023-05-15 09:41:08.808infoHouse Illuminance Sensor 01 InitializeVars... fullInit = true (driver version 1.4.2 2023/05/14 6:06 PM)
dev:17752023-05-15 09:41:08.795infoHouse Illuminance Sensor 01 configure...(driver version 1.4.2 2023/05/14 6:06 PM)
dev:17752023-05-15 09:39:55.377debugHouse Illuminance Sensor 01 sending ZigbeeCommands : [he raw 0x0682 1 0x01 0x0400 {04 5F 11 00 00 00 00}, delay 200, he raw 0x0682 1 0x01 0x0400 {04 6E 12 00 00 00 00}, delay 200]
dev:17752023-05-15 09:39:27.003warnHouse Illuminance Sensor 01 ignored value 00 cluster 0001 attr 0020 for lumi.sen_ill.agl01
dev:17752023-05-15 09:39:27.001debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:06820100010A20002000, dni:0682, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:00, clusterInt:1, attrInt:32]
dev:17752023-05-15 09:39:26.995infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.992tracehealthStatus online
dev:17752023-05-15 09:39:26.989debugHouse Illuminance Sensor 01 parse: description is read attr - raw: 06820100010A20002000, dni: 0682, endpoint: 01, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: 00
dev:17752023-05-15 09:39:26.917infoHouse Illuminance Sensor 01 illuminance is 3576844 Lux
dev:17752023-05-15 09:39:26.912debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:06820104000C000021FFFF, dni:0682, endpoint:01, cluster:0400, size:0C, attrId:0000, encoding:21, command:01, value:FFFF, clusterInt:1024, attrInt:0]
dev:17752023-05-15 09:39:26.905infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.902tracehealthStatus online
dev:17752023-05-15 09:39:26.900debugHouse Illuminance Sensor 01 parse: description is read attr - raw: 06820104000C000021FFFF, dni: 0682, endpoint: 01, cluster: 0400, size: 0C, attrId: 0000, encoding: 21, command: 01, value: FFFF
dev:17752023-05-15 09:39:26.798debugHouse Illuminance Sensor 01 Received Configure Reporting Response for cluster:0001 , data=[00] (Status: Success)
dev:17752023-05-15 09:39:26.795debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0104 0001 01 01 0040 00 0682 00 00 0000 07 01 00, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:17752023-05-15 09:39:26.787infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.785tracehealthStatus online
dev:17752023-05-15 09:39:26.782debugHouse Illuminance Sensor 01 parse: description is catchall: 0104 0001 01 01 0040 00 0682 00 00 0000 07 01 00
dev:17752023-05-15 09:39:26.688infoHouse Illuminance Sensor 01 Received bind response, data=[5A, 00] (Sequence Number:5A, Status: Success)
dev:17752023-05-15 09:39:26.686debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5A00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[5A, 00]]
dev:17752023-05-15 09:39:26.678infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.676tracehealthStatus online
dev:17752023-05-15 09:39:26.673debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5A00
dev:17752023-05-15 09:39:26.498debugHouse Illuminance Sensor 01 Received Configure Reporting Response for cluster:0400 , data=[00] (Status: Success)
dev:17752023-05-15 09:39:26.493debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0104 0400 01 01 0040 00 0682 00 00 0000 07 01 00, profileId:0104, clusterId:0400, clusterInt:1024, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:17752023-05-15 09:39:26.485infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.483tracehealthStatus online
dev:17752023-05-15 09:39:26.480debugHouse Illuminance Sensor 01 parse: description is catchall: 0104 0400 01 01 0040 00 0682 00 00 0000 07 01 00
dev:17752023-05-15 09:39:26.336infoHouse Illuminance Sensor 01 Received bind response, data=[56, 00] (Sequence Number:56, Status: Success)
dev:17752023-05-15 09:39:26.333debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[56, 00]]
dev:17752023-05-15 09:39:26.325infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.320tracehealthStatus online
dev:17752023-05-15 09:39:26.318debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5600
dev:17752023-05-15 09:39:26.298infoHouse Illuminance Sensor 01 Received bind response, data=[57, 00] (Sequence Number:57, Status: Success)
