It would figure when I point someone there it is having issues.
I just went back one revision in the code. Pasted this in and opened and hit done on the app. Seems all is well. Looks like Ken made the changes yesterday that are causing the error.
* HousePanel (Hubitat Version)
* Copyright 2016, 2017, 2018 Kenneth Washington
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* This app started life displaying the history of various ssmartthings
* but it has morphed into a full blown smart panel web application
* it displays and enables interaction with switches, dimmers, locks, etc
* Revision history:
* 07/24/2018 - fix bug in lock opening and closing with motion detection
* 06/21/2018 - Automatic push of Hubitat settings to HP server
* 06/16/2018 - Sync important bug fixes from SmartThings version
* 06/16/2018 - Add cloud and local options and auto configuration
* 06/15/2018 - Port over updates from ST side; icon change other cleanup
* 04/18/2018 - Bugfix curtemp in Thermostat, thanks to @kembod for finding this
* 03/10/2018 - Major speedup by reading all things at once
* 02/25/2018 - Update to support sliders and color hue picker
* 02/04/2018 - Port over to Hubitat
* 01/04/2018 - Fix bulb bug that returned wrong name in the type
* 12/29/2017 - Changed bulb to colorControl capability for Hue light support
* Added support for colorTemperature in switches and lights
* 12/10/2017 - Added name to each thing query return
* - Remove old code block of getHistory code
public static String version() { return "v1.622" }
public static String handle() { return "HousePanel" }
definition(
namespace: "kewashi",
author: "Kenneth Washington",
description: "Tap here to install ${handle()} ${version()} - a highly customizable tablet smart app. ",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/kewpublicicon/smartthings/hpicon1x.png",
iconX2Url: "https://s3.amazonaws.com/kewpublicicon/smartthings/hpicon2x.png",
iconX3Url: "https://s3.amazonaws.com/kewpublicicon/smartthings/hpicon3x.png",
oauth: [displayName: "kewashi house panel", displayLink: ""])
preferences {
section("Hubitat Configuration") {
paragraph "The HousePanel url is the full url address where your HousePanel application is installed. " +
"This is typically a rPi device on the same network subnet as the Hubitat HUB. \n" +
"HousePanel uses this to push the access token and hub id to your server instead of requiring " +
"user manual configuration; however, you can always still configure HousePanel manually. "
input (name: "hpurl", type: "text", title: "HousePanel url", defaultValue: "http://192.168.11.20/smartthings/housepanel.php", required: true, multiple: false )
paragraph "Set the Cloud Calls option to True if your HousePanel app is NOT on your local LAN. " +
"When this is true all calls to HousePanel will be through the Cloud endpoint. " +
"Actions and updates to be slower than local installations."
input (name: "cloudcalls", type: "bool", title: "Cloud Calls", defaultValue: false, required: true)
paragraph "Set this to True if you do not have a SmartThings hub. This will make the Hubitat " +
"installation to return blanks and images that are usual done on the Smartthings side. \n" +
"This will also make the app bypass the SmartThings authentication step."
input (name: "hubitatonly", type: "bool", title: "use Hubitat only?", defaultValue: false, required: true)
section("Lights and Switches...") {
input "myswitches", "capability.switch", multiple: true, required: false, title: "Switches"
input "mydimmers", "capability.switchLevel", hideWhenEmpty: true, multiple: true, required: false, title: "Dimmers"
input "mymomentaries", "capability.momentary", hideWhenEmpty: true, multiple: true, required: false, title: "Momentary Buttons"
input "mylights", "capability.light", hideWhenEmpty: true, multiple: true, required: false, title: "Lights"
input "mybulbs", "capability.colorControl", hideWhenEmpty: true, multiple: true, required: false, title: "Bulbs"
section ("Motion and Presence") {
input "mypresences", "capability.presenceSensor", hideWhenEmpty: true, multiple: true, required: false, title: "Presence"
input "mysensors", "capability.motionSensor", multiple: true, required: false, title: "Motion"
section ("Door and Contact Sensors") {
input "mycontacts", "capability.contactSensor", hideWhenEmpty: true, multiple: true, required: false, title: "Contact Sensors"
input "mydoors", "capability.doorControl", hideWhenEmpty: true, multiple: true, required: false, title: "Doors"
input "mylocks", "capability.lock", hideWhenEmpty: true, multiple: true, required: false, title: "Locks"
section ("Thermostat & Environment") {
input "mythermostats", "capability.thermostat", hideWhenEmpty: true, multiple: true, required: false, title: "Thermostats"
input "mytemperatures", "capability.temperatureMeasurement", hideWhenEmpty: true, multiple: true, required: false, title: "Temperature Measures"
input "myilluminances", "capability.illuminanceMeasurement", hideWhenEmpty: true, multiple: true, required: false, title: "Illuminances"
// input "myweathers", "device.smartweatherStationTile", hideWhenEmpty: true, title: "Weather tile", multiple: false, required: false
section ("Water") {
input "mywaters", "capability.waterSensor", hideWhenEmpty: true, multiple: true, required: false, title: "Water Sensors"
input "myvalves", "capability.valve", hideWhenEmpty: true, multiple: true, required: false, title: "Sprinklers"
section ("Other Sensors (duplicates allowed)...") {
input "mymusics", "capability.musicPlayer", hideWhenEmpty: true, multiple: true, required: false, title: "Music Players"
input "mysmokes", "capability.smokeDetector", hideWhenEmpty: true, multiple: true, required: false, title: "Smoke Detectors"
// input "myothers", "capability.sensor", multiple: true, required: false, title: "Other and Virtual Sensors"
mappings {
path("/getallthings") {
action: [ POST: "getAllThings" ]
path("/doaction") {
action: [ POST: "doAction" ]
path("/doquery") {
action: [ POST: "doQuery" ]
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
configureHub();
log.debug "Installed with settings: ${settings} "
def configureHub() {
state.hubitatOnly = hubitatonly
if ( ! state.accessToken ) {
createAccessToken();
log.debug "Creating new accessToken ... you must save app.id and accessToken in your HousePanel configuration file."
