I made some changes and now it works for me.
* Daikin WiFi Split System Hubitat
* V 1.4.1 - 11/12/2018
* Copyright 2018 Ben Dews - https://bendews.com
* Contribution by RBoy Apps
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
* Changelog:
* 1.0 (06/01/2018) - Initial 1.0 Release. All Temperature, Mode and Fan functions working.
* 1.1 (06/01/2018) - Allow user to change device icon.
* 1.2 (07/01/2018) - Fixed issue preventing user from setting desired temperature, added switch and temperature capabilities
* 1.3 (10/01/2018) - Added support for outside temperature value, 1 minute refresh option (not reccomended) and fixed thermostat and switch state reporting when turned off
* 1.4 (07/06/2018) - Added Fahrenheit support
* 1.4.1 (11/12/2018) - Implemented fix for B-type adapters ('Host' header case) - Big thanks to @WGentine in the SmartThings community
import groovy.transform.Field
@Field final Map DAIKIN_MODES = [
"0": "auto",
"1": "auto",
"2": "dry",
"3": "cool",
"4": "heat",
"6": "fan",
"7": "auto",
"off": "off",
@Field final Map DAIKIN_FAN_RATE = [
"A": "Auto",
"B": "Silence",
"3": "1",
"4": "2",
"5": "3",
"6": "4",
"7": "5"
@Field final Map DAIKIN_FAN_DIRECTION = [
"0": "Off",
"1": "Vertical",
"2": "Horizontal",
"3": "3D"
metadata {
definition (name: "Daikin WiFi Split System Hubitat", namespace: "bendews", author: "contact@bendews.com") {
capability "Thermostat"
capability "Temperature Measurement"
capability "Actuator"
capability "Switch"
capability "Sensor"
capability "Refresh"
capability "Polling"
attribute "outsideTemp", "number"
attribute "targetTemp", "number"
attribute "currMode", "string"
attribute "fanAPISupport", "string"
attribute "fanRate", "string"
attribute "fanDirection", "string"
attribute "statusText", "string"
attribute "connection", "string"
command "fan"
command "dry"
command "tempUp"
command "tempDown"
command "fanRateAuto"
command "fanRateSilence"
command "fanDirectionVertical"
command "fanDirectionHorizontal"
command "setFanRate", ["number"]
command "setTemperature", ["number"]
preferences {
input("ipAddress", "string", title:"Daikin WiFi IP Address", required:true, displayDuringSetup:true)
input("ipPort", "string", title:"Daikin WiFi Port (default: 80)", defaultValue:80, required:true, displayDuringSetup:true)
input("refreshInterval", "enum", title: "Refresh Interval in minutes", defaultValue: "10", required:true, displayDuringSetup:true, options: ["1","5","10","15","30"])
input("displayFahrenheit", "boolean", title: "Display Fahrenheit", defaultValue: false, displayDuringSetup:true)
// Generic Private Functions -------
private getHostAddress() {
def ip = settings.ipAddress
def port = settings.ipPort
return ip + ":" + port
private getDNI(String ipAddress, String port){
log.debug "Generating DNI"
String ipHex = ipAddress.tokenize( '.' ).collect { String.format( '%02X', it.toInteger() ) }.join()
String portHex = String.format( '%04X', port.toInteger() )
String newDNI = ipHex + ":" + portHex
return newDNI
private apiGet(def apiCommand) {
log.debug "Executing hubaction on " + getHostAddress() + apiCommand
sendEvent(name: "hubactionMode", value: "local")
def hubAction = new hubitat.device.HubAction(
method: "GET",
path: apiCommand,
headers: [Host:getHostAddress()]
log.debug hubAction
return hubAction
private roundHalf(Double num){
return ((num * 2).round() / 2)
private convertTemp(Double temp, Boolean isFahrenheit){
log.debug "Converting ${temp}, Fahrenheit: ${isFahrenheit}"
Double convertedTemp
if (isFahrenheit) {
convertedTemp = ((temp - 32) * 5) / 9
return convertedTemp.round()
convertedTemp = ((temp * 9) / 5) + 32
// Daikin Specific Private Functions -------
private parseTemp(Double temp, String method){
