I just got an Aeotec AerQ. All I want is something small to detect temperature changes when my fireplace is turned on, so I can set a rule to turn the A/C off in the house as the two conflict at certain times.
As you can see in the image below I have temperature reports set for anytime it changes 1 degree. I have made it change by as much as 30 degrees with no update. Unless I press the button on the sensor, then it updates.
What am I missing here? How do I get this sensor to update to Hubitat quickly.
If it matters the current firmware version is 2.03. Do I just need a different sensor? If so can someone recommend a small sensor like this that I can mount under my mantel to detect temperature changes please