// get the cloud and local access points
def hubip = location.hubs[0].getDataValue("localIP")
def endpt
if ( cloudcalls ) {
endpt = "${getApiServerUrl()}/${hubUID}/apps/${app.id}/"
log.debug "Cloud installation was requested and is reflected in the endpt below"
} else {
endpt = "${hubip}/apps/api/${app.id}/"
// send debug info to log for manual setup option
log.debug "This information is being sent to your HousePanel web app at ${hpurl}"
log.debug "HousePanel url = ${hpurl}"
log.debug "Hubitat IP = ${hubip}"
log.debug "app.id = ${app.id}"
log.debug "accessToken = ${state.accessToken}"
log.debug "Hubitat endpt = ${endpt}"
log.debug "Hubitat only? = ${state.hubitatOnly}"
// push these variables to our HousePanel server
// this can be local or somewhere out on the Internet
// we don't need the hubip and id but we send it anyway
// what we really need is the accesstoken and endpt
def cmds = [
useajax: "confighubitat",
type: "none",
value: [
hubip: hubip,
hubitatid: app.id,
accesstoken: state.accessToken,
endpt: endpt,
hubitatonly: state.hubitatOnly
def params = [
uri: "${hpurl}",
// requestContentType: "application/json",
// query: null,
// body: cmds
requestContentType: "application/x-www-form-urlencoded",
query: cmds
try {
httpGet(params) { resp ->
def msg = ""
if (resp?.status == 200) {
msg = "Success"
} else {
msg = "Failure: ${resp?.status}"
log.debug "response: ${msg} (${resp.data})"
} catch (e) {
log.debug "Something went wrong: $e"
def getSwitch(swid, item=null) {
// getThing(myswitches, swid, item)
item = item? item : myswitches.find {it.id == swid }
def resp = item ? [name: item.displayName, switch: item.currentValue("switch")
] : false
def getBulb(swid, item=null) {
getThing(mybulbs, swid, item)
def getLight(swid, item=null) {
getThing(mylights, swid, item)
def getMomentary(swid, item=null) {
def resp = false
item = item ? item : mymomentaries.find {it.id == swid }
if ( item && item.hasCapability("Switch") ) {
def curval = item.currentValue("switch")
if (curval!="on" && curval!="off") { curval = "off" }
resp = [name: item.displayName, momentary: item.currentValue("switch")]
return resp
def getDimmer(swid, item=null) {
getThing(mydimmers, swid, item)
def getSensor(swid, item=null) {
getThing(mysensors, swid, item)
def getContact(swid, item=null) {
getThing(mycontacts, swid, item)
// change to only return lock status and battery
def getLock(swid, item=null) {
// def lock = getThing(mylocks, swid, item)
item = item? item : mylocks.find {it.id == swid }
def resp = item ? [:] : false
if ( item ) {
resp.put("name",item.displayName)
if ( item.hasCapability("Battery") ) {
resp.put("battery", item.currentValue("battery"))
resp.put("lock", item.currentValue("lock"))
return resp
def getMusic(swid, item=null) {
item = item? item : mymusics.find {it.id == swid }
def resp = item ? [name: item.displayName, track: item.currentValue("trackDescription"),
musicstatus: item.currentValue("status"),
level: item.currentValue("level"),
musicmute: item.currentValue("mute")
] : false
return resp
def getThermostat(swid, item=null) {
item = item? item : mythermostats.find {it.id == swid }
def resp = item ? [name: item.displayName, temperature: item.currentValue("temperature"),
heat: item.currentValue("heatingSetpoint"),
cool: item.currentValue("coolingSetpoint"),
thermofan: item.currentValue("thermostatFanMode"),
thermomode: item.currentValue("thermostatMode"),
thermostate: item.currentValue("thermostatOperatingState")
] : false
if ( item.hasAttribute("humidity") ) {
resp.put("humidity", item.currentValue("humidity"))
// log.debug "Thermostat response = ${resp}"
return resp
// use absent instead of "not present" for absence state
def getPresence(swid, item=null) {
item = item ? item : mypresences.find {it.id == swid }
def resp = item ? [name: item.displayName, presence : (item.currentValue("presence")=="present") ? "present" : "absent"] : false
return resp
def getWater(swid, item=null) {
getThing(mywaters, swid, item)
def getValve(swid, item=null) {
getThing(myvalves, swid, item)
def getDoor(swid, item=null) {
getThing(mydoors, swid, item)
// return just illuminance
def getIlluminance(swid, item=null) {
// getThing(myilluminances, swid, item)
item = item ? item : myilluminances.find {it.id == swid }