log.debug "${method}-ing ${temp}"
if (settings.displayFahrenheit.toBoolean()) {
switch(method) {
case "GET":
return convertTemp(temp, false)
case "SET":
return convertTemp(temp, true)
return temp
private parseDaikinResp(String response) {
// Convert Daikin response to Groovy Map
// Convert to JSON
def parsedResponse = response.replace("=", "\":\"").replace(",", "\",\"")
def jsonString = "{\"${parsedResponse}\"}"
// Parse JSON to Map
def results = new groovy.json.JsonSlurper().parseText(jsonString)
return results
private updateDaikinDevice(Boolean turnOff = false){
// "Power", either 0 or 1
def pow = "?pow=1"
// "Mode", 0, 1, 2, 3, 4, 6 or 7
def mode = "&mode=3"
// "Set Temperature", degrees in Celsius
def sTemp = "&stemp=26"
// "Fan Rate", A, B, 3, 4, 5, 6, or 7
def fRate = "&f_rate=A"
// "Fan Direction", 0, 1, 2, or 3
def fDir = "&f_dir=3"
// Current mode selected in smartthings
// If turning unit off, get current mode of unit instead of desired mode
String modeAttr = turnOff ? "currMode" : "thermostatMode"
def currentMode = device.currentState(modeAttr)?.value
// Convert textual mode (e.g "cool") to Daikin Code (e.g "3")
def currentModeKey = DAIKIN_MODES.find{ it.value == currentMode }?.key
// Current fan rate selected in smartthings
def currentfRate = device.currentState("fanRate")?.value
// Convert textual fan rate (e.g "lvl1") to Daikin Code (e.g "3")
def currentfRateKey = DAIKIN_FAN_RATE.find{ it.value == currentfRate }?.key
// Current fan direction selected in smartthings
def currentfDir = device.currentState("fanDirection")?.value
// Convert textual fan direction (e.g "3d") to Daikin Code (e.g "3")
def currentfDirKey = DAIKIN_FAN_DIRECTION.find{ it.value == currentfDir }?.key
log.debug "wing: ${currentfDirKey}"
// Get target temperature set in Smartthings
def targetTemp = parseTemp(device.currentValue("targetTemp"), "SET")
// Set power mode in HTTP call
if (turnOff) {
pow = "?pow=0"
if (currentModeKey.isNumber()){
// Set desired mode in HTTP call
mode = "&mode=${currentModeKey}"
if (targetTemp){
// Set desired Target Temperature in HTTP call
sTemp = "&stemp=${targetTemp}"
if (currentfRateKey){
// Set desired Fan Rate in HTTP call
fRate = "&f_rate=${currentfRateKey}"
if (currentfDirKey){
// Set desired Fan Direction in HTTP call
fDir = "&f_dir=${currentfDirKey}"
def apiCalls = [
// Send HTTP Call to update device
apiGet("/aircon/set_control_info"+pow+mode+sTemp+fRate+fDir+"&shum=0"),
// Get mode info
runIn(2, 'apiGet', [overwrite: false, data : "/aircon/get_control_info"]),
// Get temperature info
runIn(4, 'apiGet', [overwrite: false, data : "/aircon/get_sensor_info"])
return apiCalls
// Utility Functions -------
private startScheduledRefresh() {
log.debug "startScheduledRefresh()"
// Get minutes from settings
def minutes = settings.refreshInterval?.toInteger()
if (!minutes) {
log.warn "Using default refresh interval: 10"
minutes = 10
log.debug "Scheduling polling task for every '${minutes}' minutes"
if (minutes == 1){
runEvery1Minute(refresh)
} else {
"runEvery${minutes}Minutes"(refresh)
def setDNI(){
log.debug "Setting DNI"
String ip = settings.ipAddress
String port = settings.ipPort
String newDNI = getDNI(ip, port)
device.setDeviceNetworkId("${newDNI}")
def updated() {
log.debug "Updated with settings: ${settings}"
// Prevent function from running twice on save
if (!state.updated || now() >= state.updated + 5000){
// Unschedule existing tasks
unschedule()
// Set DNI
runIn(1, 'setDNI', [overwrite : false])
runIn(5, 'refresh')
// Start scheduled task
state.updated = now()
def poll() {
log.debug "Executing poll(), unscheduling existing"
refresh()
def refresh() {
log.debug "Refreshing"
/*def apiCalls = [
sendHubCommand(apiGet("/aircon/get_sensor_info")),
