Still doesn't work, but I get an error now! Here's what I've got:
dev:24962021-07-12 08:53:58.113 am debugrefresh: createChildACUnits() method skipped, we are working with the Kumo Cloud platform
dev:24962021-07-12 08:53:58.110 am infoA new authentication code value has been set
dev:24962021-07-12 08:53:58.098 am debugsetAuthCode: New authentication code value has been set
dev:24962021-07-12 08:53:58.094 am errorretrieveAuthCode_KumoCloud: Unable to query Mitsubishi Electric KumoCloud: java.lang.NullPointerException: Cannot get property 'zoneTable' on null object
dev:24962021-07-12 08:53:58.078 am debugretrieveAuthCode_KumoCloud: Child - [lastScheduleChange:0, zoneTable:[:], children:[[lastScheduleChange:0, zoneTable:[9X34P0088100106F:[serial:9X34P0088100106F, mac:d4:53:83:46:4f:97, label:Living Room, port:80, unitType:ductless, lastUpdate:1626057784202, eqcStageThreeBacksupChannels:[1:0, 2:0, 3:0, 4:0], eqcUpdatedLocally:[1:false, 2:false, 3:false, 4:false], prohibits:[global:[power:false, mode:false, setpoint:false], local:[power:false, mode:false, setpoint:false], effective:[power:false, mode:false, setpoint:false]], prohibitsChanged:1593382188689, holdChanged:0, hasElectricHeatingOption:false, ledDisabled:true, cryptoSerial:0123835fad3eb5b1ee, cryptoKeySet:F, timezone:America/Denver, firmwareVersion:02.06.03, autoModeEnabled:false, roomTempOffset:-3, password:wGa148lurWJtzlbK+ihddpPfOvdd1M6rw0ke4gei, sendDesiredConditionsPending:false, sendDesiredConditionsTime:2021-07-10T04:09:46.417Z, systemChangeoverEnabled:true, minCoolSetpoint:15.5, maxHeatSetpoint:28, kumoSensorSettings:null, address:10.54.25.225, $$hashKey:object:405, desiredConditionStack:[], reportedCondition:[more:[:], _created:1626057784202], overrideSettings:[:], forceCloudUpdates:false, errorHandler:[1:[error2char:A0, error4char:8000, timestamp:1625306576, code:8000, text:8000]], rssi:[:], reportedInitialSettings:[assigned_settings:[:], restart_after_outage:0, vent_air:0, voltage:0, energy_save:0, filter_alerts:0, auto_fan:0, pla_outlets:0, filter_type:0, frost_temp:0, defrost:0, oscillate:0, heating_offset:0, thermal_off1:0, thermal_off2:0, pressure1:0, pressure2:0, electric_heater1:0, electric_heater2:0, humidifier:0, humidifier_modifier:0, leftovers_settings:[2:0, 6:0, 12:0, 14:0, 18:0, 19:0, 20:0, 21:0, 22:0, 26:0, 28:0, 29:0, 30:0, 31:0]], reportedProfile:[fan_speed_stages:5, has_air_direction:true, has_auto_fan_speed:true, has_dry_function:true, has_extended_temp_range:true, has_heat_function:true, has_swing_direction:true, has_test_run:false, has_unit_function_setting:false, has_ventilation_function:true, display_setting_temp_of_dry:true, maximum_auto_temp:28, maximum_cool_or_dry_temp:28, maximum_heat_temp:28, minimum_auto_temp:13, minimum_cool_or_dry_temp:13, minimum_heat_temp:7], equipmentControllerSettings:[:], lastAdapterUpdate:2021-05-17 22:21:27.609563, systemChangeoverSettings:[masterZone:[serial:9934P008T100003F, minRuntime:20, maxStandby:180, disable:none, activeMode:null, durActive:null, durInactive:null], priority:1], mhk2Settings:[auto:[owner:none, status:inactive, heatSetpoint:null, coolSetpoint:null], connected:[thermostat:false, thermostatBattery:unset, outdoorAir:false, outdoorAirBattery:unset, indoorAir:false, indoorAirBattery:unset], dr:[override:false, event:none], hold:[adapter:[cancelMHK2:false, endTime:0], mhk2:[cancelAdapter:false, endTime:0]], info:[model:, serial:, firmware:], schedule:[owner:adapter, enabled:disabled], status:[outdoorTemp:0, outdoorHumid:null, indoorHumid:null]], programEventSettings:[1:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:0600, settings:[mode:heat, spCool:null, spHeat:20, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 2:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:2200, settings:[mode:heat, spCool:null, spHeat:17.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 3:[active:false, inUse:false, day:MoTuWeThFr, time:1215, settings:[mode:off, spCool:null, spHeat:null, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 4:[active:false, inUse:false, day:MoTuWeThFr, time:1115, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 5:[active:false, inUse:false, day:MoTuWeThFr, time:1615, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 6:[active:false, inUse:false, day:MoTuWeThFr, time:2100, settings:[mode:heat, spCool:null, spHeat:20, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 7:[active:false, inUse:false, day:SuSa, time:0800, settings:[mode:heat, spCool:null, spHeat:21.