Aeotec wallmote quad - slide for dimmer?
The wallmote quad says it supports slide actions - is there any way to get that enabled in hubitat? I found a smartthings driver, but cant get it to load. I was able to get push and hold to work with the built in driver, but there is no slide option.
I experimented with the release function, but it conflicts with the hold.. for example, in my rule touch button 1 turns the light on. hold it and it turns off, but since the hold also has a release to it, whatever you set the release command to is the one that sticks - so if you wanted release to dim it to 50% and hold to turn it off and you set both, it would never turn off and will always go to 50% since the release comes after the hold - hence why slide is important.
Ditto the request for slide actions. It would be cool if it could be configured as a dimmer. I bought one for bedside to trigger "good night" routine so I don't have to sleep with Alexa!
so i tried my hand at programming.. i took
and modified a few items such as physcialgraph to hubitat and a few others. Then I found info about changing def configuration = parseXml(configuration_model) to def configuration = new XmlSlurper().parseText(configuration_model) I did that and then the driver would save and load !! But.. then I went to set the preferences and I get this in the logs - ` error groovy.lang.MissingMethodException: No signature of method: user_driver_erocm123_Aeon_WallMote_Quad___User_762.parseXml() is applicable for argument types: (java.lang.String) values: [
Which model of WallMote is this?
Enable/disable the touch sound.
Default: Enable
Enable/disable the touch vibration.
Default: Enable
  Enable/disable the function of button slide.
Default: Enable
To configure which color will be displayed when the button is pressed.
Default: Blue
Multiple "held" events on botton hold? With this option, the controller will send a "held" event about every second while holding down a button. If set to No it will send a "held" event a single time when the button is released.
Default: No
Possible solutions: parse(java.lang.String) on line 327 (updated)`
.. so nothing happens.. however the logs are full in info when you touch the wallmote or even slide it..
dev:7062019-05-13 08:55:59.180 pm debugkeyAttributes: 2
dev:7062019-05-13 08:55:59.153 pm debugsequenceNumber: 106
dev:7062019-05-13 08:55:59.153 pm debugsceneNumber: 3
dev:7062019-05-13 08:55:59.152 pm debugkeyAttributes: 2
dev:7062019-05-13 08:55:56.889 pm debugsequenceNumber: 105
dev:7062019-05-13 08:55:56.889 pm debugsceneNumber: 1
dev:7062019-05-13 08:55:56.887 pm debugkeyAttributes: 1
dev:7062019-05-13 08:55:56.770 pm debugsequenceNumber: 104
dev:7062019-05-13 08:55:56.770 pm debugsceneNumber: 1
dev:7062019-05-13 08:55:56.769 pm debugkeyAttributes: 2
dev:7062019-05-13 08:55:56.605 pm debugsequenceNumber: 103
dev:7062019-05-13 08:55:56.604 pm debugsceneNumber: 1
dev:7062019-05-13 08:55:56.604 pm debugkeyAttributes: 2
dev:7062019-05-13 08:55:56.599 pm debugsequenceNumber: 102
dev:7062019-05-13 08:55:56.598 pm debugsceneNumber: 1
dev:7062019-05-13 08:55:56.597 pm debugkeyAttributes: 2
dev:7062019-05-13 08:41:45.988 pm errororg.xml.sax.SAXParseException: Content is not allowed in prolog. on line 327 (parse)
dev:7062019-05-13 08:41:45.920 pm debugDevice WallMote woke up
last but not least - here is the modified code: is doesnt like line 327.. def configuration = new XmlSlurper().parseText(configuration_model) eventhough thats the code it liked before.
 *  Copyright 2016 Eric Maycock
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Aeon WallMote Dual/Quad
 *  Author: Eric Maycock (erocm123)
 *  Date: 2017-06-19
 *  2017-06-19: Added check to only send color change config for three wakeups. Editing preferences
 *              and hitting "done" will reset the counter. This is an attempt to prevent freezing
 *              caused by updating preferences.