def resp = item ? [name: item.displayName, illuminance : item.currentValue("illuminance")] : false
return resp
def getSmoke(swid, item=null) {
getThing(mysmokes, swid, item)
// return just temperature for this capability
def getTemperature(swid, item=null) {
// getThing(mytemperatures, swid, item)
item = item ? item : mytemperatures.find {it.id == swid }
def resp = item ? [name: item.displayName, temperature : item.currentValue("temperature")] : false
return resp
def getWeather(swid, item=null) {
getDevice(myweathers, swid, item)
def getOther(swid, item=null) {
getThing(myothers, swid, item)
def getmyMode(swid, item=null) {
def curmode = location.getCurrentMode()
def curmodename = curmode.getName()
def resp = [ name: swid,
sitename: location.getName(),
themode: curmodename ];
// log.debug "currrent mode = ${curmodename}"
return resp
def getBlank(swid, item=null) {
def resp = [name: "Blank ${swid}", size: "${swid}"]
return resp
def getImage(swid, item=null) {
def resp = [name: "Image ${swid}", url: "${swid}"]
return resp
def getRoutine(swid, item=null) {
def routines = location.helloHome?.getPhrases()
def routine = item ? item : routines.find{it.id == swid}
def resp = routine ? [name: routine.label, label: routine.label] : false
return resp
// a generic device getter to streamline code
def getDevice(mydevices, swid, item=null) {
def resp = false
if ( mydevices ) {
item = item ? item : mydevices.find {it.id == swid }
if (item) {
resp = [:]
def attrs = item.getSupportedAttributes()
attrs.each {att ->
def attname = att.name
def attval = item.currentValue(attname)
resp.put(attname,attval)
return resp
def setOther(swid, cmd, attr, subid ) {
def resp = false
def item = myothers.find {it.id == swid }
if (item && subid.startsWith("_")) {
subid = subid.substring(1)
// log.debug "Activating other device " + item + " command: " + subid
resp = [:]
if ( item.hasCommand(subid) ) {
item."$subid"()
resp = getOther(swid, item)
else if ( subid == "switch" ) {
def onoff = setOnOff(myothers, "switch", swid, cmd, swattr)
resp = onoff ? [switch: onoff] : false
return resp
// make a generic thing getter to streamline the code
def getThing(things, swid, item=null) {
item = item ? item : things.find {it.id == swid }
if ( item ) {
item.capabilities.each {cap ->
// def capname = cap.getName()
cap.attributes?.each {attr ->
try {
def othername = attr.getName()
def othervalue = item.currentValue(othername)
resp.put(othername,othervalue)
} catch (ex) {
log.warn "Attempt to read attribute for ${swid} failed"
// add commands other than standard ones
item.supportedCommands.each { comm ->
try {
def reserved = ["setLevel","setHue",\
"setSaturation","setColorTemperature","setColor","setAdjustedColor",\
"indicatorWhenOn","indicatorWhenOff","indicatorNever",\
"enrollResponse","poll","ping","configure","refresh"]
def comname = comm.getName()
def args = comm.getArguments()
def arglen = args.size()
// log.debug "Command for ${swid} = $comname with $arglen args = $args "
if ( arglen==0 && ! reserved.contains(comname) ) {
resp.put( "_"+comname, comname )
} catch (ex) {
// log.warn "Attempt to read command for ${swid} failed"
return resp
// make a generic thing list getter to streamline the code
def getThings(resp, things, thingtype) {
// def resp = []
// def n = things ? things.size() : 0
// if ( n > 0 ) { log.debug "Number of things of type ${thingtype} = ${n}" }
things?.each {
def val = getThing(things, it.id, it)
resp << [name: it.displayName, id: it.id, value: val, type: thingtype]
return resp
// This retrieves and returns all things
// used up front or whenever we need to re-read all things
def getAllThings() {
def resp = []
resp = getSwitches(resp)
resp = getDimmers(resp)
resp = getMomentaries(resp)
resp = getLights(resp)
resp = getBulbs(resp)
resp = getContacts(resp)
resp = getDoors(resp)
resp = getLocks(resp)
resp = getSensors(resp)
resp = getPresences(resp)
resp = getThermostats(resp)
resp = getTemperatures(resp)
resp = getIlluminances(resp)
resp = getValves(resp)
resp = getWaters(resp)
resp = getSmokes(resp)
resp = getOthers(resp)
if ( state.hubitatOnly ) {
resp = getBlanks(resp)
resp = getImages(resp)
return resp
// this returns just a single active mode, not the list of available modes
// this is done so we can treat this like any other set of tiles