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 8:[active:false, inUse:false, day:SuSa, time:2100, settings:[mode:heat, spCool:null, spHeat:19.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 9:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 10:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 11:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 12:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 13:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.790Z], 14:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.790Z], 15:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 16:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 17:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 18:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 19:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 20:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 21:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 22:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 23:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 24:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 25:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 26:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.308Z], 27:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.308Z], 28:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.308Z]], _requestRescan:0, _isRespondingLocally:null, acoilSettings:[isAcoil:false, inputs:[humidistat:false, ervSwitch:false, floatSwitchWet:false], outputs:[w1:false, w2:false, y:false, g:false, erv:false, humidifer:false, heartbeat:false], humidifier:[targetPcr:0, source:null, enable:false], erv:[mode:classic], ytoo:[fan:false, humidifier:false, erv:false], cbp:0, oat:0, bpcr:off, ebp:false, fDelay:0], autoChangeoverEnabled:false, optimalStart:false], 9934P008T100003F:[serial:9934P008T100003F, mac:d4:53:83:2b:7f:9b, label:Bedroom, port:80, unitType:ductless, reportedCondition:[more:[:], _created:1626057784205], desiredConditionStack:[], lastUpdate:1626057784205, overrideSettings:[:], forceCloudUpdates:false, errorHandler:[1:[error2char:A0, error4char:8000, timestamp:1625890076, code:8000, text:8000]], equipmentControllerSettings:[:], eqcStageThreeBacksupChannels:[1:0, 2:0, 3:0, 4:0], eqcUpdatedLocally:[1:false, 2:false, 3:false, 4:false], mhk2Settings:[auto:[owner:none, status:inactive, heatSetpoint:null, coolSetpoint:null], connected:[thermostat:false, thermostatBattery:unset, outdoorAir:false, outdoorAirBattery:unset, indoorAir:false, indoorAirBattery:unset], dr:[override:false, event:none], hold:[adapter:[cancelMHK2:false, endTime:0], mhk2:[cancelAdapter:false, endTime:0]], info:[model:, serial:, firmware:], schedule:[owner:adapter, enabled:disabled], status:[outdoorTemp:0, outdoorHumid:null, indoorHumid:null]], systemChangeoverSettings:[masterZone:[serial:9934P008T100003F, minRuntime:20, maxStandby:180, disable:none, activeMode:null, durActive:null, durInactive:null], priority:1], programEventSettings:[1:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:0600, settings:[mode:heat, spCool:null, spHeat:20, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.222Z], 2:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:2200, settings:[mode:heat, spCool:null, spHeat:17.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.222Z], 3:[active:false, inUse:false, day:MoTuWeThFr, time:0600, settings:[mode:heat, spCool:null, spHeat:21.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 4:[active:false, inUse:false, day:MoTuWeThFr, time:0745, settings:[mode:off, spCool:null, spHeat:null, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 5:[active:false, inUse:false, day:MoTuWeThFr, time:1215, settings:[mode:off, spCool:null, spHeat:null, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 6:[active:false, inUse:false, day:MoTuWeThFr, time:1615, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 7:[active:false, inUse:false, day:MoTuWeThFr, time:1115, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 8:[active:false, inUse:false, day:MoTuWeThFr, time:2100, settings:[mode:heat, spCool:null, spHeat:19.