metadata {
	definition (name: "Aeon WallMote Quad - User", namespace: "erocm123", author: "Eric Maycock", vid:"generic-button") {
		capability "Actuator"
		capability "PushableButton"
        capability "HoldableButton"
		capability "Configuration"
		capability "Sensor"
        capability "Battery"
        capability "Health Check"
        attribute "sequenceNumber", "number"
        attribute "numberOfButtons", "number"
        attribute "needUpdate", "string"
        fingerprint mfr: "0086", prod: "0102", model: "0082", deviceJoinName: "Aeon WallMote"
		fingerprint deviceId: "0x1801", inClusters: "0x5E,0x73,0x98,0x86,0x85,0x59,0x8E,0x60,0x72,0x5A,0x84,0x5B,0x71,0x70,0x80,0x7A", outClusters: "0x25,0x26" // secure inclusion
        fingerprint deviceId: "0x1801", inClusters: "0x5E,0x85,0x59,0x8E,0x60,0x86,0x70,0x72,0x5A,0x73,0x84,0x80,0x5B,0x71,0x7A", outClusters: "0x25,0x26"
    preferences {
        input description: "Once you change values on this page, the corner of the \"configuration\" icon will change orange until all configuration parameters are updated.", title: "Settings", displayDuringSetup: false, type: "paragraph", element: "paragraph"
		generate_preferences(configuration_model())
	simulator {
	tiles (scale: 2) {
        multiAttributeTile(name:"button", type:"generic", width:6, height:4) {
  			tileAttribute("device.button", key: "PRIMARY_CONTROL"){
    		attributeState "default", label:'', backgroundColor:"#ffffff", icon: "st.unknown.zwave.remote-controller"
            tileAttribute ("device.battery", key: "SECONDARY_CONTROL") {
			attributeState "battery", label:'${currentValue} % battery'
        valueTile(
			"battery", "device.battery", decoration: "flat", width: 2, height: 2) {
			state "battery", label:'${currentValue}%', unit:""
        valueTile(
			"sequenceNumber", "device.sequenceNumber", decoration: "flat", width: 2, height: 2) {
			state "battery", label:'${currentValue}', unit:""
        standardTile("configure", "device.needUpdate", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
            state "NO" , label:'', action:"configuration.configure", icon:"st.secondary.configure"
            state "YES", label:'', action:"configuration.configure", icon:"https://github.com/erocm123/SmartThingsPublic/raw/master/devicetypes/erocm123/qubino-flush-1d-relay.src/configure@2x.png"
		main "button"
		details(["button", "battery", "sequenceNumber", "configure"])
	def results = []
	if (description.startsWith("Err")) {
	    results = createEvent(descriptionText:description, displayed:true)
	} else {
		def cmd = zwave.parse(description, [0x2B: 1, 0x80: 1, 0x84: 1])
		if(cmd) results += zwaveEvent(cmd)
		if(!results) results = [ descriptionText: cmd, displayed: false ]
	return results
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelStartLevelChange cmd) {
        logging("upDown: $cmd.upDown")
        switch (cmd.upDown) {
           case 0: // Up
              buttonEvent(device.currentValue("numberOfButtons"), "pushed")
           break
           case 1: // Down
              buttonEvent(device.currentValue("numberOfButtons"), "held")
           break
           default:
              logging("Unhandled SwitchMultilevelStartLevelChange: ${cmd}")
           break
def zwaveEvent(hubitat.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
        logging("keyAttributes: $cmd.keyAttributes")
        logging("sceneNumber: $cmd.sceneNumber")
        logging("sequenceNumber: $cmd.sequenceNumber")
        sendEvent(name: "sequenceNumber", value: cmd.sequenceNumber, displayed:false)
        switch (cmd.keyAttributes) {
           case 0:
              buttonEvent(cmd.sceneNumber, "pushed")
           break
           case 1: // released
              if (!settings.holdMode || settings.holdMode == "2") buttonEvent(cmd.sceneNumber, "held")
           break
           case 2: // held
              if (settings.holdMode == "1") buttonEvent(cmd.sceneNumber, "held")
           break
           default:
              logging("Unhandled CentralSceneNotification: ${cmd}")
           break
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x5B: 1, 0x20: 1, 0x31: 5, 0x30: 2, 0x84: 1, 0x70: 1])
	state.sec = 1
	if (encapsulatedCommand) {
		zwaveEvent(encapsulatedCommand)
	} else {
		log.warn "Unable to extract encapsulated cmd from $cmd"
		createEvent(descriptionText: cmd.toString())
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
	response(configure())
