Android device as presence sensor
I'm having trouble using my parents' phones as presence sensors - both Android devices. I want to use the Geofence feature to detect when they are home or away, but for some reason it's not working.
I did wonder if it was because they only worked when the app was open, but I can't find a way to test it, or to change the settings.
I have also just noticed that my (iPhone) hasn't logged any geofence activity for over a week, so does anybody have any advice to help solve this problem?
Chris
Try looking at PositionGuard. You can have track tpresence at several locations.
Not looking to start any arguement but my OwnTracks app on my pixel 9 is the most stable, accurate and robust tool I've ever had. I'm not experienced in multi-user implementations but the family stuff is there, and because my individual function works so flawlessly, I would feel safe in saying I'd have nothing but high expectations for multiple family members on that app.
The dashboard abilities, icons and configuration including waypoints external (like you can have it do stuff when you get to work, or other waypoints) is amazing. If you have already looked at this, maybe take a peek!
EDIT: Just an afterthought but I want to add that the dev of the app, lpakula understand every facet of my phone - not just the Hub side. He takes into consideration phone and hub reboots, interactions with permissions and things way beyond normal comprehension. Truly a stable app - I rely on it daily to handle my automation for home/aways presence after having tried so many things (WIFI SSID, HE Mobile, Aggragation, etc.).
Mine is erratic and slow to update as well. It does work, most of the time.
I've found after hub updates, I need to delete the phone app, reboot, then reinstall the phones hubitat app. It also needs to stay active all the time.
Good afternoon
I've finally set this up on my parent's phones and I'm encountering some issues.
I've set my house up as Home, theirs as Mum and Dad's and an area for their holiday home.
If I look on my version of the app, on both of them it says they are at Mum and Dad's, but on Hubitat if I look at the devices, the current area shows as "Away". Any ideas why this might be the case?
Also, is there a difference between sharing and sharing with Habitat? In other words, if I switched off sharing with family, would Hubitat still be able to see my location changes? Or does that need to be on for it to work with Hubitat?
Chris
+1 for Owntracks. Works 100% reliably on our two Pixel 9s for home/away status and automations. if you need assistance the developer @lpakula is the best, one I happily contribute to.
