There's a ST DH that's been converted, and works reasonably well.
* HUBITAT: Dome Motion Sensor v1.0
* (Model: DMMS1)
* Author:
* Kevin LaFramboise (krlaframboise)
* Changelog:
* 1.0 (02/10/2018)
* - Initial Release
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (
name: "Dome Motion Sensor",
namespace: "krlaframboise",
author: "Kevin LaFramboise"
capability "Sensor"
capability "Motion Sensor"
capability "Illuminance Measurement"
capability "Battery"
capability "Configuration"
capability "Refresh"
capability "Health Check"
attribute "lastCheckin", "string"
fingerprint deviceId: "0x0701", inClusters: "0x30, 0x31, 0x59, 0x5A, 0x5E, 0x70, 0x71, 0x72, 0x73, 0x80, 0x84, 0x85, 0x86"
fingerprint mfr:"021F", prod:"0003", model:"0083"
preferences {
input "ledEnabled", "enum",
title: "Enable/Disable LED:",
defaultValue: ledEnabledSetting,
required: false,
displayDuringSetup: true,
options: ledEnabledOptions.collect { it.name }
input "motionEnabled", "enum",
title: "Enable/Disable Motion:",
defaultValue: motionEnabledSetting,
required: false,
options: motionEnabledOptions.collect { it.name }
input "motionClearedDelay", "enum",
title: "Motion Cleared Delay:",
defaultValue: motionClearedDelaySetting,
required: false,
options: motionClearedDelayOptions.collect { it.name }
input "motionRetrigger", "enum",
title: "Motion Retrigger Interval:",
defaultValue: motionRetriggerSetting,
required: false,
options: motionRetriggerOptions.collect { it.name }
input "motionSensitivity", "enum",
title: "Motion Detection Sensitivity:",
defaultValue: motionSensitivitySetting,
required: false,
options: motionSensitivityOptions.collect { it.name }
input "lightReporting", "enum",
title: "Light Reporting Interval:",
defaultValue: lightReportingSetting,
required: false,
options: lightReportingOptions.collect { it.name }
input "lightSensitivity", "enum",
title: "Light Reporting Sensitivity:",
defaultValue: lightSensitivitySetting,
required: false,
options: lightSensitivityOptions.collect { it.name }
input "wakeUpInterval", "enum",
title: "Checkin Interval:",
defaultValue: checkinIntervalSetting,
required: false,
options: checkinIntervalOptions.collect { it.name }
input "batteryReportingInterval", "enum",
title: "Battery Reporting Interval:",
defaultValue: batteryReportingIntervalSetting,
required: false,
input "debugOutput", "bool",
title: "Enable debug logging?",
defaultValue: true,
required: false
// Sets flag so that configuration is updated the next time it wakes up.
def updated() {
// This method always gets called twice when preferences are saved.
if (!isDuplicateCommand(state.lastUpdated, 3000)) {
state.lastUpdated = new Date().time
logTrace("updated()")
logForceWakeupMessage "The configuration will be updated the next time the device wakes up."
// Initializes the device state when paired and updates the device's configuration.
def configure() {
logTrace("configure()")
def cmds = []
def refreshAll = (!state.isConfigured || !settings?.ledEnabled)
if (!state.isConfigured) {
logTrace("Waiting 1 second because this is the first time being configured")
sendEvent(getEventMap("motion", "inactive", false))
sendEvent(getEventMap("illuminance", 0, false, null, "lx"))
cmds << "delay 1000"
configData.sort { it.paramNum }.each {
cmds += updateConfigVal(it.paramNum, it.size, it.value, refreshAll)
if (refreshAll || (checkinIntervalSettingMinutes * 60) != state.checkinInterval) {
cmds << wakeUpIntervalSetCmd(checkinIntervalSettingMinutes)
cmds << wakeUpIntervalGetCmd()
if (cmds) {
logDebug("Sending configuration to device.")
if (state.pendingRefresh || canReportBattery()) {
cmds << batteryGetCmd()
return cmds ? delayBetween(cmds, 1000) : []
private updateConfigVal(paramNum, paramSize, val, refreshAll) {
def result = []
def configVal = state["configVal${paramNum}"]
if (refreshAll || (configVal != val)) {
logDebug "#${paramNum}: changing ${configVal} to ${val}"
result << configSetCmd(paramNum, paramSize, val)
result << configGetCmd(paramNum)
return result
private initializeCheckin() {
// Set the Health Check interval so that it can be skipped once plus 2 minutes.