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpIntervalReport cmd)
	logging("WakeUpIntervalReport ${cmd.toString()}")
    state.wakeInterval = cmd.seconds
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
    logging("Device ${device.displayName} woke up")
    def request = update_needed_settings()
    request << zwave.versionV1.versionGet()
    if (!state.lastBatteryReport || (now() - state.lastBatteryReport) / 60000 >= 60 * 24)
        logging("Over 24hr since last battery report. Requesting report")
        request << zwave.batteryV1.batteryGet()
    state.wakeCount? (state.wakeCount = state.wakeCount + 1) : (state.wakeCount = 2)
    if(request != []){
       response(commands(request) + ["delay 5000", zwave.wakeUpV1.wakeUpNoMoreInformation().format()])
    } else {
       logging("No commands to send")
       response([zwave.wakeUpV1.wakeUpNoMoreInformation().format()])
def buttonEvent(button, value) {
	createEvent(name: "button", value: value, data: [buttonNumber: button], descriptionText: "$device.displayName button $button was $value", isStateChange: true)
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
    logging("Battery Report: $cmd")
	def map = [ name: "battery", unit: "%" ]
	if (cmd.batteryLevel == 0xFF) {
		map.value = 1
		map.descriptionText = "${device.displayName} battery is low"
		map.isStateChange = true
	} else {
		map.value = cmd.batteryLevel
	state.lastBatteryReport = now()
	createEvent(map)
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
	logging("AssociationReport $cmd")
    state."association${cmd.groupingIdentifier}" = cmd.nodeId[0]
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
     update_current_properties(cmd)
     logging("${device.displayName} parameter '${cmd.parameterNumber}' with a byte size of '${cmd.size}' is set to '${cmd2Integer(cmd.configurationValue)}'")
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
	def fw = "${cmd.applicationVersion}.${cmd.applicationSubVersion}"
	updateDataValue("fw", fw)
	if (state.MSR == "003B-6341-5044") {
		updateDataValue("ver", "${cmd.applicationVersion >> 4}.${cmd.applicationVersion & 0xF}")
	def text = "$device.displayName: firmware version: $fw, Z-Wave version: ${cmd.zWaveProtocolVersion}.${cmd.zWaveProtocolSubVersion}"
	createEvent(descriptionText: text, isStateChange: false)
def zwaveEvent(hubitat.zwave.Command cmd) {
	logging("Unhandled zwaveEvent: ${cmd}")
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	log.debug "msr: $msr"
    updateDataValue("MSR", msr)
def installed() {
    logging("installed()")
    configure()
* Triggered when Done button is pushed on Preference Pane
def updated()
    logging("updated() is being called")
    state.wakeCount = 1
    def cmds = update_needed_settings()
    sendEvent(name: "checkInterval", value: 2 * 60 * 12 * 60 + 5 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
    sendEvent(name: "numberOfButtons", value: settings.buttons ? (settings."3" == "1" ? settings.buttons.toInteger() + 1 : settings.buttons) : (settings."3" ? 4 + 1 : 4), displayed: true)
    sendEvent(name:"needUpdate", value: device.currentValue("needUpdate"), displayed:false, isStateChange: true)
    if (cmds != []) response(commands(cmds))
def configure() {
	state.enableDebugging = settings.enableDebugging
    logging("Configuring Device For SmartThings Use")
    def cmds = []
    if (cmds != []) commands(cmds)
def ping() {
    logging("ping()")
	logging("Battery Device - Not sending ping commands")
def generate_preferences(configuration_model)
    configuration.Value.each
        switch(it.@type)
            case ["byte","short","four"]:
                input "${it.@index}", "number",
                    title:"${it.@label}\n" + "${it.Help}",
                    range: "${it.@min}..${it.@max}",
                    defaultValue: "${it.@value}",
                    displayDuringSetup: "${it.@displayDuringSetup}"
            break
            case "list":
                def items = []
                it.Item.each { items << ["${it.@value}":"${it.@label}"] }
                input "${it.@index}", "enum",
                    displayDuringSetup: "${it.@displayDuringSetup}",
                    options: items
            break
            case "decimal":
               input "${it.@index}", "decimal",
            break
            case "boolean":
               input "${it.@index}", "boolean",
                    title: it.@label != "" ? "${it.@label}\n" + "${it.Help}" : "" + "${it.Help}",
            break
