They usually just look at logs/what is installed.
Per previous comments by Hubitat staff - no, they don't.
For the record and other's use:
I am now working to identify any other custom code that I had previously stopped using/removed and adding it back one at a time giving 2-3 days in between as that seems to be the maximum time until a lockup prior.
For the HE staff, if you would like more information on my Chromecast setup let me know, I have 2 mini's and a home Hub.
hope it helps someone-
Chris
With the hub update 2.1.0, I decided to re-do all of my Rule Machine automations, but before that happened, my hub locked up last Friday - the first time ever for me.
With no clear changes that might have led to this, I removed a few apps that I was testing out, and even though I have very very little in the way of "fancy" apps loaded anymore, I experienced another complete lock up yesterday.
In both cases, by the time I realized the hub was locked up, a bunch of my ZigBee devices had dropped their connection, so I have to assume the hub's ZigBee network also stopped working altogether.
Before contacting support, I was hoping to try performing a "soft" Hub Reset as explained by @raidflex here:
...however I got a page with a single text entry field asking for a "Login", and my Hubitat username / password are not accepted.
So, I am going to disable the only couple of things that could be suspect and see if the hub locks up again.
Perhaps there's something I'm missing, but I've only experienced slowness in past which I resolved by removing the "offending" apps, and I have never had the hub lock up before the most recent update.
Scratch that. Hub locked up this morning, red light, :8081 was not available.
Rebooted, no "Errors" in the historical logs. Opened support call.
Just got this from support:
Hi there, sorry for the troubles. Our engineers have identified the issue and a fix is coming with next update.
So apparently whatever caused my last lockup is some sort of bug.
I look forward to seeing the description of the bug/fix for your specific issue in the release notes of the next release then!
The more we understand what the issues are, the more we can help ourselves - which is good for both users AND Hubitat.
Good news. Always great when something is identified.
as a follow up, I asked if I could prevent the known issue in some way and got this:
Sorry for the troubles. There is no workaround for this problem. Enabling more custom devices it will only cause your hub to go unresponsive quicker. I would hold off changing anything until the next update rolls out, which shouldn't be far away. However, I do not have a time frame when it will happen.
So may be something in handling custom device drivers etc. Not clear.
I don't want you guys to go thinking that everybody's hubs will be fixed with the next release. We found a very specific bug that was reproducible. If you click on an event in the event list page, it will attempt to open an event details page. Currently that page will blow up, there is a loop that the hub gets into loading the page and causes an out of memory error. This is what support is referring to having been fixed in the next release.
The other issue that people have been experiencing with hub lockups is still our highest priority. I have been working with multiple people to attempt to get to the bottom of it. While we have many promising leads we do not yet have a fix.
An update on my particular issue with extreme slowing. With Chromecast Integration AND Nest Integration disabled, the issue was gone. Two things at once, not a good troubleshooting method.
So after re-enabling the Nest Integration, I had very slow hub performance within a few hours. I disabled the Nest Integration and rebooted. Things were fine for a few days. I re-enabled the Chromecast Integration and left the Nest Integration disabled. After a few more days, everything was still fine.
Nest Integration is deprecated anyway, and Iβm only using it for turning on lights in an emergency. So goodbye Nest Integration, and Iβve switched back to IFTTT for that. All is well on my hub.
Had the same thing and it also seemed to fix mine but i then used the port of NST manager and have not had a lock up since, so if you still want a integration that's the way i would do it
Meh, itβs cloud anyway, no matter what Integration you use. I figure this another stop gap until Google lets everyone in on their big plans for the new integration method.
Should my "grandfathered in" Nest integration ever fail, I will probably sell my Nest and replace it with a basic Zwave t-stat.
Bummer, I don't have nest integration. Was really looking forward to the fix, but based on the description thats not what i'm experiencing.
Yes, that is why I phrased it "my particular issue" so as not to imply that I've discovered something that is global. In fact, I'm going to guess (and probably won't be too far off base) that's probably what most people are dealing with. Either corrupt databases for some reason (possibly pulling the power without proper shutdown) or custom code that is conflicting with some other code or the platform itself.
I would lean that direction as well, as you would think statistically if it was a hardware issue that at least one of my 3 hubs would experience what others have reported, which I have not. But I also have never pulled the power cord on any of the hubs without a proper shutdown first, (as well as non-recommended periodic reboots I also perform)
Thank you for posting the details Chuck, makes it easier to understand and set expectations for what may or may not be fixed in the next release. I suspect because I'm still doing so much work within my hub I have hit it several times lately accidentally.
The last few days I've been too busy to muck about, things just ran on their own with the automations in place and all is well so far.
I'm a newcomer to Hubitat and I'm having lock ups and slowness now too. I've had full lock ups and general slowness at times too. Simple Lighting is much slower currently, dashboards and most of the web UI are very slow to load, I will list my added apps and drivers below in case it helps support determine problems.
Apps: Chromecast(beta), Google Home, Group/Scenes, Dashboard, Simple Lighting, Hue Bridge, MyQ Lite, Notifications, Rule Machine, WATO, Wink Relay
Drivers: LeakSmart Sensor & Valve, MagicHome, Momentary Button Tile, MyQ Garage Door Opener/No-Sensor, Wink Relay.
I'm off to reboot my hub to try to regain some speed.
Disable Chromecast and either disable the apps that use Chromecast or chose another TTS device for those rules and see what happens.
Doing this cured my issues.
I figured that would help but it's why I bought Hubitat so I really don't want to. I need my TTS to wake me if something happens overnight like my basement floods or the door opens. I was doing this in HA but I wanted reliability and commercial support and to survive an Internet outage...