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 9:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 10:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 11:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 12:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 13:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 14:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.863Z], 15:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 16:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 17:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 18:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 19:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 20:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 21:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 22:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 23:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 24:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 25:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 26:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 27:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 28:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z]], prohibits:[global:[power:false, mode:false, setpoint:false], local:[power:false, mode:false, setpoint:false], effective:[power:false, mode:false, setpoint:false]], prohibitsChanged:1593832606056, holdChanged:0, hasElectricHeatingOption:false, rssi:[:], ledDisabled:true, password:VGZDI/8r9tZTJxv69jWGURLMbHu6XdJ+mXIBo1+g, cryptoSerial:0123ea6714c0febfee, cryptoKeySet:F, lastAdapterUpdate:2021-07-03 20:22:23.107836, firmwareVersion:02.06.03, autoModeEnabled:false, roomTempOffset:-2, minCoolSetpoint:16.5, maxHeatSetpoint:29, timezone:America/Denver, kumoSensorSettings:null, address:10.54.25.242, reportedInitialSettings:[assigned_settings:[:], restart_after_outage:0, vent_air:0, voltage:0, energy_save:0, filter_alerts:0, auto_fan:0, pla_outlets:0, filter_type:0, frost_temp:0, defrost:0, oscillate:0, heating_offset:0, thermal_off1:0, thermal_off2:0, pressure1:0, pressure2:0, electric_heater1:0, electric_heater2:0, humidifier:0, humidifier_modifier:0, leftovers_settings:[2:0, 6:0, 12:0, 14:0, 18:0, 19:0, 20:0, 21:0, 22:0, 26:0, 28:0, 29:0, 30:0, 31:0]], reportedProfile:[fan_speed_stages:5, has_air_direction:true, has_auto_fan_speed:true, has_dry_function:true, has_extended_temp_range:true, has_heat_function:true, has_swing_direction:true, has_test_run:false, has_unit_function_setting:false, has_ventilation_function:true, display_setting_temp_of_dry:true, maximum_auto_temp:29, maximum_cool_or_dry_temp:29, maximum_heat_temp:29, minimum_auto_temp:14, minimum_cool_or_dry_temp:14, minimum_heat_temp:8], sendDesiredConditionsPending:false, sendDesiredConditionsTime:2021-07-09T23:20:19.291Z, systemChangeoverEnabled:true, $$hashKey:object:1722, _requestRescan:0, _isRespondingLocally:null, acoilSettings:[isAcoil:false, inputs:[humidistat:false, ervSwitch:false, floatSwitchWet:false], outputs:[w1:false, w2:false, y:false, g:false, erv:false, humidifer:false, heartbeat:false], humidifier:[targetPcr:0, source:null, enable:false], erv:[mode:classic], ytoo:[fan:false, humidifier:false, erv:false], cbp:0, oat:0, bpcr:off, ebp:false, fDelay:0], autoChangeoverEnabled:false, optimalStart:false]], children:[], level:3, label:Whole House, id:1584850810976-2055058039, lastUpdate:1584850905544, isSystemChangeoverGroup:true, $$hashKey:object:13690, reportedCondition:[more:[:], power:1, operation_mode:3, sp_cool:20, _created:1625872819290, fan_speed:6, sp_heat:21.5]]], label:Home, level:2, id:1581290123319-1352448193, lastUpdate:1584850810976, network:[name:HA2, password:], $$hashKey:object:1699, reportedCondition:[more:[:], power:0, operation_mode:3, sp_heat:20, sp_cool:20, _created:1625526108272]]
dev:24962021-07-12 08:53:56.535 am debugretrieveAuthCode_KumoCloud: New Auth Code - 419e6f708d5dc8a024c09af8178fa5ae
