I couldn’t get user codes to populate so I just started over.
This is the driver I came up with. It reports lock and unlock locally and through the app, reports who unlocked the door if a pin was used, works with Lock Code Manager, reports DoorSense open/close.
* Yale Assure Lock 2
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Features:
* - Z-Wave S2 Security (Supervision encapsulation)
* - DoorSense (Contact Sensor)
* - Lock Code Manager compatibility
* - Detailed Event Text Reporting
metadata {
definition (name: "Yale Assure Lock 2", namespace: "Trunzoc", author: "Trunzoc") {
capability "Actuator"
capability "Lock"
capability "Lock Codes"
capability "ContactSensor"
capability "Battery"
capability "Configuration"
capability "Refresh"
fingerprint mfr:"0129", prod:"8104", model:"45D1", deviceJoinName: "Yale Assure Lock 2, YRD410" //YRD410-ZW3
fingerprint mfr:"0129", prod:"8104", model:"45D2", deviceJoinName: "Yale Assure Lock 2, YRD420" //YRD420-ZW3
fingerprint mfr:"0129", prod:"8104", model:"45D3", deviceJoinName: "Yale Assure Lock 2, YRD430" //YRD430-ZW3
fingerprint mfr:"0129", prod:"8104", model:"45D5", deviceJoinName: "Yale Assure Lock 2, YRD450" //YRD450-ZW3
fingerprint mfr:"0129", prod:"8107", model:"49D1", deviceJoinName: "Yale Assure Lock 2 Touch, YRD410" //YRD410-F-ZW3
fingerprint mfr:"0129", prod:"8107", model:"49D2", deviceJoinName: "Yale Assure Lock 2 Touch, YRD420" //YRD420-F-ZW3
fingerprint mfr:"0129", prod:"8107", model:"49D3", deviceJoinName: "Yale Assure Lock 2 Touch, YRD430" //YRD430-F-ZW3
fingerprint mfr:"0129", prod:"8107", model:"49D5", deviceJoinName: "Yale Assure Lock 2 Touch, YRD450" //YRD450-F-ZW3
preferences {
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input name: "debugEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "traceEnable", type: "bool", title: "Enable trace logging", defaultValue: false
import hubitat.zwave.commands.doorlockv1.*
import hubitat.zwave.commands.usercodev1.*
import hubitat.zwave.commands.notificationv3.*
import hubitat.zwave.commands.supervisionv1.*
// --- Core Z-Wave Parsing ---
if (traceEnable) log.trace "parse(String description): ${description}"
def result = null
def cmd = zwave.parse(description, [ 0x98: 1, 0x62: 1, 0x71: 3, 0x80: 1, 0x85: 2, 0x86: 1, 0x6C: 1 ])
if (cmd) {
result = zwaveEvent(cmd)
if (debugEnable) log.debug "Parsed ${cmd} to ${result.inspect()}"
return result
// --- S2 Security Supervision Handler ---
def zwaveEvent(SupervisionGet cmd) {
if (traceEnable) log.trace "zwaveEvent(SupervisionGet cmd): ${cmd}"
if (debugEnable) log.debug "SupervisionGet: $cmd"
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand)
sendHubCommand(new hubitat.device.HubAction(zwaveSecureEncap(zwave.supervisionV1.supervisionReport(sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false, status: 0xFF, duration: 0).format()), hubitat.device.Protocol.ZWAVE))
return null
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
if (traceEnable) log.trace "zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd): ${cmd}"
def encapsulatedCommand = cmd.encapsulatedCommand([0x62: 1, 0x71: 3, 0x80: 1, 0x85: 2, 0x63: 1, 0x98: 1, 0x86: 1])
return zwaveEvent(encapsulatedCommand)
// --- Lock Operation & State ---
def zwaveEvent(DoorLockOperationReport cmd) {
if (traceEnable) log.trace "zwaveEvent(DoorLockOperationReport cmd): ${cmd}"
def map = [name: "lock"]
if (cmd.doorLockMode == 0xFF) {
map.value = "locked"
map.descriptionText = "${device.displayName} was locked"
} else {
map.value = "unlocked"
map.descriptionText = "${device.displayName} was unlocked"
if (txtEnable) log.info map.descriptionText
sendEvent(map)
// --- Consolidated Event Reporting ---
def zwaveEvent(NotificationReport cmd) {
