I don't have a WeatherFlow device. Is it possible to get a token that permits access to data via the map page?
Eg:
Eg:
Simply use the wundergroud driver then pick a station near you, no token needed for it
Right. So when you set up wunderground, you can use anyone's PWS number.
So the answer is, "I'm out of luck."
SIgn up for a free wunderground account. Receive your free API key.
At top pick Sensor Network, Personal Weather Station network.
Find the closest weatherstation to your physical location. Note the name,
Put the API key and the name into the wunderground driver.,
Enjoy