def update_current_properties(cmd)
    def currentProperties = state.currentProperties ?: [:]
    currentProperties."${cmd.parameterNumber}" = cmd.configurationValue
    if (settings."${cmd.parameterNumber}" != null)
        if (convertParam(cmd.parameterNumber, settings."${cmd.parameterNumber}") == cmd2Integer(cmd.configurationValue))
            sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
        else
            sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
    state.currentProperties = currentProperties
def update_needed_settings()
    def cmds = []
    def isUpdateNeeded = "NO"
    if(state.wakeInterval == null || state.wakeInterval != 86400){
        logging("Setting Wake Interval to 86400")
        cmds << zwave.wakeUpV1.wakeUpIntervalSet(seconds: 86400, nodeid:zwaveHubNodeId)
        cmds << zwave.wakeUpV1.wakeUpIntervalGet()
    if(settings."3" == "1"){
       if(!state.association3 || state.association3 == "" || state.association3 == "1"){
          logging("Setting association group 3")
          cmds << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:zwaveHubNodeId)
          cmds << zwave.associationV2.associationGet(groupingIdentifier:3)
       if(!state.association5 || state.association5 == "" || state.association5 == "1"){
          logging("Setting association group 5")
          cmds << zwave.associationV2.associationSet(groupingIdentifier:5, nodeId:zwaveHubNodeId)
          cmds << zwave.associationV2.associationGet(groupingIdentifier:5)
       if(!state.association7 || state.association7 == "" || state.association7 == "1"){
          logging("Setting association group 7")
          cmds << zwave.associationV2.associationSet(groupingIdentifier:7, nodeId:zwaveHubNodeId)
          cmds << zwave.associationV2.associationGet(groupingIdentifier:7)
       if(!state.association9 || state.association9 == "" || state.association9 == "1"){
          logging("Setting association group 9")
          cmds << zwave.associationV2.associationSet(groupingIdentifier:9, nodeId:zwaveHubNodeId)
          cmds << zwave.associationV2.associationGet(groupingIdentifier:9)
    if(state.MSR == null){
        logging("Getting Manufacturer Specific Info")
        cmds << zwave.manufacturerSpecificV2.manufacturerSpecificGet()
        if ("${it.@setting_type}" == "zwave"){
            if (currentProperties."${it.@index}" == null)
               if (it.@setonly == "true"){
                  if (it.@index == 5) {
                      if (state.wakeCount <= 3) {
                          logging("Parameter ${it.@index} will be updated to " + convertParam(it.@index.toInteger(), settings."${it.@index}"? settings."${it.@index}" : "${it.@value}"))
                          def convertedConfigurationValue = convertParam(it.@index.toInteger(), settings."${it.@index}"? settings."${it.@index}" : "${it.@value}")
                          cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(convertedConfigurationValue, it.@byteSize.toInteger()), parameterNumber: it.@index.toInteger(), size: it.@byteSize.toInteger())
                          cmds << zwave.configurationV1.configurationGet(parameterNumber: it.@index.toInteger())
                      } else {
                        logging ("Parameter has already sent. Will not send again until updated() gets called")
                  } else {
               } else {
                  isUpdateNeeded = "YES"
                  logging("Current value of parameter ${it.@index} is unknown")
            else if (settings."${it.@index}" != null && cmd2Integer(currentProperties."${it.@index}") != convertParam(it.@index.toInteger(), settings."${it.@index}"))
                        logging("Parameter ${it.@index} will be updated to " + convertParam(it.@index.toInteger(), settings."${it.@index}"))
                        def convertedConfigurationValue = convertParam(it.@index.toInteger(), settings."${it.@index}")
                    } else {
                } else {
    sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
    return cmds
def convertParam(number, value) {
    long parValue
	switch (number){
    	case 5:
            switch (value) {
                case "1":
                parValue = 4278190080
                break
                case "2":
                parValue = 16711680
                break
                case "3":
                parValue = 65280
                break
                default:
                parValue = value
                break
