Ugh. This is getting annoying.
Out since 10 PM; Now 5:30 AM here.
Turned off standby generator overnight.
On standby now,
Some takeaways so far
-Automation works/recovers better on battery backup. No inexplicable zigbee drops like last outage
-Still had 3 bars on the three TalentCell batteries that back up router, modem, and hub after overnight
-Modem backup useless this time since internet provider (Spectrum) went down along with utility power. Using mobile hotspot.
-Turn off, probably, most voice notifications overnight-it's the wind blowing open the mailbox and yes, I know the freezer is warm
-Fridge and its freezer went to 45F overnight. Don't want to run gen overnight. Probably would do better if I had the ice-maker running, but if its ice melts...a mess
-Still liking the local La Crosse thermometer on the fridge/freezer
-Standby (propane) generation is very nice. This time I'm eating breakfast, taking shower, etc, before transferring to the little 2000 W Honda inverter genny.
edit 1
-Pulsations seen on led bulbs with the new-ish 22kw Generac standby
-Running on little inverter genny now-No pulsations
-Lights dimmed momentarily when the deep well submersible pump started-normal, but a soft start pump might be in the cards at some point; might be hard to argue with simplicity though-it's been down in the hole for nigh on 20 years, knock on wood
