Aeotec Multisensor 6
You can still power it via USB after it's been paired in while on batteries.
I'm not sure how well that works anymore.. it certainly used to be true but my updated devices show as being on power had routed some stuff... Fortunately they are on the mesh edge.. They are HORRIBLE routers.
Well I did a little cheat, I bought the MS6 as close as I could and reset the hub and power cycled the MS6 this seemed to jump start it and now its routing a strange way BUT it is working! Will keep an eye on it to see if it drops off again!
So touch wood - I have 15 of these that I paired on battery before latterly adding them to power via a POE adapter, and seemingly, at least for now, none are acting as repeaters they are mostly on FW 1.15, but some are on FW 1.14.
Had a powercut in the summerhouse and its fallen off the network again, really really frustrating :sob: I am tempted to just use batteries and then I know that any power outages wont effect it.
I'm trying to DIY a sort of beam sensor using two multisensors. Does anyone know what I would need to change to have the motion sensor delay be less than 20 seconds? I want the delay to be somewhere in the neighbourhood of 5 seconds, but I don't know how to add this as an option in the driver without breaking something. I'm using @csteele's driver :slight_smile:
You can try changing parameter 3 to 10, this is the lowest allowed value.
Summary
pir
:rofl::rofl::rofl:
Im powered through usb and i have 3 of these. I cant get the lux or humidity to work. I dont see why id need to do anything special. The parameters are there but nothing is reporting. Any help please.
Did you click "configure" on the device page? Also check the device firmware - mine is 1.15.
I like @csteele's MS6 driver - you can install via the community Hubitat Package Manager - search on "aeotec". It probably won't solve your issue but offers some additional features.
Yes i hit configure multiple times. I tried the default driver and the one around post 18 by csteele. Both drivers were doing the same thing. Im not sure which firmware i have, but i know its not the earliest one, and all parameters were working with ST. Where do i find the firmware, i dont see it on the device page.
Here's mine..
Here's the firmware links
Not sure the firmware is your issue though - did you try to remove/exclude, factory reset then re-pair?
My firmware is definitely not listed there. No, i didnt try the remove stuff because its happening on all three, i figure that cant be the issue in a situation like this...what are the chances. But ill try a little later.
I don't know what could be wrong - if the re-pairing does not work maybe try again but do it running on a battery to see what happens there? You can always then plug it in after it's paired.
At this point I'm kind of reaching for ideas though so apologies..
All of my MS6's have worked fine when paired (other than some issues working as repeaters) and always reported temp/humidity/illuminance - in fact until recently I was still using one to trigger my outdoor lighting based on the illuminance reading.
One other thought is maybe bring one closer to the hub to pair - if you do the battery thing should be easy.
Thanks for your help. It turned out redoing the pairing fixed it.
@csteele is there an advanced driver that work with firmware V1.07? The current one indicates that version V1.10 is required. I have two old MultiSensors that run V1.07, and Aeotec states that they cannot be upgraded to the latest firmware (I have an email out to them to confirm that). Thanks.
I don't have any History going back that far BUT the current code should work, minus the version specific options. The most visible :slight_smile: is that the LED options don't work.
I assume you're trying this and have encountered a problem... can you elaborate?
Actually, I have not yet tried, but will give it a go.
On a different but related topic, does selective temperature reporting work with a threshold of 0.2F? I seem to recall that the minimum treshold in recent firmwares had be changed to 2F.
Running firmware V1.15 and a setup of 2 tenth of a degree does not trigger the expected reporting…
Looking at the engineering specs for V1.13 (latest I could find on Aeotec website), it seems like the min temperature treshold for selective reporting is 1F… I’m able to use lower value on V1.07. (For clarity I have several multisensor
S running different firmwares, and as part of an ongoing migration from ST, I was trying to harmonize them)
