iOS 14.4 with the latest HE app ver 1.1.1 (Feb build). Was hoping the latest mobile app advanced motion and network settings would make this work. But it doesn't work at all by itself. I can get it to send presence to the hub sometimes if I go into the app and open the Geofence map which kinda kick starts it to send to the hub. Its like it goes to sleep forever.
I have the app open in the background and phone Location services set to "While Using", also tried "Always".
Under settings, advanced, turn on validate location on network change and high accuracy presence
High accuracy presence seemed o help a lot. What exactly does it do differently? The HE app is now 55% of my battery usage running in background which is concerning. I noticed with that setting on I have the blue oval location Icon permanently on in the top right of my phone which links to the HE app.
Yeah high accuracy keeps it running in the background and it is very battery heavy
Yeah, will see so how it goes but probably not gonna like it running constantly.
Two things would make this better if its possible:
- Another option, check location and send in selective intervals; 5min, 15min, 30min.. So its not constantly running the GPS or whatever its doing.
- Another option maybe on the HE "Mobil App driver" side, If you don't hear from the app geofence in a certain amount of time (5, 15, 30min..) them declare Not Present. So if I accidently close my app and away it will show not present.
It seems that this problem with geofencing is not solved yet.
It would be very important to a use case that I’m working with.
Is there other alternative?
life 360 perhaps
I’ll check it out
Thanks!!
integration built into HE
Life 360. I would also suggest some kind of wifi sensor ,many use IPhone wifi presence sensor
I would also suggest a presence Monitor that looks at multiple presence devices. I use Presence monitor in conjunction with the mobile app, Life 360 and Improved Mobile Presence - Android (the first link is a similar app for iOS) with this combination I'm getting about 98% accuracy (or better).