if (traceEnable) log.trace "zwaveEvent(NotificationReport cmd): ${cmd}"
if (debugEnable) log.debug cmd.event
// Notification Type 0x06: Access Control
if (cmd.notificationType == 0x06) {
def map = [name: "lock", isStateChange: true]
switch (cmd.event) {
case 0x01: // Manual Lock
map.descriptionText = "${device.displayName} was locked manually"
break
case 0x02: // Manual Unlock
map.descriptionText = "${device.displayName} was unlocked manually"
break
case 0x03: // RF/App Lock
map.descriptionText = "${device.displayName} was locked digitally"
break
case 0x04: // RF/App Unlock
map.descriptionText = "${device.displayName} was unlocked digitally"
break
case 0x05: // Keypad Lock
map.descriptionText = "${device.displayName} was locked via keypad"
break
case 0x06: // Keypad Unlock (With User Data)
def slotId = cmd.eventParameter[2]
def codeName = getCodeName(slotId)
map.descriptionText = "${device.displayName} unlocked by ${codeName}"
sendEvent(name: "lastCodeName", value: codeName)
state.remove("lastCodeName")
break
case 0x0D: // Code Deleted
case 0x0E: // Code Added/Changed
def slotId = cmd.eventParameter[0]
if (txtEnable) log.info "${device.displayName} syncing code ${slotId}..."
executeCommand(zwaveSecureEncap(zwave.userCodeV1.userCodeGet(userIdentifier: slotId)))
return
case 22: // Door Opened
map.name = contact
map.value = "open"
map.descriptionText = "${device.displayName} was opened"
if (txtEnable) log.info "${device.displayName} was opened"
sendEvent(name: "contact", value: "open", descriptionText: "${device.displayName} was opened")
break;
case 23: // Door Closed
map.name = contact
map.value = "closed"
map.descriptionText = "${device.displayName} was closed"
if (txtEnable) log.info "${device.displayName} was closed"
sendEvent(name: "contact", value: "closed", descriptionText: "${device.displayName} was closed")
break
if (map.value) sendEvent(map)
// Fallback handler for older Yale Z-Wave reporting structures (RF/App/Manual)
def zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd) {
if (traceEnable) log.trace "zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd): ${cmd}"
// Alarm Type 0x09: Access Control (Legacy/RF Events)
if (cmd.alarmType == 0x09) {
switch (cmd.alarmLevel) {
case 0x03: // RF Lock
case 0x04: // RF Unlock
def status = (cmd.alarmLevel % 2 != 0) ? "locked" : "unlocked"
sendEvent(name: "lock", value: status, descriptionText: "${device.displayName} ${status} via ${cmd.alarmLevel > 2 ? 'App' : 'Manual'}")
break
// Handle DoorSense (if reported via AlarmReport)
if (cmd.alarmType == 0x16 || cmd.alarmType == 23) {
return handleDoorSenseReport(cmd)
// --- Lock Code Manager Integration ---
def zwaveEvent(UserCodeReport cmd) {
if (traceEnable) log.trace "zwaveEvent(UserCodeReport cmd): ${cmd}"
def codePosition = cmd.userIdentifier.toString()
def lockCodes = loadLockCodes()
if (cmd.userIdStatus == UserCodeReport.USER_ID_STATUS_OCCUPIED) {
def pin = cmd.userCode.toString()
if (!lockCodes.containsKey(codePosition) || lockCodes[codePosition].code != pin) {
lockCodes[codePosition] = [name: "User ${codePosition}", code: pin, status: "active"]
sendEvent(name: "codeChanged", value: "${codePosition} updated", descriptionText: "Code position ${codePosition} updated", isStateChange: true)
} else {
if (lockCodes.containsKey(codePosition)) {
lockCodes.remove(codePosition)
sendEvent(name: "codeChanged", value: "${codePosition} deleted", descriptionText: "Code position ${codePosition} deleted", isStateChange: true)
updateLockCodes(lockCodes)
def setCode(codePosition, pin, codeName = null) {
if (traceEnable) log.trace "setCode(codePosition, pin, codeName = null): ${codePosition}, ${pin}, ${codeName}"
if (!codeName) codeName = "User ${codePosition}"