def getModes(resp) {
log.debug "Getting 4 mode tiles"
def val = getmyMode(0)
resp << [name: "Mode", id: "m1x1", value: val, type: "mode"]
resp << [name: "Mode", id: "m1x2", value: val, type: "mode"]
resp << [name: "Mode", id: "m2x1", value: val, type: "mode"]
resp << [name: "Mode", id: "m2x2", value: val, type: "mode"]
return resp
def getBlanks(resp) {
// log.debug "Getting 4 blank tiles"
// def resp = []
def vals = ["b1x1","b1x2","b2x1","b2x2"]
def val
vals.each {
val = getBlank(it)
resp << [name: "Blank ${it}", id: "${it}", value: val, type: "blank"]
return resp
def getImages(resp) {
// def resp = []
// log.debug "Getting the image tiles"
def vals = ["img1","img2","img3","img4"]
def val
vals.each {
val = getImage(it)
resp << [name: "Image ${it}", id: "${it}", value: val, type: "image"]
return resp
def getSwitches(resp) {
// getThings(myswitches, "switch")
// def resp = []
// log.debug "Number of switches = " + myswitches?.size() ?: 0
myswitches?.each {
def multivalue = getSwitch(it.id, it)
resp << [name: it.displayName, id: it.id, value: multivalue, type: "switch" ]
return resp
def getBulbs(resp) {
getThings(resp, mybulbs, "bulb")
def getLights(resp) {
getThings(resp, mylights, "light")
def getDimmers(resp) {
getThings(resp, mydimmers, "switchlevel")
def getSensors(resp) {
getThings(resp, mysensors, "motion")
def getContacts(resp) {
getThings(resp, mycontacts, "contact")
def getMomentaries(resp) {
// def resp = []
// log.debug "Number of momentaries = " + mymomentaries?.size() ?: 0
mymomentaries?.each {
if ( it.hasCapability("Switch") ) {
def val = getMomentary(it.id, it)
resp << [name: it.displayName, id: it.id, value: val, type: "momentary" ]
return resp
def getLocks(resp) {
// getThings(mylocks, "lock")
// def resp = []
// log.debug "Number of locks = " + mylocks?.size() ?: 0
mylocks?.each {
def multivalue = getLock(it.id, it)
resp << [name: it.displayName, id: it.id, value: multivalue, type: "lock"]
return resp
def getMusics(resp) {
// def resp = []
// log.debug "Number of music players = " + mymusics?.size() ?: 0
mymusics?.each {
def multivalue = getMusic(it.id, it)
resp << [name: it.displayName, id: it.id, value: multivalue, type: "music"]
return resp
def getThermostats(resp) {
// def resp = []
// log.debug "Number of thermostats = " + mythermostats?.size() ?: 0
mythermostats?.each {
def multivalue = getThermostat(it.id, it)
resp << [name: it.displayName, id: it.id, value: multivalue, type: "thermostat" ]
return resp
def getPresences(resp) {
// getThings(mypresences, "presence")
// def resp = []
// log.debug "Number of presences = " + mypresences?.size() ?: 0
mypresences?.each {
def multivalue = getPresence(it.id, it)
resp << [name: it.displayName, id: it.id, value: multivalue, type: "presence"]
return resp
def getWaters(resp) {
getThings(resp, mywaters, "water")
def getValves(resp) {
getThings(resp, myvalves, "valve")
def getDoors(resp) {
getThings(resp, mydoors, "door")
def getIlluminances(resp) {
getThings(resp, myilluminances, "illuminance")
def getSmokes(resp) {
getThings(resp, mysmokes, "smoke")
def getTemperatures(resp) {
// def resp = []
// log.debug "Number of temperatures = " + mytemperatures?.size() ?: 0
mytemperatures?.each {
def val = getTemperature(it.id, it)
resp << [name: it.displayName, id: it.id, value: val, type: "temperature"]
return resp
def getWeathers(resp) {
// def resp = []
// log.debug "Number of weathers = " + myweathers?.size() ?: 0
myweathers?.each {
def multivalue = getWeather(it.id, it)
resp << [name: it.displayName, id: it.id, value: multivalue, type: "weather"]
return resp
// get hellohome routines - thanks to ady264 for the tip
def getRoutines(resp) {
// def resp = []
// log.debug "Number of routines = " + routines?.size() ?: 0
routines?.each {
def multivalue = getRoutine(it.id, it)
resp << [name: it.label, id: it.id, value: multivalue, type: "routine"]
return resp
def getOthers(resp) {
def n = myothers ? myothers.size() : 0
if ( n > 0 ) { log.debug "Number of selected other sensors = ${n}" }
myothers?.each {
def thatid = it.id;
def multivalue = getThing(myothers, thatid, it)
resp << [name: it.displayName, id: thatid, value: multivalue, type: "other"]
return resp
def autoType(swid) {
def swtype
if ( mydimmers?.find {it.id == swid } ) { swtype= "switchlevel" }