def checkInterval = ((checkinIntervalSettingMinutes * 2 * 60) + (2 * 60))
sendEvent(name: "checkInterval", value: checkInterval, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
// Required for HealthCheck Capability, but doesn't actually do anything because this device sleeps.
def ping() {
logDebug("ping()")
// Forces the configuration to be resent to the device the next time it wakes up.
def refresh() {
if (state.pendingRefresh) {
logForceWakeupMessage "All settings will be sent to the device the next time it wakes up."
configData.each {
state."configVal${it.paramNum}" = null
else {
logForceWakeupMessage "The sensor data will be refreshed the next time the device wakes up."
state.pendingRefresh = true
private logForceWakeupMessage(msg) {
logDebug("${msg} You can force the device to wake up immediately by pressing the connect button once.")
// Processes messages received from device.
def result = []
sendEvent(name: "lastCheckin", value: convertToLocalTimeString(new Date()), displayed: false, isStateChange: true)
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result += zwaveEvent(cmd)
else {
logDebug("Unable to parse description: $description")
return result
// Updates devices configuration, requests battery report, and/or creates last checkin event.
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd)
logTrace("WakeUpNotification: $cmd")
def result = []
result += configure()
if (result) {
result << "delay 2000"
result << wakeUpNoMoreInfoCmd()
return response(result)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpIntervalReport cmd) {
logTrace("WakeUpIntervalReport: $cmd")
state.checkinInterval = cmd.seconds
initializeCheckin()
return [ ]
// Creates the event for the battery level.
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
logTrace("BatteryReport: $cmd")
state.pendingRefresh = false
def val = (cmd.batteryLevel == 0xFF ? 1 : cmd.batteryLevel)
if (val > 100) {
val = 100
state.lastBatteryReport = new Date().time
logDebug("Battery ${val}%")
createEvent(getEventMap("battery", val, null, null, "%"))
// Stores the configuration values so that it only updates them when they've changed or a refresh was requested.
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
// logTrace("ConfigurationReport $cmd") // ***
def name = configData.find { it.paramNum == cmd.parameterNumber }?.name
if (name) {
def val = convertToScaledValue(cmd.configurationValue, cmd.size)
logDebug("${name}(#${cmd.parameterNumber}) = ${val}")
state."configVal${cmd.parameterNumber}" = val
else {
logDebug("Parameter ${cmd.parameterNumber}: ${cmd.configurationValue}")
state.isConfigured = true
return []
// Creates motion events.
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
def result = []
// logTrace("NotificationReport: $cmd") //***
if (cmd.notificationType == 0x07) {
switch (cmd.event) {
case 0x00:
logDebug("Motion Inactive")
result << createEvent(getEventMap("motion", "inactive"))
break
case 0x08:
logDebug("Motion Active")
result << createEvent(getEventMap("motion", "active"))
break
default:
logDebug("Unknown Notification Event: ${cmd}")
return result
// Creates illuminance events.
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
def result = []
logTrace("SensorMultilevelReport $cmd")
if (cmd.sensorType == 3) {
result << createEvent(getEventMap("illuminance", cmd.scaledSensorValue, null, null, "lx"))
state.lastRefreshed = new Date().time
return result
// Ignoring event because motion events are being handled by notification report.
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
// logTrace("SensorBinaryReport: $cmd") // ***
return []
// Logs unexpected events from the device.
