Double check your base dashboard app id. You can get it by loading up your menu, you shouldn't use the example link exactly
I guess I don't know where to find it.
Ah! Still no token but the ID is 11. Trying...
What do you mean by no token?
Never mind, it showed when I clicked in the address bar. And now I have the expected list of dashboards. Thanks for your patience!
No problem! Glad its working.
To have the link to open a new tab instead of same window change line 64 from
paragraph("""<a href="${state.fullEndpoint}?access_token=${state.secret}&dashboardAppId=${dashboardAppId}&endpoint=${state.endpoint}&hubIp=${getHubIP()}">${state.fullEndpoint}?access_token=${state.secret}&dashboardAppId=${dashboardAppId}&endpoint=${state.endpoint}&hubIp=${getHubIP()}</a>""")
to
paragraph("""<a href="${state.fullEndpoint}?access_token=${state.secret}&dashboardAppId=${dashboardAppId}&endpoint=${state.endpoint}&hubIp=${getHubIP()}" target="_blank">${state.fullEndpoint}?access_token=${state.secret}&dashboardAppId=${dashboardAppId}&endpoint=${state.endpoint}&hubIp=${getHubIP()}</a>""")
Thanks! I'll implement that along with a ton of other features tomorrow or the next day. I also plan to add this to the package manager to make the groovy side of things easier!
If anyone has some feature suggestions / requests, feel free to list them, and I'll see what I can do.
I like this app very much... thanks to you and your son.
Great work, #1 son.
Suggestion: Make the Panels panel/frame/whateveritscalled sizable and maybe minimize with arrow.
I replied to your message. The highlighted dashboard doesn’t change the dashboard itself.
Nice work! For my use case (iOS tablet-safari) works great in portrait mode, does not switch dashboards in landscape mode.
Thanks! I’ll look into a fix today
Ok! It looks like this was a bug specific to iOS not supporting the visibility CSS attribute. I have pushed an update to fix this, and I have verified that it is working on an iPad in landscape.
To get the update, just refresh.
Welcome #1 son (I assume) to this amazing community. Thanks for the hard work your family has provided In pushing the platform forward!
-Travis
Working perfectly! Thank you.
Alrighty! We've got another feature release as promised. In this update:
- Topic has moved to: [Alpha] HubiPanel v0.2 so I can maintain it bettter.
- Added a child-proofing feature (@Evilborg)
- Activating
Child Lock
on a dashboard will cause it to be locked when you hit the lock button - You can activate
Disable settings when locked
to protect the settings button when locked - You can activate
Fully disable viewing dashboards when locked
to completely disable a tab on the dashboard list- Otherwise, it will simply block clicks
- Locking is per-device, and endures a refresh, so do not forget your code. Otherwise, you can clear the web cache for your browser
- Activating
- Various Groovy fixes. This update changes the query parameters again, so you'll have to redo your links again, sorry .
Code is HERE