else if ( mymomentaries?.find {it.id == swid } ) { swtype= "momentary" }
else if ( mylights?.find {it.id == swid } ) { swtype= "light" }
else if ( mybulbs?.find {it.id == swid } ) { swtype= "bulb" }
else if ( myswitches?.find {it.id == swid } ) { swtype= "switch" }
else if ( mylocks?.find {it.id == swid } ) { swtype= "lock" }
else if ( mymusics?.find {it.id == swid } ) { swtype= "music" }
else if ( mythermostats?.find {it.id == swid} ) { swtype = "thermostat" }
else if ( mypresences?.find {it.id == swid } ) { swtype= "presence" }
else if ( myweathers?.find {it.id == swid } ) { swtype= "weather" }
else if ( mysensors?.find {it.id == swid } ) { swtype= "motion" }
else if ( mydoors?.find {it.id == swid } ) { swtype= "door" }
else if ( mycontacts?.find {it.id == swid } ) { swtype= "contact" }
else if ( mywaters?.find {it.id == swid } ) { swtype= "water" }
else if ( myvalves?.find {it.id == swid } ) { swtype= "valve" }
else if ( myilluminances?.find {it.id == swid } ) { swtype= "illuminance" }
else if ( mysmokes?.find {it.id == swid } ) { swtype= "smoke" }
else if ( mytemperatures?.find {it.id == swid } ) { swtype= "temperature" }
else if ( myothers?.find {it.id == swid } ) { swtype= "other" }
else if ( swid=="m1x1" || swid=="m1x2" || swid=="m2x1" || swid=="m2x2" ) { swtype= "mode" }
else { swtype = "" }
return swtype
// routine that performs ajax action for clickable tiles
def doAction() {
// returns false if the item is not found
// otherwise returns a JSON object with the name, value, id, type
def cmd = params.swvalue
def swid = params.swid
def swtype = params.swtype
def swattr = params.swattr
def subid = params.subid
def cmdresult = false
// sendLocationEvent( [name: "housepanel", value: "touch", isStateChange:true, displayed:true, data: [id: swid, type: swtype, attr: swattr, cmd: cmd] ] )
log.debug "doaction params: cmd = $cmd type = $swtype id = $swid subid = $subid"
// get the type if auto is set
if (swtype=="auto" || swtype=="none" || swtype=="") {
swtype = autoType(swid)
switch (swtype) {
case "switch" :
cmdresult = setSwitch(swid, cmd, swattr)
break
case "bulb" :
cmdresult = setBulb(swid, cmd, swattr)
break
case "light" :
cmdresult = setLight(swid, cmd, swattr)
break
case "switchlevel" :
cmdresult = setDimmer(swid, cmd, swattr)
break
case "momentary" :
cmdresult = setMomentary(swid, cmd, swattr)
break
case "lock" :
cmdresult = setLock(swid, cmd, swattr)
break
case "thermostat" :
cmdresult = setThermostat(swid, cmd, swattr, subid)
break
case "music" :
cmdresult = setMusic(swid, cmd, swattr, subid)
break
// note: this requires a special handler for motion to manually set it
case "motion" :
// log.debug "Manually setting motion sensor with id = $swid"
cmdresult = setSensor(swid, cmd, swattr)
break
case "mode" :
cmdresult = setMode(swid, cmd, swattr)
break
case "valve" :
cmdresult = setValve(swid, cmd, swattr)
break
case "door" :
cmdresult = setDoor(swid, cmd, swattr)
break
case "routine" :
cmdresult = setRoutine(swid, cmd, swattr)
break;
case "other" :
cmdresult = setOther(swid, cmd, swattr, subid)
break
log.debug "HousePanel doaction: cmd = $cmd type = $swtype id = $swid subid = $subid cmdresult = $cmdresult"
return cmdresult
// get a tile by the ID not object
def doQuery() {
if ( (swtype=="auto" || swtype=="none" || swtype=="") && swid ) {
switch(swtype) {
// special case to return an array of all things
// each case below also now includes multi-item options for the API
case "all" :
cmdresult = getAllThings()
break
case "switch" :
cmdresult = swid ? getSwitch(swid) : getSwitches( [] )
break
case "bulb" :
cmdresult = swid ? getBulb(swid) : getBulbs( [] )
break
case "light" :
cmdresult = swid ? getLight(swid) : getLights( [] )
break
cmdresult = swid ? getDimmer(swid) : getDimmers( [] )
break
case "momentary" :
cmdresult = swid ? getMomentary(swid) : getMomentaries( [] )
break
case "motion" :
cmdresult = swid ? getSensor(swid) : getSensors( [] )
break
case "contact" :
cmdresult = swid ? getContact(swid) : getContacts( [] )
break
case "lock" :
cmdresult = swid ? getLock(swid) : getLocks( [] )
break
case "thermostat" :
cmdresult = swid ? getThermostat(swid) : getThermostats( [] )
break
case "music" :
cmdresult = swid ? getMusic(swid) : getMusics( [] )
break
case "presence" :
cmdresult = swid ? getPresence(swid) : getPresences( [] )
