I've had a number of the "Aqara Wireless Switch Smart Remote One Key" devices and each one I added would work for maybe an hour then stop working I'd then reset the button and repair it and it would usually work fine from then on. The issue is these devices are fully Zigbee compliant so they don't work as well as other brands that are (although they are a lot cheaper, or can be depending on where you get them).
