A/C control: Daikin Mobile Controller
That's because the driver is written for SmartThings and doesn't work correctly. It uses an action to delay API calls that isn't allowed on Hubitat. Try this one. I have only confirmed that is saves as I don't have the device. But instead of using the illegal delays it uses runIn.
 *  Daikin WiFi Split System
 *  V 1.4.1 - 11/12/2018
 *  Copyright 2018 Ben Dews - https://bendews.com
 *  Contribution by RBoy Apps
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
 *	Changelog:
 *  1.0     (06/01/2018) - Initial 1.0 Release. All Temperature, Mode and Fan functions working.
 *  1.1     (06/01/2018) - Allow user to change device icon.
 *  1.2     (07/01/2018) - Fixed issue preventing user from setting desired temperature, added switch and temperature capabilities
 *  1.3     (10/01/2018) - Added support for outside temperature value, 1 minute refresh option (not reccomended) and fixed thermostat and switch state reporting when turned off
 *  1.4     (07/06/2018) - Added Fahrenheit support
 *  1.4.1   (11/12/2018) - Implemented fix for B-type adapters ('Host' header case) - Big thanks to @WGentine in the SmartThings community
import groovy.transform.Field
@Field final Map DAIKIN_MODES = [
    "0":    "auto",
    "1":    "auto",
    "2":    "dry",
    "3":    "cool",
    "4":    "heat",
    "6":    "fan",
    "7":    "auto",
    "off": "off",
@Field final Map DAIKIN_FAN_RATE = [
    "A":    "Auto",
    "B":    "Silence",
    "3":    "1",
    "4":    "2",
    "5":    "3",
    "6":    "4",
    "7":    "5"
@Field final Map DAIKIN_FAN_DIRECTION = [
    "0":    "Off",
    "1":    "Vertical",
    "2":    "Horizontal",
    "3":    "3D"
metadata {
    definition (name: "Daikin WiFi Split System", namespace: "bendews", author: "contact@bendews.com") {
        capability "Thermostat"
        capability "Temperature Measurement"
        capability "Actuator"
        capability "Switch"
        capability "Sensor"
        capability "Refresh"
        capability "Polling"
        attribute "outsideTemp", "number"
        attribute "targetTemp", "number"
        attribute "currMode", "string"
        attribute "fanAPISupport", "string"
        attribute "fanRate", "string"
        attribute "fanDirection", "string"
        attribute "statusText", "string"
        attribute "connection", "string"
        command "fan"
        command "dry"
        command "tempUp"
        command "tempDown"
        command "fanRateAuto"
        command "fanRateSilence"
        command "fanDirectionVertical"
        command "fanDirectionHorizontal"
        command "setFanRate", ["number"]
        command "setTemperature", ["number"]
    preferences {
        input("ipAddress", "string", title:"Daikin WiFi IP Address", required:true, displayDuringSetup:true)
        input("ipPort", "string", title:"Daikin WiFi Port (default: 80)", defaultValue:80, required:true, displayDuringSetup:true)
        input("refreshInterval", "enum", title: "Refresh Interval in minutes", defaultValue: "10", required:true, displayDuringSetup:true, options: ["1","5","10","15","30"])
        input("displayFahrenheit", "boolean", title: "Display Fahrenheit", defaultValue: false, displayDuringSetup:true)
    simulator {
        // TODO: define status and reply messages here
    tiles(scale:2) {
        // Main Tile
        multiAttributeTile(name:"thermostatGeneric", type:"generic", width:6, height:4, canChangeIcon: true) {
            tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
                attributeState("temp", label:'${currentValue}°', unit:"dF", defaultState: true, backgroundColors: [
                // Celsius
                [value: 0, color: "#153591"],
                [value: 7, color: "#1e9cbb"],
                [value: 15, color: "#90d2a7"],
                [value: 23, color: "#44b621"],
                [value: 28, color: "#f1d801"],
                [value: 35, color: "#d04e00"],
                [value: 37, color: "#bc2323"],
                // Fahrenheit
				[value: 40, color: "#153591"],
				[value: 44, color: "#1e9cbb"],
				[value: 59, color: "#90d2a7"],
				[value: 74, color: "#44b621"],
				[value: 82, color: "#f1d801"],
				[value: 95, color: "#d04e00"],
				[value: 98, color: "#bc2323"]
            tileAttribute("device.statusText", key: "SECONDARY_CONTROL") {