break
case "water" :
cmdresult = swid ? getWater(swid) : getWaters( [] )
break
case "valve" :
cmdresult = swid ? getValve(swid) : getValves( [] )
break
case "door" :
cmdresult = swid ? getDoor(swid) : getDoors( [] )
break
case "illuminance" :
cmdresult = swid ? getIlluminance(swid) : getIlluminances( [] )
break
case "smoke" :
cmdresult = swid ? getSmoke(swid) : getSmokes( [] )
break
case "temperature" :
cmdresult = swid ? getTemperature(swid) : getTemperatures( [] )
break
case "weather" :
cmdresult = swid ? getWeather(swid) : getWeathers( [] )
break
case "other" :
cmdresult = getOther(swid)
break
case "mode" :
cmdresult = getmyMode(swid)
break
case "routine" :
cmdresult = swid ? getRoutine(swid) : getRoutines( [] )
break
// log.debug "getTile: type = $swtype id = $swid cmdresult = $cmdresult"
return cmdresult
// changed these to just return values of entire tile
def setOnOff(items, itemtype, swid, cmd, swattr) {
def newonoff = false
def item = items.find {it.id == swid }
if (item) {
if (cmd=="on" || cmd=="off") {
newonoff = cmd
} else if ( swattr=="on" || swattr=="off") {
newonoff = swattr
} else {
newonoff = item.currentValue(itemtype)=="off" ? "on" : "off"
newonoff=="on" ? item.on() : item.off()
return newonoff
def setSwitch(swid, cmd, swattr) {
def onoff = setOnOff(myswitches, "switch", swid,cmd,swattr)
def resp = onoff ? [switch: onoff] : false
return resp
def setDoor(swid, cmd, swattr) {
def newonoff
def resp = false
def item = mydoors.find {it.id == swid }
if (item) {
if (cmd=="open" || cmd=="close") {
newonoff = cmd
} else {
newonoff = (item.currentValue("door")=="closed" ||
item.currentValue("door")=="closing" ) ? "open" : "closed"
newonoff=="open" ? item.open() : item.close()
resp = [door: newonoff]
if ( item.hasAttribute("contact") ) {
resp.put("contact", newonoff)
return resp
// special function to set motion status
def setSensor(swid, cmd, swattr) {
def resp = false
def newsw
def item = mysensors.find {it.id == swid }
// anything but active will set the motion to inactive
if (item && item.hasCommand("startmotion") && item.hasCommand("stopmotion") ) {
if (cmd=="active" || cmd=="move") {
item.startmotion()
newsw = "active"
} else {
item.stopmotion()
newsw = "inactive"
resp = [motion: newsw]
return resp
// replaced this code to treat bulbs as Hue lights with color controls
def setBulb(swid, cmd, swattr) {
// def onoff = setOnOff(mybulbs, "bulb", swid,cmd,swattr)
def resp = setGenericLight(mybulbs, swid, cmd, swattr)
return resp
def setLight(swid, cmd, swattr) {
// def onoff = setOnOff(mylights, "light", swid,cmd,swattr)
// def resp = onoff ? [light: onoff] : false
def resp = setGenericLight(mylights, swid, cmd, swattr)
return resp
def setMode(swid, cmd, swattr) {
def resp
def themode = swattr.substring(swattr.lastIndexOf(" ")+1)
def newsw = themode
def allmodes = location.getModes()
def idx=allmodes.findIndexOf{it.name == themode}
if (idx!=null) {
idx = idx+1
if (idx == allmodes.size() ) { idx = 0 }
newsw = allmodes[idx].getName()
} else {
newsw = allmodes[0].getName()
log.debug "Mode changed from $themode to $newsw index = $idx "
location.setMode(newsw);
themode: newsw
return resp
def setDimmer(swid, cmd, swattr) {
def resp = setGenericLight(mydimmers, swid, cmd, swattr)
return resp
def setGenericLight(mythings, swid, cmd, swattr) {
def resp = false
def item = mythings.find {it.id == swid }
def newsw = false
def hue = false
def saturation = false
def temperature = false
def newcolor = false
def skiponoff = false
if (item ) {
def newonoff = item.currentValue("switch")
log.debug "generic light cmd = $cmd swattr = $swattr"
// bug fix for grabbing right swattr when long classes involved
// note: sometime swattr has the command and other times it has the value
// just depends. This is a legacy issue when classes were the command
if ( swattr.endsWith(" on" ) ) {
swattr = "on"
} else if ( swattr.endsWith(" off" ) ) {
swattr = "off"
switch(swattr) {
case "toggle":
newonoff = cmd
} else {
newonoff = newonoff=="off" ? "on" : "off"
// newonoff=="on" ? item.on() : item.off()
break
case "level-up":
newsw = item.currentValue("level")
newsw = newsw.toInteger()
newsw = (newsw >= 95) ? 100 : newsw - (newsw % 5) + 5
item.setLevel(newsw)
if ( item.hasAttribute("hue") ) {
