I tried to remake the Hubitat Mirror application that mirrors switches and noticed that I can't access the rate/duration variable from the event in the setLevel command and therefore cannot "fade" the light over time like the master switch does.
To see if it was even possible, I tested the Hubitat Mirror app and it seems like it doesn't handle the rate/duration either. When the master switch uses setLevel with a duration, the slave switches uses setLevel without duration (both in my own app and hubitat mirror app)
Wondered if it's intended to not work like that or if I can access it somehow.
