Anyone else see value in adding switches as a trigger in HSM?
Thinking about notification of someone flipping a switch that shouldn't be flipped either:
a) because NO one is on premise and that switch wouldn't be switched unless somebody was (think of it like a feature that someone could cause an HSM alarm unbeknownst to them)
b) because a particular switch is for something that should not be switched by anyone unauthorized and those that are should know if & when it is
or maybe...
c) because a VIRTUAL switch has been created to be flipped by some other App and you want HSM to react to that
I'm sure others could come up with justifications for switches being a trigger in HSM if you happen to use HSM.
