I set up a bunch of Aeotec Zigbee water link sensors and a EcoNet Z-Wave shut off valve controller yesterday. I then tried activating each sensor to make sure it shuts off the water. Some of the sensors worked and other didn’t. In fact, the ones that did work a minute ago, didn’t work a second time. Is there anything I can try? Is there anything here that would indicate they wouldn’t work correctly?
I wish you would coalesce all your zigbee issues into a single thread rather than their being distributed across multiple posts.
Your mesh isn't that bad. However, as you've stated earlier, you have 29 power-reporting Sengled plugs. If these plugs report power frequently, it is going to make your mesh really busy, causing other messages - such as those from your leak sensors, to be missed.
Turn off power-reporting (or minimize it by configuration on the device page).
I would but, after a few replies, the thread becomes orphan and it seems that there’s no new communication. I realize that I’m not the only person that needs help and you’re very busy but doing all of this troubleshooting is very time-consuming and when one’s smart home is not-so-smart, you tend to be impatient.
All I see is temperature reporting, is this what you’re referring to?
On the device page for each of your Sengled outlets. You'll have to set conservative power reporting limits for each outlet - there is no global setting.