lockCodes[codePosition.toString()] = [name: codeName, code: pin.toString(), status: "active"]
executeCommand(zwaveSecureEncap(zwave.userCodeV1.userCodeSet(userIdentifier: codePosition, userIdStatus: 1, userCode: pin)))
def deleteCode(codePosition) {
if (traceEnable) log.trace "deleteCode(codePosition): ${codePosition}"
executeCommand(zwaveSecureEncap(zwave.userCodeV1.userCodeSet(userIdentifier: codePosition, userIdStatus: 0)))
def getCodes() {
if (traceEnable) log.trace "getCodes()"
executeCommand(zwaveSecureEncap(zwave.userCodeV1.usersNumberGet()))
private getCodeName(slotId) {
if (traceEnable) log.trace "getCodeName(slotId): ${slotId}"
def codes = loadLockCodes()
def entry = codes["${slotId}"] ?: codes[slotId]
return entry?.name ?: "User ${slotId}"
private Map loadLockCodes() {
if (traceEnable) log.trace "loadLockCodes()"
def lockCodes = device.currentValue("lockCodes")
def decrypted = decrypt(lockCodes) ?: lockCodes
return parseJson(decrypted ?: "{}") ?: [:]
private void updateLockCodes(lockCodes) {
if (traceEnable) log.trace "updateLockCodes(lockCodes): ${lockCodes}"
def json = new groovy.json.JsonOutput().toJson(lockCodes)
sendEvent(name: "lockCodes", value: json, displayed: false, descriptionText: "Lock codes updated")
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
if (traceEnable) log.trace "zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd): ${cmd}"
// 0xFF (255) is Z-Wave's standard report for a low battery warning
def percent = (cmd.batteryLevel == 0xFF) ? 1 : cmd.batteryLevel
def descText = "${device.displayName} battery is ${percent}%"
if (txtEnable) log.info descText
sendEvent(
value: percent,
unit: "%",
descriptionText: descText,
isStateChange: true
// Catch-all for any other unhandled Z-Wave commands to prevent future MissingMethodExceptions
def zwaveEvent(hubitat.zwave.Command cmd) {
if (traceEnable) log.trace "zwaveEvent(hubitat.zwave.Command cmd): ${cmd}"
if (debugEnable) log.debug "Unhandled Z-Wave Command: $cmd"
def zwaveEvent(hubitat.zwave.commands.usercodev1.UsersNumberReport cmd) {
if (traceEnable) log.trace "zwaveEvent(hubitat.zwave.commands.usercodev1.UsersNumberReport cmd): ${cmd}"
if (debugEnable) log.debug "UsersNumberReport: lock supports ${cmd.supportedUsers} codes"
// Update the maxCodes attribute so Lock Code Manager knows the limit
sendEvent(name: "maxCodes", value: cmd.supportedUsers, displayed: false)
// --- Actuator Commands ---
def lock() {
if (traceEnable) log.trace "lock()"
executeCommand(zwaveSecureEncap(zwave.doorLockV1.doorLockOperationSet(doorLockMode: DoorLockOperationSet.DOOR_LOCK_MODE_DOOR_SECURED)))
def unlock() {
if (traceEnable) log.trace "unlock()"
executeCommand(zwaveSecureEncap(zwave.doorLockV1.doorLockOperationSet(doorLockMode: DoorLockOperationSet.DOOR_LOCK_MODE_DOOR_UNSECURED)))
def refresh() {
if (traceEnable) log.trace "refresh()"
def cmds = []
cmds << zwaveSecureEncap(zwave.doorLockV1.doorLockOperationGet())
cmds << zwaveSecureEncap(zwave.batteryV1.batteryGet())
sendHubCommand(new hubitat.device.HubMultiAction(cmds, hubitat.device.Protocol.ZWAVE))
def configure() {
if (traceEnable) log.trace "configure()"
log.info "Configuring Association Groups..."
// Group 1 is the Lifeline for Z-Wave locks, required to report events to the Hub
def hubNode = zwaveHubNodeId
def cmds = []
cmds << zwaveSecureEncap(zwave.associationV1.associationSet(groupingIdentifier: 1, nodeId: hubNode))
cmds << zwaveSecureEncap(zwave.associationV1.associationGet(groupingIdentifier: 1))
// Also request a full refresh to align current states
private executeCommand(command) {
if (traceEnable) log.trace "executeCommand(command): ${command}"
sendHubCommand(new hubitat.device.HubAction(command, hubitat.device.Protocol.ZWAVE))