dev:24962021-07-12 08:53:56.525 am debugretrieveAuthCode_KumoCloud: HTTP Response = [[token:419e6f708d5dc8a024c09af8178fa5ae, username:michaelahess@gmail.com, device:null], [lastUpdate:1581290123318, sendAnalytics:1, filterReminder:true], [lastScheduleChange:0, zoneTable:[:], children:[[lastScheduleChange:0, zoneTable:[:], children:[[lastScheduleChange:0, zoneTable:[9X34P0088100106F:[serial:9X34P0088100106F, mac:d4:53:83:46:4f:97, label:Living Room, port:80, unitType:ductless, lastUpdate:1626057784202, eqcStageThreeBacksupChannels:[1:0, 2:0, 3:0, 4:0], eqcUpdatedLocally:[1:false, 2:false, 3:false, 4:false], prohibits:[global:[power:false, mode:false, setpoint:false], local:[power:false, mode:false, setpoint:false], effective:[power:false, mode:false, setpoint:false]], prohibitsChanged:1593382188689, holdChanged:0, hasElectricHeatingOption:false, ledDisabled:true, cryptoSerial:0123835fad3eb5b1ee, cryptoKeySet:F, timezone:America/Denver, firmwareVersion:02.06.03, autoModeEnabled:false, roomTempOffset:-3, password:wGa148lurWJtzlbK+ihddpPfOvdd1M6rw0ke4gei, sendDesiredConditionsPending:false, sendDesiredConditionsTime:2021-07-10T04:09:46.417Z, systemChangeoverEnabled:true, minCoolSetpoint:15.5, maxHeatSetpoint:28, kumoSensorSettings:null, address:10.54.25.225, $$hashKey:object:405, desiredConditionStack:[], reportedCondition:[more:[:], _created:1626057784202], overrideSettings:[:], forceCloudUpdates:false, errorHandler:[1:[error2char:A0, error4char:8000, timestamp:1625306576, code:8000, text:8000]], rssi:[:], reportedInitialSettings:[assigned_settings:[:], restart_after_outage:0, vent_air:0, voltage:0, energy_save:0, filter_alerts:0, auto_fan:0, pla_outlets:0, filter_type:0, frost_temp:0, defrost:0, oscillate:0, heating_offset:0, thermal_off1:0, thermal_off2:0, pressure1:0, pressure2:0, electric_heater1:0, electric_heater2:0, humidifier:0, humidifier_modifier:0, leftovers_settings:[2:0, 6:0, 12:0, 14:0, 18:0, 19:0, 20:0, 21:0, 22:0, 26:0, 28:0, 29:0, 30:0, 31:0]], reportedProfile:[fan_speed_stages:5, has_air_direction:true, has_auto_fan_speed:true, has_dry_function:true, has_extended_temp_range:true, has_heat_function:true, has_swing_direction:true, has_test_run:false, has_unit_function_setting:false, has_ventilation_function:true, display_setting_temp_of_dry:true, maximum_auto_temp:28, maximum_cool_or_dry_temp:28, maximum_heat_temp:28, minimum_auto_temp:13, minimum_cool_or_dry_temp:13, minimum_heat_temp:7], equipmentControllerSettings:[:], lastAdapterUpdate:2021-05-17 22:21:27.609563, systemChangeoverSettings:[masterZone:[serial:9934P008T100003F, minRuntime:20, maxStandby:180, disable:none, activeMode:null, durActive:null, durInactive:null], priority:1], mhk2Settings:[auto:[owner:none, status:inactive, heatSetpoint:null, coolSetpoint:null], connected:[thermostat:false, thermostatBattery:unset, outdoorAir:false, outdoorAirBattery:unset, indoorAir:false, indoorAirBattery:unset], dr:[override:false, event:none], hold:[adapter:[cancelMHK2:false, endTime:0], mhk2:[cancelAdapter:false, endTime:0]], info:[model:, serial:, firmware:], schedule:[owner:adapter, enabled:disabled], status:[outdoorTemp:0, outdoorHumid:null, indoorHumid:null]], programEventSettings:[1:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:0600, settings:[mode:heat, spCool:null, spHeat:20, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 2:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:2200, settings:[mode:heat, spCool:null, spHeat:17.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 3:[active:false, inUse:false, day:MoTuWeThFr, time:1215, settings:[mode:off, spCool:null, spHeat:null, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 4:[active:false, inUse:false, day:MoTuWeThFr, time:1115, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 5:[active:false, inUse:false, day:MoTuWeThFr, time:1615, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 6:[active:false, inUse:false, day:MoTuWeThFr, time:2100, settings:[mode:heat, spCool:null, spHeat:20, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 7:[active:false, inUse:false, day:SuSa, time:0800, settings:[mode:heat, spCool:null, spHeat:21.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.154Z], 8:[active:false, inUse:false, day:SuSa, time:2100, settings:[mode:heat, spCool:null, spHeat:19.