sendHubCommand(delayAction(500)),
sendHubCommand(apiGet("/aircon/get_control_info"))
//return apiCalls*/
runIn(2, 'apiGet', [data:"/aircon/get_sensor_info"])
runIn(4, 'apiGet', [overwrite : false, data : "/aircon/get_control_info"])
def installed() {
log.debug "installed()"
sendEvent(name:'heatingSetpoint', value: '18', displayed:false)
sendEvent(name:'coolingSetpoint', value: '28', displayed:false)
sendEvent(name:'temperature', value: null, displayed:false)
sendEvent(name:'targetTemp', value: null, displayed:false)
sendEvent(name:'thermostatOperatingState', value:'idle', displayed:false)
sendEvent(name:'outsideTemp', value: null, displayed:false)
sendEvent(name:'currMode', value: null, displayed:false)
sendEvent(name:'thermostatMode', value: null, displayed:false)
sendEvent(name:'thermostatFanMode', value: null, displayed:false)
sendEvent(name:'fanRate', value: null, displayed:false)
sendEvent(name:'fanDirection', value: null, displayed:false)
sendEvent(name:'fanState', value: null, displayed:false)
// Parse and Update functions
// Parse Daikin response
def msg = parseLanMessage(description)
def body = msg.body
def daikinResp = parseDaikinResp(body)
// Debug Response
log.debug "Parsing Response: ${daikinResp}"
// Custom definitions
def events = []
def turnedOff = false
def currMode = null
def modeVal = null
def targetTempVal = null
// Define return field data we are interested in
def devicePower = daikinResp.get("pow", null)
def deviceMode = daikinResp.get("mode", null)
def deviceInsideTempSensor = daikinResp.get("htemp", null)
def deviceOutsideTempSensor = daikinResp.get("otemp", null)
def deviceTargetTemp = daikinResp.get("stemp", null)
def devicefanRate = daikinResp.get("f_rate", null)
def devicefanDirection = daikinResp.get("f_dir", null)
def deviceFanSupport = device.currentValue("fanAPISupport")
// Get power info
if (devicePower){
// log.debug "pow: ${devicePower}"
if (devicePower == "0") {
turnedOff = true
events.add(createEvent(name: "thermostatMode", value: "off"))
// Get mode info
if (deviceMode){
// log.debug "mode: ${deviceMode}"
currMode = DAIKIN_MODES.get(deviceMode.toString())
if (!turnedOff) {
modeVal = currMode
events.add(createEvent(name: "currMode", value: currMode))
// Get inside temperature sensor info
if (deviceInsideTempSensor){
// log.debug "htemp: ${deviceInsideTempSensor}"
String insideTemp = parseTemp(Double.parseDouble(deviceInsideTempSensor), "GET")
events.add(createEvent(name: "temperature", value: insideTemp))
// Get outside temperature sensor info
if (deviceOutsideTempSensor){
// log.debug "otemp: ${deviceOutsideTempSensor}"
String outsideTemp = parseTemp(Double.parseDouble(deviceOutsideTempSensor), "GET")
events.add(createEvent(name: "outsideTemp", value: outsideTemp))
// Get currently set target temperature
if (deviceTargetTemp){
// log.debug "stemp: ${deviceTargetTemp}"
// Value of "M" is for modes that don't support temperature changes, make value null
targetTempVal = deviceTargetTemp.isNumber() ? parseTemp(Double.parseDouble(deviceTargetTemp), "GET") : null
// Get current fan rate
if (devicefanRate){
// log.debug "f_rate: ${devicefanRate}"
events.add(createEvent(name: "fanAPISupport", value: "true", displayed: false))
events.add(createEvent(name: "fanRate", value: DAIKIN_FAN_RATE.get(devicefanRate)))
// Get current fan direction
if (devicefanDirection){
// log.debug "f_dir: ${devicefanDirection}"
events.add(createEvent(name: "fanDirection", value: DAIKIN_FAN_DIRECTION.get(devicefanDirection)))
// If device doesnt support API Fan functions
if (deviceMode && !devicefanRate){
// log.debug "Fan support: False"
events.add(createEvent(name: "fanAPISupport", value: "false", displayed: false))
