Hi!
I'm about to find a good app for my alarm system.
I've tried with Hubitat's own, but I can't get it working properly with the delay. I can't have the door open when I have to arm my alarm.
Do you know a good app or a solution?
Hi!
I am using webCoRE for everything.
The Rule Machine doesn't make too much sense to me. It's too counterintuitive and limited in design.
I prefer seing the conditions and event in a code manner, as it happens in webCoRE.
It was a possibility. I'm just not strong in webcore, and prefer an app in the hubitat itself
use nyckelharpa app, search the forum
thx
I’m not sure if I’m 100% following you, but does Hubitat safety monitor’s “arming delay” option work for your use case? It’s in the “configure arming/disarming/cancel options” sub-menu.
If you’re having trouble configuring it correctly, posting a screenshot of your HSM settings page can help. There’s also the relevant hub documentation page if you haven’t read it yet.
I second the recommendation for nyckelharpa. It adds the features missing in HSM.
Yes, there is. The problem is, I can't have my door open when I have to scar my alarm. Then it has to be closed, and then I can scar it. Can you make a detour to that?
The Nyckelharpa app allows contact sensors to be open when arming.
I could read myself to that. But I can't get it to scar HSM with the door open.
I've attached my setup in pictures
It's setup backwards. NYKL sensors go into HSM, Real sensors go into Nyckelharpa.
If you have anything configured under "Configure Alerts for Arming Failures (contacts open)" in the Configure Arming/Disarming/Canel Options section HSM won't arm if one of the sensors is open, once that has been removed then open sensors will just be ignored and the system will arm. Once the open sensor is closed HSM should start monitoring that sensor again.
Okay, so what you're saying is that if it's my front door that needs to be delayed, it's the only one that needs to be turned on in HSM? The rest of the sensors must be active in Nyckelharpa?
Okay?
To be perfectly clear. It's my 'Dør gang
As documented, only doors used for access and egress, or windows allowed to be open during arming should be specified in Nyckelharpa.
In your case it's only 'Dør gang'. So HSM usage of 'Dør gang' should be replaced with NCKL-Dør gang, as shown in my prior message, when it's allowed to be open for the respective arming state. Then the original sensor name is used in Nyckelharpa.
When the door is closed, no messages. When open, arming is canceled and a message is sent on first try, second try within time frame sends message and arms. Messages are optional.
Okay
Sorry I'm a little slow
Does that mean That I have to, if the door is open, set the alarm twice in a row for it to arm, or can I make it arm at the first attempt when the door is open?
Set the alarm twice in a row for it to arm, within the designated user set time frame.
Wow.
It's weird I can't get around that rule. It is difficult to print the code twice in a row.
Try turning off the arming failure alerts to see if it reacts how you want.
The "Number of seconds allowed for Forced Arming window" can be set as high as 40, more if the code is modified.
When this is set, HSM silently arms with any open sensor.
