@pavr27 Thanks for the picture, which promoted me to open my 2nd unit to find that it's almost identical to yours. I brought two units from two separate eBay listings, and both claimed to be Tuya controllers, but only to learn that they are different.
Here is mine:
Since you are already on 2.2.5.123, wondering if you want to try 2.2.5.124 that was recently released. Version .124 comes with Advanced Zigbee Xyz drivers according to the changelog. I haven't upgraded to 2.2.5, so I don't know if there are any issues with the latest firmware.
That seems to be contradicting to what you said earlier:
BTW, the latest version of firmware 2.2.5.124 seems to have a new Advanced Zigbee series driver, not sure if you have tried. Disclaimer: I'm still on 2.2.4.x.
Updated to 2.2.5.126 now. Sadly, the device still doesn't work.
I don't really understand the logs....but it appears that HE cannot see a manufacture/model number... (but Smartthings can).
Anyway, I have access to it on smarttthings via hubconnect...so I'll patiently await any future driver updates, with the understanding that perhaps I'll never have it working directly on HE!
Same experience here - the new Advanced Zigbee drivers didn’t help. For now, I am using these strips where brightness from white LEDs is not critical. Not ideal, but the physical button on the controller can still be used to switch from RGB to white LEDs, after which HE can adjust the brightness.
Thanks to @Kenneth I learned more about RGBW configurations so next time I will order a 6-pin controller.
Could some of you please explain how did you connect it to Hue Bridge? I tried with Hue Essentials etc but it didn’t seem to discover any devices. I have the 3-pin version.
I really like these - have 8 of these - plus a couple which I cannot comunicate with any longer.... following me disconnecting them from the power when they were still on. I have the 4 pin version. Does anyone know how to Factory Reset them?
I just received one of them, connected to the first one with he, what I had before with a Wi-Fi controller, and the colors have nothing to do with it, white is not white, it's yellow, and with the other one from smartlife it was white, Does anyone know if it can be solved, or do I have to order a white zigbee controller and a white led strip?
This is a combination of controller and strip. Kelvin colors range from yellow (lets say 1200k to soft white (2700k) to more stark daylight (4000) to starting to get into blue (5000k and above) So you need to adjust capable lighting correctly.
brother if I tell you what happened to me, one of the cables was broken, that's why it failed me when I made the white light, and yes, my strip is rgb, it makes an attempt at bluish white, but it already works for me, thanks for helping me