// Update temperature and mode values if applicable (and all other values based from that)
// Add to start of returned list for faster UI feedback
if (modeVal || targetTempVal){
events.add(0, updateEvents(mode: modeVal, temperature: targetTempVal, updateDevice: false))
return events
private updateEvents(Map args){
log.debug "Executing 'updateEvents' with ${args.mode}, ${args.temperature} and ${args.updateDevice}"
// Get args with default values
def mode = args.get("mode", null)
def temperature = args.get("temperature", null)
def updateDevice = args.get("updateDevice", false)
// Daikin "Off" mode is handled as seperate attribute
// Smarthings thermostat handles "Off" as another mode
// Work around this by defining a "turnOff" boolean and set where appropiate
def events = []
if (!mode){
mode = device.currentValue("thermostatMode")
} else {
events.add(sendEvent(name: "thermostatMode", value: mode))
if (!temperature){
temperature = device.currentValue("targetTemp")
switch(mode) {
case "fan":
events.add(sendEvent(name: "statusText", value: "Fan Mode", displayed: false))
events.add(sendEvent(name: "thermostatOperatingState", value: "fan only", displayed: false))
events.add(sendEvent(name: "targetTemp", value: null))
break
case "dry":
events.add(sendEvent(name: "statusText", value: "Dry Mode", displayed: false))
break
case "heat":
events.add(sendEvent(name: "statusText", value: "Heating to ${temperature}°", displayed: false))
events.add(sendEvent(name: "thermostatOperatingState", value: "heating", displayed: false))
events.add(sendEvent(name: "heatingSetpoint", value: temperature, displayed: false))
events.add(sendEvent(name: "targetTemp", value: temperature))
break
case "cool":
events.add(sendEvent(name: "statusText", value: "Cooling to ${temperature}°", displayed: false))
events.add(sendEvent(name: "thermostatOperatingState", value: "cooling", displayed: false))
events.add(sendEvent(name: "coolingSetpoint", value: temperature, displayed: false))
break
case "auto":
events.add(sendEvent(name: "statusText", value: "Auto Mode: ${temperature}°", displayed: false))
break
case "off":
events.add(sendEvent(name: "statusText", value: "System is off", displayed: false))
events.add(sendEvent(name: "thermostatOperatingState", value: "idle", displayed: false))
turnOff = true
break
if (turnOff){
events.add(sendEvent(name: "switch", value: "off", displayed: false))
} else {
events.add(sendEvent(name: "switch", value: "on", displayed: false))
if (updateDevice){
runIn(1, 'updateDaikinDevice', [ data : turnOff])
// Temperature Functions
def tempUp() {
log.debug "tempUp()"
def step = 0.5
def mode = device.currentValue("thermostatMode")
def targetTemp = device.currentValue("targetTemp")
def value = targetTemp + step
updateEvents(temperature: value, updateDevice: true)
def tempDown() {
log.debug "tempDown()"
def step = 0.5
def value = targetTemp - step
def setThermostatMode(String newMode) {
log.debug "Executing 'setThermostatMode'"
def currMode = device.currentValue("thermostatMode")
if (currMode != newMode){
updateEvents(mode: newMode, updateDevice: true)
def setTemperature(Double value) {
log.debug "Executing 'setTemperature' with ${value}"
def setHeatingSetpoint(Double value) {
log.debug "Executing 'setHeatingSetpoint' with ${value}"
def setCoolingSetpoint(Double value) {
log.debug "Executing 'setCoolingSetpoint' with ${value}"
// Daikin "Modes" ----
def auto(){
log.debug "Executing 'auto'"
updateEvents(mode: "auto", updateDevice: true)
def dry() {
log.debug "Executing 'dry'"
updateEvents(mode: "dry", updateDevice: true)
def cool() {
log.debug "Executing 'cool'"
// Set target temp to previously set Cool temperature
def coolPoint = device.currentValue("coolingSetpoint")
updateEvents(mode: "cool", temperature: coolPoint, updateDevice: true)
