Aeotec Multisensor 7 Motion - Add motion retrigger/clear time?
Hub: C-8
Version: 2.3.9.157
Aeotec Multisensor 7 Firmware Ver: 1.67
HE Team: Would it possible for you to add to the Aeotec Multisensor 7 driver the ability to adjust motion retrigger/clear time?
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
Sounds like a question for @bcopeland -- looks like the driver just doesn't offer parameter 2 settings. Not sure if this is intentional.
Regardless, with or without support in the driver, you could use the Basic Z-Wave Tool to set this -- or any -- parameter using the information provided in the manual: parameter number, desired value, and byte size.
Thank you for some direction. Still would be nice to have it like the tri sensor.