dev:17752023-05-15 09:39:26.295debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5700, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[57, 00]]
dev:17752023-05-15 09:39:26.288infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.285tracehealthStatus online
dev:17752023-05-15 09:39:26.283debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5700
dev:17752023-05-15 09:39:26.172infoHouse Illuminance Sensor 01 Received bind response, data=[55, 00] (Sequence Number:55, Status: Success)
dev:17752023-05-15 09:39:26.169debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[55, 00]]
dev:17752023-05-15 09:39:26.161infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.158tracehealthStatus online
dev:17752023-05-15 09:39:26.156debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5500
dev:17752023-05-15 09:39:26.069infoHouse Illuminance Sensor 01 Received bind response, data=[54, 00] (Sequence Number:54, Status: Success)
dev:17752023-05-15 09:39:26.066debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[54, 00]]
dev:17752023-05-15 09:39:26.057infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:26.055tracehealthStatus online
dev:17752023-05-15 09:39:26.052debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 8021 00 00 0040 00 0682 00 00 0000 00 00 5400
dev:17752023-05-15 09:39:25.910debugHouse Illuminance Sensor 01 Unprocessed FCC0 attribute report: cluster=0xFCC0 attrId=0x0000 value=0x0005 status=null data=null
dev:17752023-05-15 09:39:25.890debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:068201FCC00C0000210500, dni:0682, endpoint:01, cluster:FCC0, size:0C, attrId:0000, encoding:21, command:01, value:0005, clusterInt:64704, attrInt:0]
dev:17752023-05-15 09:39:25.882infoHouse Illuminance Sensor 01 is online
dev:17752023-05-15 09:39:25.879tracehealthStatus online
dev:17752023-05-15 09:39:25.874debugHouse Illuminance Sensor 01 parse: description is read attr - raw: 068201FCC00C0000210500, dni: 0682, endpoint: 01, cluster: FCC0, size: 0C, attrId: 0000, encoding: 21, command: 01, value: 0500
dev:17752023-05-15 09:39:25.865debugHouse Illuminance Sensor 01 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:17752023-05-15 09:39:25.859debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 0682 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:17752023-05-15 09:39:25.855debugHouse Illuminance Sensor 01 parse: description is catchall: 0104 FCC0 01 01 0040 00 0682 00 01 115F 04 01 00
dev:17752023-05-15 09:39:25.411debugHouse Illuminance Sensor 01 sending ZigbeeCommands : [he wattr 0x0682 0x01 0xFCC0 0x0009 0x20 {01} {115F}, delay 50, he raw 0x0682 1 0x01 0xFCC0 {04 5F 11 00 00 00 00}, delay 200, zdo bind 0682 0x01 0x01 0x0400 {54EF44100065D51F} {}, delay 50, zdo bind 0682 0x01 0x01 0x0000 {54EF44100065D51F} {}, delay 50, zdo bind 0682 0x01 0x01 0x0001 {54EF44100065D51F} {}, delay 50, zdo bind 0682 0x01 0x01 0x0003 {54EF44100065D51F} {}, delay 50, zdo bind 0x0682 0x01 0x01 0x0400 {54EF44100065D51F} {}, delay 200, he cr 0x0682 0x01 1024 0 33 10 3600 {0500} {}, delay 200, zdo bind 0x0682 0x01 0x01 0x0001 {54EF44100065D51F} {}, delay 200, he cr 0x0682 0x01 1 32 32 3600 3600 {} {}, delay 200, he raw 0x0682 1 0x01 0x0400 {10 00 00 00 00}, delay 200, he raw 0x0682 1 0x01 0x0001 {10 00 00 20 00}, delay 200]
dev:17752023-05-15 09:39:25.378debugHouse Illuminance Sensor 01 Minimum Update Time: 10
dev:17752023-05-15 09:39:25.363infoHouse Illuminance Sensor 01 Received device announcement, data=[D3, 82, 06, 1F, D5, 65, 00, 10, 44, EF, 54, 84] (Sequence Number:D3, Device network ID: 0682, Capability Information: 84)
dev:17752023-05-15 09:39:25.357debugHouse Illuminance Sensor 01 parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 0682 00 00 0000 00 00 D382061FD565001044EF5484, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0682, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D3, 82, 06, 1F, D5, 65, 00, 10, 44, EF, 54, 84]]
dev:17752023-05-15 09:39:25.351debugHouse Illuminance Sensor 01 parse: description is catchall: 0000 0013 00 00 0040 00 0682 00 00 0000 00 00 D382061FD565001044EF5484
dev:17752023-05-15 09:39:25.279warnHouse Illuminance Sensor 01 if no more logs, please pair the device again to HE!
