totally new to Hubitat, but generally quite technically minded....
I've bought a couple of Aeotec radiator valves to start with, they are being found on Z-Wave OK by the Hubitat (on version 2.2.6.129), but then being recognised as "KeyWe" Z-Wave locks, so I can do nothing heating related with them.
Any pointers as to where to start looking for the problem....?
You might try using the recently added Hubitat drivers for "Eurotronic Spirit Thermostat", the hardware is identical to Aeotec.
Simply select the drivers, click "Save Preferences", then hit "Configure".
This would be the simplest way, also you might want to try these drivers, which offer more options and work for my Eurotronic EU-TRVs:
I had actually already installed the driver you linked to, but what I'd missed is that you actually have to apply the driver to the device for it to actually work with the device - perhaps naively I expected that step to happen automagically....
I've switched to the Eurotronic version which is a little simpler, and that's now working - thank you again !