def h = item.currentValue("hue").toInteger()
def s = item.currentValue("saturation").toInteger()
newcolor = hsv2rgb(h, s, newsw)
newonoff = "on"
skiponoff = true
break
case "level-dn":
def del = (newsw % 5) == 0 ? 5 : newsw % 5
newsw = (newsw <= 5) ? 5 : newsw - del
newonoff = "on"
skiponoff = true
break
case "level":
if ( cmd.isNumber() ) {
newsw = cmd.toInteger()
newsw = (newsw >100) ? 100 : newsw
skiponoff = true
newonoff = (newsw == 0) ? "off" : "on"
break
case "hue-up":
hue = item.currentValue("hue").toInteger()
hue = (hue >= 95) ? 100 : hue - (hue % 5) + 5
item.setHue(hue)
def v = item.currentValue("level").toInteger()
newcolor = hsv2rgb(hue, s, v)
newonoff = "on"
skiponoff = true
break
case "hue-dn":
def del = (hue % 5) == 0 ? 5 : hue % 5
hue = (hue <= 5) ? 5 : hue - del
item.setHue(hue)
newonoff = "on"
skiponoff = true
break
case "saturation-up":
saturation = item.currentValue("saturation").toInteger()
saturation = (saturation >= 95) ? 100 : saturation - (saturation % 5) + 5
item.setSaturation(saturation)
newcolor = hsv2rgb(h, saturation, v)
newonoff = "on"
skiponoff = true
break
case "saturation-dn":
def del = (saturation % 5) == 0 ? 5 : saturation % 5
saturation = (saturation <= 5) ? 5 : saturation - del
newonoff = "on"
skiponoff = true
break
case "colorTemperature-up":
temperature = item.currentValue("colorTemperature").toInteger()
temperature = (temperature >= 6500) ? 6500 : temperature - (temperature % 100) + 100
item.setColorTemperature(temperature)
newonoff = "on"
skiponoff = true
break
case "colorTemperature-dn":
/* temperature drifts up so we cant use round down method */
def del = 100
temperature = (temperature <= 2700) ? 2700 : temperature - del
newonoff = "on"
skiponoff = true
break
case "colorTemperature":
temperature = cmd.toInteger()
newonoff = "on"
skiponoff = true
break
case "level-val":
case "hue-val":
case "saturation-val":
case "colorTemperature-val":
break
case "on":
newonoff = "off"
break
case "off":
newonoff = "on"
break
case "color":
if (cmd.startsWith("hsl(") && cmd.length()==16) { // hsl(123,123,123)
hue = cmd.substring(4,7).toInteger()
saturation = cmd.substring(8,11).toInteger()
newsw = cmd.substring(12,15).toInteger()
// log.debug "cmd= ${cmd} hue= ${hue} sat= ${saturation} level= ${newsw}"
item.setHue(hue)
newcolor = hsv2rgb(hue, saturation, newsw)
// log.debug "New color = $newcolor"
newonoff = "on"
skiponoff = true
break
default:
newonoff = cmd
} else {
if ( swattr.isNumber() ) {
newsw = swattr.toInteger()
skiponoff = true
break
if ( ! skiponoff ) {
resp = [switch: newonoff]
if ( newsw ) { resp.put("level", newsw) }
if ( newcolor ) { resp.put("color", newcolor) }
if ( hue ) { resp.put("hue", hue) }
if ( saturation ) { resp.put("saturation", saturation) }
if ( temperature ) { resp.put("colorTemperature", temperature) }
// resp = [name: item.displayName, value: newsw, id: swid, type: swtype]
return resp
def hsv2rgb(h, s, v) {
def r, g, b
h /= 100.0
s /= 100.0
v /= 100.0
def i = Math.floor(h * 6);
def f = h * 6 - i;
def p = v * (1 - s)
def q = v * (1 - f * s)
def t = v * (1 - (1 - f) * s);
switch (i % 6) {
case 0: r = v; g = t; b = p; break;
case 1: r = q; g = v; b = p; break;
case 2: r = p; g = v; b = t; break;
case 3: r = p; g = q; b = v; break;
case 4: r = t; g = p; b = v; break;
case 5: r = v; g = p; b = q; break;
r = Math.floor(r*255).toInteger()
g = Math.floor(g*255).toInteger()
b = Math.floor(b*255).toInteger()
def rhex = Integer.toHexString(r);
def ghex = Integer.toHexString(g);
def bhex = Integer.toHexString(b);
return "#"+rhex+ghex+bhex
def setMomentary(swid, cmd, swattr) {
def resp = false
def item = mymomentaries.find {it.id == swid }
if (item) {
// log.debug "setMomentary command = $cmd for id = $swid"
def newsw = item.currentSwitch
item.push()
resp = getMomentary(swid, item)
// resp = [name: item.displayName, value: item.currentSwitch, id: swid, type: swtype]
return resp
def setLock(swid, cmd, swattr) {
def resp = false
def newsw
def item = mylocks.find {it.id == swid }
log.debug "Performing setLock command with cmd = ${cmd} and swattr = ${swattr}"
if (item) {
if (cmd=="toggle") {
newsw = item.currentLock=="locked" ? "unlock" : "lock"
if ( newsw=="lock" ) {
item.lock()
} else {
item.unlock()
} else if ( cmd=="unknown" ) {
log.debug "Ignoring unknown status..."