def zwaveEvent(hubitat.zwave.Command cmd) {
logDebug("Unhandled Command: $cmd")
return []
private getEventMap(name, value, displayed=null, desc=null, unit=null) {
def isStateChange = (device.currentValue(name) != value)
displayed = (displayed == null ? isStateChange : displayed)
def eventMap = [
value: value,
displayed: displayed,
isStateChange: isStateChange
if (desc) {
eventMap.descriptionText = desc
if (unit) {
eventMap.unit = unit
// logTrace("Creating Event: ${eventMap}") // ***
return eventMap
private wakeUpIntervalGetCmd() {
return zwave.wakeUpV2.wakeUpIntervalGet().format()
private wakeUpIntervalSetCmd(minutesVal) {
return zwave.wakeUpV2.wakeUpIntervalSet(seconds:(minutesVal * 60), nodeid:zwaveHubNodeId).format()
private wakeUpNoMoreInfoCmd() {
return zwave.wakeUpV2.wakeUpNoMoreInformation().format()
private batteryGetCmd() {
return zwave.batteryV1.batteryGet().format()
private configGetCmd(paramNum) {
return zwave.configurationV2.configurationGet(parameterNumber: paramNum).format()
private configSetCmd(paramNum, size, val) {
return zwave.configurationV2.configurationSet(parameterNumber: paramNum, size: size, configurationValue: convertFromScaledValue(val, size)).format()
private getCommandClassVersions() {
0x30: 2, // Sensor Binary
0x31: 5, // Sensor Multilevel
0x59: 1, // AssociationGrpInfo
0x5A: 1, // DeviceResetLocally
0x5E: 2, // ZwaveplusInfo
0x70: 2, // Configuration
0x71: 3, // Notification v4
0x72: 2, // ManufacturerSpecific
0x73: 1, // Powerlevel
0x80: 1, // Battery
0x84: 2, // WakeUp
0x85: 2, // Association
0x86: 1 // Version (2)
private canReportBattery() {
def reportEveryMS = (batteryReportingIntervalSettingMinutes * 60 * 1000)
return (!state.lastBatteryReport || ((new Date().time) - state.lastBatteryReport > reportEveryMS))
// Settings
private getLedEnabledSetting() {
return settings?.ledEnabled ?: findDefaultOptionName(ledEnabledOptions)
private getMotionEnabledSetting() {
return settings?.motionEnabled ?: findDefaultOptionName(motionEnabledOptions)
private getMotionSensitivitySetting() {
return settings?.motionSensitivity ?: findDefaultOptionName(motionSensitivityOptions)
private getLightSensitivitySetting() {
return settings?.lightSensitivity ?: findDefaultOptionName(lightSensitivityOptions)
private getMotionClearedDelaySetting() {
return settings?.motionClearedDelay ?: findDefaultOptionName(motionClearedDelayOptions)
private getMotionRetriggerSetting() {
return settings?.motionRetrigger ?: findDefaultOptionName(motionRetriggerOptions)
private getLightReportingSetting() {
return settings?.lightReporting ?: findDefaultOptionName(lightReportingOptions)
private getCheckinIntervalSettingMinutes() {
return convertOptionSettingToInt(checkinIntervalOptions, checkinIntervalSetting) ?: 720
private getCheckinIntervalSetting() {
return settings?.wakeUpInterval ?: findDefaultOptionName(checkinIntervalOptions)
private getBatteryReportingIntervalSettingMinutes() {
return convertOptionSettingToInt(checkinIntervalOptions, batteryReportingIntervalSetting) ?: checkinIntervalSettingMinutes
private getBatteryReportingIntervalSetting() {
return settings?.batteryReportingInterval ?: findDefaultOptionName(checkinIntervalOptions)
// Configuration Parameters
private getConfigData() {
return [
[paramNum: 1, name: "Motion Sensitivity", value: convertOptionSettingToInt(motionSensitivityOptions, motionSensitivitySetting), size: 1],
[paramNum: 2, name: "Motion Cleared Delay", value: convertOptionSettingToInt(motionClearedDelayOptions, motionClearedDelaySetting), size: 2],
[paramNum: 4, name: "Motion Enabled", value: convertOptionSettingToInt(motionEnabledOptions, motionEnabledSetting), size: 1],
[paramNum: 6, name: "Motion Retrigger Interval", value: convertOptionSettingToInt(motionRetriggerOptions, motionRetriggerSetting), size: 1],
[paramNum: 7, name: "Light Reporting Interval", value: convertOptionSettingToInt(lightReportingOptions, lightReportingSetting), size: 2],
[paramNum: 9, name: "Light Sensitivity", value: convertOptionSettingToInt(lightSensitivityOptions, lightSensitivitySetting), size: 1],
[paramNum: 10, name: "LED Enabled", value: convertOptionSettingToInt(ledEnabledOptions, ledEnabledSetting), size: 1],
private getMotionSensitivityOptions() {
return getSensitivityOptions(28, 8, 255, 10)
private getLightSensitivityOptions() {
// Dome: max value documented as 255, but is really 100.
