bump - Silence from all quarters!
i spoke with Aeotec support, they say that the Dual Nano is their 2nd highest selling device, so its strange to them (and me) that there is so little care factor about this device working properly in Hubitat. Or is there something I am missing here?
@syepes as the apparent guru on Aeotec device handlers (and thank you so much for your work on the others), do you have any suggestions - or a DH for this device in the works?
btw just re-read my earlier post, hope it didn't come across petulant or otherwise, i'm loving hubitat so far and you guys are doing a great job with support...
if you want help with testing/QA or otherwise, let me know.
thanks guys. yeah i checked the list and saw aeotec nano, bought these and didn't appreciate the support difference between nano/dual nano, i assumed it would work. i assumed wrong.
the devices are great though once there's a proper DH i'd see no reason to change.
Hi @syepes thanks for your response! @mike.maxwell has already put up his hand to sort it, no doubt his To Do list is as long as the receipt every time my wife goes to Ikea, so I'm not sure whether your "eventually" beats Mike's list, but either way be good to avoid duplicated efforts...
Same case here, it seems to work just fine but if you need to configure the device then I guess the parameters are different, I never managed to make it work with the Qubino driver. I need to use the Basic Zwave Tool to do that.
Parameter 80 is probably the most tricky one, I don't know why in my case at some point the devices started to fail reporting the physical switch action, and upon checking it is configured for "Hail CC" instead of "Basic CC". Not sure why it worked when installed, stop working a few months later. Changing this parameter to "2" solved it. It would be nice to be able to do it from within the UI of the driver, but apart from that the Qubino is working and I guess with some minimal tweaking it should be "full" Aeotec Dual Nano.
thanks for getting this done @mike.maxwell your work is much appreciated it is indeed working much better with the new driver. intermittent missed status and commands are gone, and performance is faster just as @erktrek says. i can't see any issues at present.
You need to clear your driver 1st. I have a driver that will do this.
Your need to remove the device from all your apps 1st so it doesn't cause issues. Then put the driver back to the aeotec dual nano and you should be good to go. Alternatively exclude it from hubitat and re join it, that will do the same.