} else if ( cmd=="move" ) {
log.debug "Ignoring move command for lock..."
} else if (cmd=="unlock") {
item.unlock()
newsw = "unlocked"
} else if (cmd=="lock") {
item.lock()
newsw = "locked"
resp = [lock: newsw]
return resp
def setValve(swid, cmd, swattr) {
def resp = false
def newsw
def item = myvalves.find {it.id == swid }
if (item) {
if (cmd!="open" && cmd!="close") {
cmd = item.currentValue=="closed" ? "open" : "close"
if (cmd=="open") {
item.open()
newsw = "open"
} else {
item.close()
newsw = "closed"
resp = [valve: newsw]
return resp
// fixed bug to get just the last words of the class
def setThermostat(swid, curtemp, swattr, subid) {
def resp = false
def newsw = 72
def tempint
def item = mythermostats.find {it.id == swid }
if (item) {
// log.debug "setThermostat attr = $swattr for id = $swid curtemp = $curtemp"
resp = getThermostat(swid, item)
// switch (swattr) {
// case "heat-up":
if ( swattr.endsWith("heat-up") ) {
newsw = curtemp.toInteger() + 1
if (newsw > 85) newsw = 85
// item.heat()
item.setHeatingSetpoint(newsw.toString())
resp['heat'] = newsw
// break
// case "cool-up":
else if ( swattr.endsWith("cool-up") ) {
// item.cool()
item.setCoolingSetpoint(newsw.toString())
resp['cool'] = newsw
// break
// case "heat-dn":
else if ( swattr.endsWith("heat-dn")) {
newsw = curtemp.toInteger() - 1
if (newsw < 50) newsw = 50
// item.heat()
// break
// case "cool-dn":
else if ( swattr.endsWith("cool-dn")) {
if (newsw < 60) newsw = 60
// item.cool()
// break
// case "thermostat thermomode heat":
else if ( swattr.contains("emergency")) {
item.heat()
newsw = "heat"
resp['thermomode'] = newsw
// break
else if ( swattr.contains("thermomode") && swattr.endsWith("heat")) {
def modecmd = swattr
item.cool()
newsw = "cool"
// break
// case "thermostat thermomode cool":
else if ( swattr.contains("thermomode") && swattr.endsWith("cool")) {
item.auto()
newsw = "auto"
// break
// case "thermostat thermomode auto":
else if ( swattr.contains("thermomode") && swattr.endsWith("auto")) {
item.off()
newsw = "off"
// break
// case "thermostat thermomode off":
else if ( swattr.contains("thermomode") && swattr.endsWith("off")) {
item.heat()
newsw = "heat"
// break
// case "thermostat thermofan fanOn":
else if ( swattr.contains("thermofan") && swattr.endsWith("on")) {
item.fanAuto()
newsw = "auto"
resp['thermofan'] = newsw
// break
// case "thermostat thermofan fanAuto":
else if ( swattr.contains("thermofan") && swattr.endsWith("auto")) {
item.fanCirculate()
newsw = "circulate"
// break
else if ( swattr.contains("thermofan") && swattr.endsWith("circulate")) {
item.fanOn()
newsw = "on"
// break
// define actions for python end points
else {
// default:
def cmd = curtemp
if ( (cmd=="heat" || cmd=="emergencyHeat") && swattr.isNumber()) {
item.setHeatingSetpoint(swattr)
resp['heat'] = swattr
else if (cmd=="cool" && swattr.isNumber()) {
item.setCoolingSetpoint(swattr)
resp['cool'] = swattr
else if (cmd=="auto" && swattr.isNumber() && item.hasCapability("thermostatSetpoint")) {
item.thermostatSetpoint(swattr)
} else if ( item.hasCommand(cmd) ) {
item."$cmd"()
// break
return resp
def setMusic(swid, cmd, swattr, subid) {
def resp = false
def item = mymusics.find {it.id == swid }
def newsw
if (item) {
// log.debug "music command = $cmd for id = $swid swattr = $swattr"
resp = getMusic(swid, item)
// fix old bug from addition of extra class stuff
if ( swattr.contains("musicmute") && swattr.endsWith("unmuted" )) {
newsw = "muted"
item.mute()
resp['musicmute'] = newsw
} else if ( swattr.contains("musicmute") && swattr.endsWith("muted" )) {
newsw = "unmuted"
item.unmute()
} else {
switch(swattr) {
case "level-up":
case "vol-up":
resp['level'] = newsw
break
case "level-dn":
case "vol-dn":
break
case "level":
break
case "music-play":
newsw = "playing"
item.play()
resp['musicstatus'] = newsw
break
case "music-stop":
newsw = "stopped"
item.stop()
break
case "music-pause":
newsw = "paused"
item.pause()
break
case "music-previous":
item.previousTrack()
resp['track'] = item.currentValue("trackDescription")
break
case "music-next":
item.nextTrack()
break
return resp
def setRoutine(swid, cmd, swattr) {
def routine = location.helloHome?.getPhrases().find{ it.id == swid }
if (routine) {
location.helloHome?.execute(routine.label)
return routine