dev:17752023-05-15 09:39:25.222infoHouse Illuminance Sensor 01 device model lumi.sen_ill.agl01 manufacturer LUMI aqaraModel GZCGQ11LM deviceName was set to Aqara T1 light intensity sensor GZCGQ11LM
dev:17752023-05-15 09:39:25.191infoHouse Illuminance Sensor 01 InitializeVars... fullInit = true (driver version 1.4.2 2023/05/14 6:06 PM)
dev:17752023-05-15 09:39:25.169infoHouse Illuminance Sensor 01 configure...(driver version 1.4.2 2023/05/14 6:06 PM)
It works for me
dev:25942023-05-15 20:56:13.297infoLiving Light Sensor illuminance is 266 Lux
dev:25942023-05-15 20:56:13.293debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A000021B95E, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:5EB9, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:56:13.281tracehealthStatus online
dev:25942023-05-15 20:56:13.278debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A000021B95E, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: B95E
dev:25942023-05-15 20:56:08.337infoLiving Light Sensor illuminance is 2306 Lux
dev:25942023-05-15 20:56:08.334debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A0000215D83, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:835D, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:56:08.320tracehealthStatus online
dev:25942023-05-15 20:56:08.317debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A0000215D83, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 5D83
dev:25942023-05-15 20:56:08.307infoLiving Light Sensor illuminance is 2306 Lux
dev:25942023-05-15 20:56:08.304debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A0000215D83, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:835D, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:56:08.292tracehealthStatus online
dev:25942023-05-15 20:56:08.289debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A0000215D83, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 5D83
dev:25942023-05-15 20:56:03.321infoLiving Light Sensor illuminance is 5393 Lux
dev:25942023-05-15 20:56:03.318debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A000021C691, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:91C6, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:56:03.307tracehealthStatus online
dev:25942023-05-15 20:56:03.304debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A000021C691, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: C691
dev:25942023-05-15 20:55:58.370infoLiving Light Sensor illuminance is 6362 Lux
dev:25942023-05-15 20:55:58.365debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A0000219494, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:9494, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:55:58.348tracehealthStatus online
dev:25942023-05-15 20:55:58.345debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A0000219494, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 9494
dev:25942023-05-15 20:55:58.336infoLiving Light Sensor illuminance is 6362 Lux
dev:25942023-05-15 20:55:58.332debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A0000219494, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:9494, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:55:58.319tracehealthStatus online
dev:25942023-05-15 20:55:58.316debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A0000219494, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 9494
dev:25942023-05-15 20:55:48.367infoLiving Light Sensor illuminance is 85 Lux
dev:25942023-05-15 20:55:48.364debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A0000215F4B, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:4B5F, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:55:48.352tracehealthStatus online
dev:25942023-05-15 20:55:48.349debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A0000215F4B, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 5F4B
dev:25942023-05-15 20:55:38.496infoLiving Light Sensor illuminance is 86 Lux
dev:25942023-05-15 20:55:38.482debugLiving Light Sensor parse: Desc Map: [raw:090B0104000A000021914B, dni:090B, endpoint:01, cluster:0400, size:0A, attrId:0000, encoding:21, command:0A, value:4B91, clusterInt:1024, attrInt:0]
dev:25942023-05-15 20:55:38.478tracehealthStatus online
dev:25942023-05-15 20:55:38.473debugLiving Light Sensor parse: description is read attr - raw: 090B0104000A000021914B, dni: 090B, endpoint: 01, cluster: 0400, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 914B
