There is, but it’s a Cloud API, not local.
We have to wait for Matter.
@mike.maxwell @gopher.ny can you consider adding such an inbuilt virtual driver in the next system platform update, please?
Not for me to decide, but I can see how this might be very confusing to new users that don’t understand what this would be used for. Anyway, the code is really simple. You can just change the capability to make any sensor you need also have a switch capability.
Only Hubitat built-in virtual drivers are permitted to be used with Hubitat’s HomeKit integration. Thus the request for a built-in driver.
yeah, we can do that
So I have had this installed for a while now, works really well (I was a little hesitant due to some not having a lot of luck with it).
I have a hallway that is 'L' shaped leading to my front door and my home cinema setup with stairs also off this hall. Now, when I answer the door and stand there for a bit the light stays on at the front door but the others in the hall go off after 1 minute, also when my cinema/projector is on the lights come on to 5% and only the ones in the hall zone (hall is split into 3 zones) they are passing through (used to bug me when someone walked past the end of the hall and the lights all came on and too bright, probably could have got around this with multiple motion sensors and blocked part of their vision to make the zone they could see very small).
Anyway, speed using virtual switches in Alexa to trigger rules in Hubitat is good and no complaints from me, will get some more
I have four of them with similar results. I've got them MOSTLY working by crippling TF out of the available zones to eliminate ghosts. The auto scan feature doesn't seem to do anything.
Edit: I just wanted to say that these work MUCH better than the Tuya ones. The EP1 and the FP1 seem like the most accurate so far. The Tuyas might work better if I could manipulate the settings a bit better. I can't see any tangible change when I tweak them in the driver. Way too sensitive and lights stay on all night.
The latest firmware for the FP2 is much better than before, BUT my bathroom lights still crank to 100% several times a night. I'm sure my bedroom would too if it weren't for my sleep sensors. My dream would be to put FP2s in every room to eliminate the need for pretty much anything else. No bed sensors, no IR motion... would be amazing. We aren't even close that reality though.
Have you played around with the sensitivity setting and/or the different options for how to report on presence in a zone? I haven't tried myself, was just curious if that helped at all.
Sure have. The main issue with the FP2.is ghosting. I'm not even talking about areas with fans. It's just not very reliable yet. If you actually used one of these for an alarm you'd be very sorry.
That's where I was wondering if the sensitivity could help, but if you've tried it and it doesn't help, that's a shame. Hopefully they will keep working on fixes in upcoming firmware updates.
While I've never been too concerned about a full-blown security system, even if I was, I don't think I would be using commercial home automation tech to achieve it, at least not at the moment. Notifications or warnings maybe, but not something more than that.
Security systems are BS anyways. Nothing but security theater. I just don't want the alarm to cry wolf.
is the Tuya integrated correctly by hubitat and fully works? I'm looking for a presence sensor instead of traditional motion sensor, and this tuya looks like the best option, Thanks
Wait one more week, I am expecting to receive a new Tuya 24GHz radar, which I should be able to compare to the older models.
I'd like to use a presence sensor instead the actual motion sensor I have, and I was looking for this Tuya. Is it is fully integrated in Hubitat, working 100%? Or is it a compromise like this Aqara FP2?
ohhh nice What model are you referring? Is there a new one of Tuya ZY-M100 ?
This one : https://www.aliexpress.com/item/1005005761971083.html
There are interesting screenshots of the Tuya SmarLife app configuration options that are not available on ZY-M100, but let's see how it will perform.
One of the issues with Tuya mmWave radars compared to Aqara FP2 is that it is difficult to see the effect of the different configurations (sensitivity, detection distances, etc...). This new model promises such test functionalities.
Looks good! Since I have no hurry, I will wait for your useful feedback
But I don't understand, both ZY-M100 and this new version, are fully compatible and integrable to Hubitat without any special competence?
Hubitat inbuilt drivers are comparable only with these Tuya devices, that follow strictly the Zigbee Clusters Library specifications.
The mmWave occupancy sensors are complex and non-standard devices, so these are handled by community written custom drivers.
Every Chinese device usual has color LEDs, a lot of these will also play music, but this one has a loud alarm!
