OK, the category is intentionally misleading. My apologies, but I want the brilliant developers in this community to take this challenge seriously.
With the fresh announcement of Z-Wave Long Range development for HE, the hub now supports simple connection and device sharing with Hub Mesh, simple Z-Wave device inclusion with SmartStart, and continued support for Classic Z-Wave Mesh.
Nearly any Zigbee device works on HE and more are being added every day. Hue Bridges integrate easily for great lighting options. Lutron Smart Bridge Pro gives us local control and unsurpassed Pico support. Plus there are community integrations to hubs like Insteon, Ring, and even HE > HA. But we’re still missing a piece to the puzzle that could be as easy to implement as the other integrations. We NEED HomeKit Controller like HA has!
This isn't HomeKit to Homebridge, this is HomeKit devices into Hubitat. It's doable and it would be easy for EVERYONE to use, not just those that decide they're good with running a broker and learning to setup MQTT or Node-Red. Its simplicity would bring even more HE users and it would cover a lot of use cases in one fell swoop. No one would need to have iOS or Mac devices to use it, and I can think of very few devices or hubs that cannot be integrated directly and locally into Hubitat by simply entering an 8 digit code. Even when those hubs and devices don't natively support HomeKit.
Xiaomi fans could bring those inexpensive and nicely designed devices directly into HE, while still maintaining connection stability for around $20 USD by simply adding the Mijia Multimode Gateway that is HomeKit compatible, has support for Zigbee 3.0, Bluetooth mesh and up to 128 end devices. Or the new Aqara M2 or M1S with Zigbee 3.0, Bluetooth mesh, Ethernet and support for up to 128 end devices.
There's no need for a device to be HomeKit native. If it is, great. It's state and parameters would instantly come into HE when added to such an integration, just as they are by using HomeKit Controller for HA. If a hub cannot support HomeKit on its own, but can share its devices with Homebridge or Hoobs, then it could share them with HE too. Just enter the 8 digit code from Homebridge or Hoobs, and all the devices and their states would appear in HE for local control and automation. No need for an Apple hub or device.
Please consider this. I'm here to test, root you on and promote your stable integrations, but as I've stated before, I cannot program my way out of paper bag. We need your help!
It's close to the Apple TV and it was a good price). And that's not ideal either. There are limits. No variable sensor data. No control over bulb dimming or color from HE.