        break
        default:
        	parValue = value.toLong()
        break
    return parValue
private def logging(message) {
    if (state.enableDebugging == null || state.enableDebugging == "true") log.debug "$message"
* Convert 1 and 2 bytes values to integer
def cmd2Integer(array) {
long value
    if (array != [255, 0, 0, 0]){
        switch(array.size()) {
            case 1:
                value = array[0]
            break
            case 2:
                value = ((array[0] & 0xFF) << 8) | (array[1] & 0xFF)
            break
            case 3:
                value = ((array[0] & 0xFF) << 16) | ((array[1] & 0xFF) << 8) | (array[2] & 0xFF)
            break
            case 4:
                value = ((array[0] & 0xFF) << 24) | ((array[1] & 0xFF) << 16) | ((array[2] & 0xFF) << 8) | (array[3] & 0xFF)
            break
    } else {
         value = 4278190080
    return value
def integer2Cmd(value, size) {
	switch(size) {
	case 1:
		[value.toInteger()]
    break
	case 2:
    	def short value1   = value & 0xFF
        def short value2 = (value >> 8) & 0xFF
        [value2.toInteger(), value1.toInteger()]
    break
    case 3:
        def short value3 = (value >> 16) & 0xFF
        [value3.toInteger(), value2.toInteger(), value1.toInteger()]
    break
	case 4:
        def short value4 = (value >> 24) & 0xFF
		[value4.toInteger(), value3.toInteger(), value2.toInteger(), value1.toInteger()]
	break
private command(hubitat.zwave.Command cmd) {
	if (state.sec) {
		zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
	} else {
		cmd.format()
private commands(commands, delay=1000) {
	delayBetween(commands.collect{ command(it) }, delay)
def configuration_model()
<configuration>
  <Value type="list" byteSize="1" index="buttons" label="WallMote Model" min="2" max="4" value="" setting_type="preference" fw="" displayDuringSetup="true">
    <Help>
   </Help>
        <Item label="Dual" value="2" />
        <Item label="Quad" value="4" />
  </Value>
  <Value type="list" byteSize="1" index="1" label="Touch Sound" min="0" max="1" value="1" setting_type="zwave" fw="">
    <Help>
Default: Enable
   </Help>
        <Item label="Disable" value="0" />
        <Item label="Enable" value="1" />
  </Value>
  <Value type="list" byteSize="1" index="2" label="Touch Vibration" min="0" max="1" value="1" setting_type="zwave" fw="">
    <Help>
Default: Enable
   </Help>
  </Value>
    <Value type="list" byteSize="1" index="3" label="Button Slide" min="0" max="1" value="1" setting_type="zwave" fw="">
    <Help>
Default: Enable
   </Help>
  </Value>
      <Value type="list" byteSize="4" index="5" label="Color" min="1" max="3" value="3" setting_type="zwave" fw="" setonly="true">
    <Help>
Default: Blue
   </Help>
        <Item label="Red" value="1" />
        <Item label="Green" value="2" />
        <Item label="Blue" value="3" />
  </Value>
  <Value type="list" byteSize="4" index="holdMode" label="Hold Mode" min="1" max="2" value="2" setting_type="preference" fw="">
    <Help>
Default: No
   </Help>
        <Item label="No" value="2" />
        <Item label="Yes" value="1" />
  </Value>
  <Value type="boolean" index="enableDebugging" label="Enable Debug Logging?" value="true" setting_type="preference" fw="">
    <Help>
    </Help>
  </Value>
</configuration>
Any luck with this? Just got a wallMote and was hoping dimmers would work in hubitat.
Also curious myself, as they are on sale and look enticing. Though without the sliding function, I might as well keep my two-position switches instead.
I just tried this out and when I went to hit 'configure' I received an error about line 327 and it did not seem to work. So I reverted to the the backup I created immediately before my test. No harm no foul. Would also be interested to know if @darby427 or anyone else was able to get this working? Thanks
Sorry guys.. no luck here.. I try a few more things but could never get it to work so I just gave up and I use it as basically an 8 button device. Someone I think @codahq - said they were working on something in one of the YouTube live broadcasts but I don't know that anything's come of it..
Yes, it's on my todo list. Unfortunately, it's pretty far down the list of priorities. I'm pretty sure the SmartThings device handler already supports the swiping actions as button presses. There's a good chance somebody can take that, capture the responses from swiping in Hubitat and turn them into button events. I'll get to it eventually.