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 9:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 10:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 11:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 12:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.789Z], 13:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.790Z], 14:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.790Z], 15:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 16:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 17:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 18:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 19:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 20:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 21:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.401Z], 22:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 23:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 24:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 25:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.307Z], 26:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.308Z], 27:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.308Z], 28:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T14:32:41.308Z]], _requestRescan:0, _isRespondingLocally:null, acoilSettings:[isAcoil:false, inputs:[humidistat:false, ervSwitch:false, floatSwitchWet:false], outputs:[w1:false, w2:false, y:false, g:false, erv:false, humidifer:false, heartbeat:false], humidifier:[targetPcr:0, source:null, enable:false], erv:[mode:classic], ytoo:[fan:false, humidifier:false, erv:false], cbp:0, oat:0, bpcr:off, ebp:false, fDelay:0], autoChangeoverEnabled:false, optimalStart:false], 9934P008T100003F:[serial:9934P008T100003F, mac:d4:53:83:2b:7f:9b, label:Bedroom, port:80, unitType:ductless, reportedCondition:[more:[:], _created:1626057784205], desiredConditionStack:[], lastUpdate:1626057784205, overrideSettings:[:], forceCloudUpdates:false, errorHandler:[1:[error2char:A0, error4char:8000, timestamp:1625890076, code:8000, text:8000]], equipmentControllerSettings:[:], eqcStageThreeBacksupChannels:[1:0, 2:0, 3:0, 4:0], eqcUpdatedLocally:[1:false, 2:false, 3:false, 4:false], mhk2Settings:[auto:[owner:none, status:inactive, heatSetpoint:null, coolSetpoint:null], connected:[thermostat:false, thermostatBattery:unset, outdoorAir:false, outdoorAirBattery:unset, indoorAir:false, indoorAirBattery:unset], dr:[override:false, event:none], hold:[adapter:[cancelMHK2:false, endTime:0], mhk2:[cancelAdapter:false, endTime:0]], info:[model:, serial:, firmware:], schedule:[owner:adapter, enabled:disabled], status:[outdoorTemp:0, outdoorHumid:null, indoorHumid:null]], systemChangeoverSettings:[masterZone:[serial:9934P008T100003F, minRuntime:20, maxStandby:180, disable:none, activeMode:null, durActive:null, durInactive:null], priority:1], programEventSettings:[1:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:0600, settings:[mode:heat, spCool:null, spHeat:20, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.222Z], 2:[active:false, inUse:false, day:SuMoTuWeThFrSa, time:2200, settings:[mode:heat, spCool:null, spHeat:17.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.222Z], 3:[active:false, inUse:false, day:MoTuWeThFr, time:0600, settings:[mode:heat, spCool:null, spHeat:21.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 4:[active:false, inUse:false, day:MoTuWeThFr, time:0745, settings:[mode:off, spCool:null, spHeat:null, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 5:[active:false, inUse:false, day:MoTuWeThFr, time:1215, settings:[mode:off, spCool:null, spHeat:null, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 6:[active:false, inUse:false, day:MoTuWeThFr, time:1615, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 7:[active:false, inUse:false, day:MoTuWeThFr, time:1115, settings:[mode:heat, spCool:null, spHeat:22.