Aeotec Doorbell 6 Button devices
This used to work, but since moving all devices over to c7 hub I'm having this issue...
Aeotec Doorbell 6 button devices when physically pressed DO sound the doorbell (has nothing to do with zwave, proprietary 400ish mhz link between button and siren) however DO NOT register button events anywhere, such as logs.
On the button component device page, if I type 1 or 2 in the PUSH field and click, only then does it register a button event. Not very useful.
Doorbell 6 is otherwise operating as expected, playing sounds triggered from the device page, etc Why is it not reporting button events?
And yes I am using the Doorbell driver for the siren, otherwise the pair/unpair buttons wouldn't be there
If it helps, you are not alone.
Edit:
Nvm. I see you've already discovered the above thread.
Same here. New to Hubitat and I've included the Aeotec Doorbell 6 with the Siren New driver but I get no logging from the button. It shows as Doorbell Button 1 Doorbell 6 Component button with a DNI of 09-BUTTON1.
Aha, got it. That pesky Configure button, not just Save.