def heat() {
log.debug "Executing 'heat'"
// Set target temp to previously set Heat temperature
def heatPoint = device.currentValue("heatingSetpoint")
updateEvents(mode: "heat", temperature: heatPoint, updateDevice: true)
def fan() {
log.debug "Executing 'fan'"
updateEvents(mode: "fan", updateDevice: true)
// Switch Functions ----
def on(){
log.debug "Executing 'on'"
def currMode = device.currentValue("currMode")
updateEvents(mode: currMode, updateDevice: true)
def off() {
log.debug "Executing 'off'"
updateEvents(mode: "off", updateDevice: true)
// Fan Actions ----
private fanAPISupported() {
// Returns boolean based on whether API Fan actions are supported by the model
String deviceFanSupport = device.currentValue("fanAPISupport")
if (deviceFanSupport == "false"){
log.debug "Fan settings not supported on this model"
sendEvent(name: "fanDirection", value: "Not Supported")
return false
} else {
return true
def setFanRate(def fanRate) {
log.debug "Executing 'setFanRate' with ${fanRate}"
def currFanRate = device.currentValue("fanRate")
// Check that rate is different before setting.
// TODO: Clean messy IF statements
if (currFanRate != fanRate){
if (fanAPISupported()){
sendEvent(name: "supportedThermostatFanModes", value: ["auto", "on"], displayed: false) // We don't support circulate at this time
if (fanRate == 0){
sendEvent(name: "fanRate", value: "Auto")
sendEvent(name: "thermostatFanMode", value: "auto", displayed: false)
} else {
sendEvent(name: "fanRate", value: fanRate)
switch (fanRate) {
case "Auto":
break
default: // all other modes indicate fan on
sendEvent(name: "thermostatFanMode", value: "on", displayed: false)
break
runIn(1, 'updateDaikinDevice', [ data : false])
} else {
sendEvent(name: "fanRate", value: "Not Supported")
def fanRateAuto(){
log.debug "Executing 'fanRateAuto'"
setFanRate("Auto")
def fanRateSilence(){
log.debug "Executing 'fanRateSilence'"
setFanRate("Silence")
def toggleFanDirection(String toggleDir){
log.debug "Executing 'toggleFanDirection' with ${toggleDir}"
String currentDir = device.currentValue("fanDirection")
if (currentDir == "Off"){
// If both directions are OFF, set to toggled value
sendEvent(name: "fanDirection", value: toggleDir)
} else if (currentDir == "3D"){
// If both directions are on ("3D"), set to opposite of toggled state
String newDir = toggleDir == "Horizontal" ? "Vertical" : "Horizontal"
sendEvent(name: "fanDirection", value: newDir)
} else if (currentDir != toggleDir) {
// If one direction is on and toggled state is not currently active, turn on both
sendEvent(name: "fanDirection", value: "3D")
} else if (currentDir == toggleDir){
// If toggled state is currently active, turn directional off
sendEvent(name: "fanDirection", value: "Off")
} else {
def fanDirectionHorizontal() {
log.debug "Executing 'fanDirectionHorizontal'"
toggleFanDirection("Horizontal")
def fanDirectionVertical() {
log.debug "Executing 'fanDirectionVertical'"
toggleFanDirection("Vertical")
def fanOn() {
log.debug "Executing 'fanOn'"
fanRateSilence() // Should this be made configurable to allow the user to select the default fan rate?
def fanAuto() {
log.debug "Executing 'fanAuto'"
fanRateAuto()
// TODO: Implement these functions if possible
def fanCirculate() {
log.warn "Executing 'fanCirculate' not currently supported"
// TODO: handle 'fanCirculate' command
def setThermostatFanMode(String value) {
log.debug "Executing 'setThermostatFanMode' with fan mode $value"
switch(value){
case "auto":
fanAuto()
break
case "on":
fanOn()
break
case "circulate":
fanCirculate()
break
default:
log.warn "Unknown fan mode: $value"
break
// def setSchedule() {
// log.debug "Executing 'setSchedule'"
// TODO: handle 'setSchedule' command
