Hi All,
I bought a power strip on Amazon
endpointId: 01
application: 64
manufacturer: _TZ3000_cfnprab5
model: TS011F
I have tried everything on this forum to get it working. Hubitat finds the device but I cannot control it, have tried all drivers to no avail.
My question is, is there a power strip like this that is easy to set up and actually works with hubitat?
Thanks,
Phil
I have a Zooz power strip it is compatible and works great for me.
In fact on the device compatibility page for HE it is the only listed power strip that is.
Check out this post, there is some mention of the exact same mfg and model in there. @kkossev is the Tuya Zigbee wizard so pay extra attention to those posts. The person who posted with the same info as yours got it working following the suggestions.
I purchased a Xenon 4-gang + 2 USB extension (zigbee version), and attached to my hubitat device.
Initially identified, as DEVICE - but I updated to "Generic Zigbee Multi-Endpoint Switch driver", and hit config, which created the child endpoint devices.
However, when I select option to turn-off, just a single endpoint socket - it will switch of all endpoint sockets and the complete extension lead.
Have disconnected & reconnected to power, but still get the same issue.
Switched to DEVICE, andβ¦
kkossev
November 27, 2022, 2:38pm
5
PhilScolari:
_TZ3000_cfnprab5
This device behaves very erratically, I don't have a 100% working solution yet.
system
Closed
November 27, 2023, 2:39pm
6