return getSensitivityOptions(49, 1, 100, 4)
private getSensitivityOptions(defaultVal, minVal, maxVal, interval) {
def options = []
options << [name: "1 (Most Sensitive)", value: minVal]
(2..24).each {
minVal += interval
options << [name: "${it}", value: minVal]
options << [name: "25 (Least Sensitive)", value: maxVal]
options.each {
if (it.value == defaultVal) {
it.name = formatDefaultOptionName("${it.name}")
return options
private getLightReportingOptions() {
[name: "1 Minute", value: 60],
[name: "2 Minutes", value: 120],
[name: formatDefaultOptionName("3 Minutes"), value: 180],
[name: "4 Minutes", value: 240],
[name: "5 Minutes", value: 300],
[name: "10 Minutes", value: 600],
[name: "30 Minutes", value: 1800],
[name: "1 Hour", value: 3600],
[name: "2 Hours", value: 7200],
[name: "4 Hours", value: 1440],
[name: "8 Hours", value: 28800]
private getMotionClearedDelayOptions() {
[name: "10 Seconds", value: 10],
[name: "15 Seconds", value: 15],
[name: formatDefaultOptionName("30 Seconds"), value: 30],
[name: "45 Seconds", value: 45],
[name: "3 Minutes", value: 180],
[name: "7 Minutes", value: 420],
private getMotionRetriggerOptions() {
def result = []
result << [name: "1 Second", value: 1]
(2..7).each {
result << [name: "${it} Seconds", value: it]
result << [name: formatDefaultOptionName("8 Seconds"), value: 8]
return result
private getLedEnabledOptions() {
[name: "Disabled", value: 0],
[name: formatDefaultOptionName("Enabled"), value: 1]
private getMotionEnabledOptions() {
private getCheckinIntervalOptions() {
[name: "10 Minutes", value: 10],
[name: "15 Minutes", value: 15],
[name: "30 Minutes", value: 30],
[name: "1 Hour", value: 60],
[name: "2 Hours", value: 120],
[name: "3 Hours", value: 180],
[name: "6 Hours", value: 360],
[name: "9 Hours", value: 540],
[name: formatDefaultOptionName("12 Hours"), value: 720],
[name: "18 Hours", value: 1080],
[name: "24 Hours", value: 1440]
private convertOptionSettingToInt(options, settingVal) {
return safeToInt(options?.find { "${settingVal}" == it.name }?.value, 0)
private formatDefaultOptionName(val) {
return "${val}${defaultOptionSuffix}"
private findDefaultOptionName(options) {
def option = options?.find { it.name?.contains("${defaultOptionSuffix}") }
return option?.name ?: ""
private getDefaultOptionSuffix() {
return " (Default)"
private safeToInt(val, defaultVal=-1) {
return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private safeToDec(val, defaultVal=-1) {
return "${val}"?.isBigDecimal() ? "${val}".toBigDecimal() : defaultVal
private convertToScaledValue(val, size) {
if (size == 2) {
return val[1] + (val[0] * 0x100)
else {
return val[0]
private convertFromScaledValue(val, size) {
if (size == 2) {
return [(byte) ((val >> 8) & 0xff),(byte) (val & 0xff)]
else {
return [val]
private canCheckin() {
// Only allow the event to be created once per minute.
def lastCheckin = device.currentValue("lastCheckin")
return (!lastCheckin || lastCheckin < (new Date().time - 60000))
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
else {
return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
if (settings?.debugOutput || settings?.debugOutput == null) {
log.debug "$msg"
private logTrace(msg) {
// log.trace "$msg" // ***
The values for motion timing are different on the Dome. What I see in the logs is a LOT of Motion Active reports. My instance says "retrigger: 8 seconds".
I'm sure it's different, I'm leaning towards thinking it's better. Fundamentally it's either a big error in the design OR it's triggering on even the smallest motions.
I love it's magnetic mount. I stick the wall piece on with 3M Command and then the sensor itself just mounts anywhere on the dome surface of the mount, magnetically. The light is red and large, a down side, but it does not illuminate for long.
I added the Enable/Disable Motion because the first one I included didn't report motion and I was thinking the Driver didn't insist it be turned on. That wasn't the problem, I had to Exclude / Include a 2nd time and it's been trouble free since.