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:48.223Z], 8:[active:false, inUse:false, day:MoTuWeThFr, time:2100, settings:[mode:heat, spCool:null, spHeat:19.5, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 9:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 10:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 11:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 12:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 13:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.862Z], 14:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.863Z], 15:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 16:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 17:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 18:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 19:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 20:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 21:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.492Z], 22:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 23:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 24:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 25:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 26:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 27:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z], 28:[active:false, inUse:false, day:, time:0000, settings:[mode:heat, spCool:0, spHeat:0, vaneDir:auto, fanSpeed:auto], lastUpdated:2021-07-10T04:09:47.126Z]], prohibits:[global:[power:false, mode:false, setpoint:false], local:[power:false, mode:false, setpoint:false], effective:[power:false, mode:false, setpoint:false]], prohibitsChanged:1593832606056, holdChanged:0, hasElectricHeatingOption:false, rssi:[:], ledDisabled:true, password:VGZDI/8r9tZTJxv69jWGURLMbHu6XdJ+mXIBo1+g, cryptoSerial:0123ea6714c0febfee, cryptoKeySet:F, lastAdapterUpdate:2021-07-03 20:22:23.107836, firmwareVersion:02.06.03, autoModeEnabled:false, roomTempOffset:-2, minCoolSetpoint:16.5, maxHeatSetpoint:29, timezone:America/Denver, kumoSensorSettings:null, address:10.54.25.242, reportedInitialSettings:[assigned_settings:[:], restart_after_outage:0, vent_air:0, voltage:0, energy_save:0, filter_alerts:0, auto_fan:0, pla_outlets:0, filter_type:0, frost_temp:0, defrost:0, oscillate:0, heating_offset:0, thermal_off1:0, thermal_off2:0, pressure1:0, pressure2:0, electric_heater1:0, electric_heater2:0, humidifier:0, humidifier_modifier:0, leftovers_settings:[2:0, 6:0, 12:0, 14:0, 18:0, 19:0, 20:0, 21:0, 22:0, 26:0, 28:0, 29:0, 30:0, 31:0]], reportedProfile:[fan_speed_stages:5, has_air_direction:true, has_auto_fan_speed:true, has_dry_function:true, has_extended_temp_range:true, has_heat_function:true, has_swing_direction:true, has_test_run:false, has_unit_function_setting:false, has_ventilation_function:true, display_setting_temp_of_dry:true, maximum_auto_temp:29, maximum_cool_or_dry_temp:29, maximum_heat_temp:29, minimum_auto_temp:14, minimum_cool_or_dry_temp:14, minimum_heat_temp:8], sendDesiredConditionsPending:false, sendDesiredConditionsTime:2021-07-09T23:20:19.291Z, systemChangeoverEnabled:true, $$hashKey:object:1722, _requestRescan:0, _isRespondingLocally:null, acoilSettings:[isAcoil:false, inputs:[humidistat:false, ervSwitch:false, floatSwitchWet:false], outputs:[w1:false, w2:false, y:false, g:false, erv:false, humidifer:false, heartbeat:false], humidifier:[targetPcr:0, source:null, enable:false], erv:[mode:classic], ytoo:[fan:false, humidifier:false, erv:false], cbp:0, oat:0, bpcr:off, ebp:false, fDelay:0], autoChangeoverEnabled:false, optimalStart:false]], children:[], level:3, label:Whole House, id:1584850810976-2055058039, lastUpdate:1584850905544, isSystemChangeoverGroup:true, $$hashKey:object:13690, reportedCondition:[more:[:], power:1, operation_mode:3, sp_cool:20, _created:1625872819290, fan_speed:6, sp_heat:21.5]]], label:Home, level:2, id:1581290123319-1352448193, lastUpdate:1584850810976, network:[name:HA2, password:], $$hashKey:object:1699, reportedCondition:[more:[:], power:0, operation_mode:3, sp_heat:20, sp_cool:20, _created:1625526108272]]], level:1, lastUpdate:1626188037303, id:1581290123311-2841356538, label:Home, version:28830], no device token]
dev:24962021-07-12 08:53:53.956 am debugsetAuthCode: method called, Platform = KumoCloud
dev:24962021-07-12 08:53:53.954 am debugrefresh: Refresh process called
dev:24962021-07-12 08:53:18.403 am debugsetBaseURL: Platform provided = KumoCloud, alternateURL = null
In my Kumo app, I have a group Whole House, that sits next to the Home icon. Under Whole House there are two units, Bedroom and Living Room.