                attributeState("default", icon: "https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/temp-gauge.png", label:'${currentValue}', defaultState: true)
            tileAttribute("device.targetTemp", key: "SLIDER_CONTROL", range:"(10..40)") {
                attributeState "level", action:"setTemperature", defaultState: true
        // Fan Rate controls
        valueTile("fanRateText", "device.fanRate",width: 3, height: 1) {
            state "val", label:'Fan Rate: ${currentValue}', defaultState: true
        controlTile("fanRateSlider", "device.fanRate", "slider", height: 1, width: 1, range:"(1..5)") {
            state "level", action:"setFanRate"
        standardTile("fanRateAuto", "device.fanRate", width:1, height:1) {
            state "default", label:'Auto', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-auto.png", backgroundColor:"#FFFFFF", action:"fanRateAuto", defaultState:true
            state "Auto", label:'Auto', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-auto.png", backgroundColor:"#00A0DC", action:"fanRateAuto"
        standardTile("fanRateSilence", "device.fanRate", width:1, height:1) {
            state "default", label:'Silence', icon:"st.samsung.da.RAC_ic_silence", backgroundColor:"#FFFFFF", action:"fanRateSilence", defaultState:true
            state "Silence", label:'Silence', icon:"st.samsung.da.RAC_ic_silence", backgroundColor:"#00A0DC", action:"fanRateSilence"
        // Fan Direction controls
        valueTile("fanDirectionText", "device.fanDirection",width: 4, height: 1) {
            state "val", label:'Fan Direction: ${currentValue}', defaultState: true
        standardTile("fanDirectionVertical", "device.fanDirection", width:1, height:1) {
            state "default", label:'Vertical', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-vertical.png", backgroundColor:"#FFFFFF", action:"fanDirectionVertical", defaultState:true
            state "Vertical", label:'Vertical', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-vertical.png", backgroundColor:"#00A0DC", action:"fanDirectionVertical"
            state "3D", label:'Vertical', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-vertical.png", backgroundColor:"#00A0DC", action:"fanDirectionVertical"
        standardTile("fanDirectionHorizontal", "device.fanDirection", width:1, height:1) {
            state "default", label:'Horizontal', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-horizontal.png", backgroundColor:"#FFFFFF", action:"fanDirectionHorizontal", defaultState:true
            state "Horizontal", label:'Horizontal', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-horizontal.png", backgroundColor:"#00A0DC", action:"fanDirectionHorizontal"
            state "3D", label:'Horizontal', icon:"https://cdn.rawgit.com/bendews/smartthings-daikin-wifi/master/icons/fan-horizontal.png", backgroundColor:"#00A0DC", action:"fanDirectionHorizontal"
        // Mode Toggles
        standardTile("modeHeat", "device.thermostatMode", width:2, height:2) {
            state "default", label:'Heat', icon:"st.Weather.weather14", backgroundColor:"#FFFFFF", action:"thermostat.heat", defaultState:true
            state "heat", label:'Heat', icon:"st.Weather.weather14", backgroundColor:"#E86D13", action:"thermostat.off"
        standardTile("modeCool", "device.thermostatMode", width:2, height:2) {
            state "default", label:'Cool', icon:"st.Weather.weather7", backgroundColor:"#FFFFFF", action:"thermostat.cool", defaultState:true
            state "cool", label:'Cool', icon:"st.Weather.weather7", backgroundColor:"#00A0DC", action:"thermostat.off"
        standardTile("modeAuto", "device.thermostatMode", width:2, height:2) {
            state "default", label:'Auto', icon:"st.tesla.tesla-hvac", backgroundColor:"#FFFFFF", action:"thermostat.auto", defaultState:true
            state "auto", label:'Auto', icon:"st.tesla.tesla-hvac", backgroundColor:"#F1D801", action:"thermostat.off"
        standardTile("modeDry", "device.thermostatMode", width:2, height:2) {
            state "default", label:'Dry', icon:"st.Weather.weather12", backgroundColor:"#FFFFFF", action:"dry", defaultState:true
            state "dry", label:'Dry', icon:"st.Weather.weather12", backgroundColor:"#00A0DC", action:"thermostat.off"
        standardTile("modeFan", "device.thermostatMode", width:2, height:2) {
            state "default", label:'Fan', icon:"st.Appliances.appliances11", backgroundColor:"#FFFFFF", action:"fan", defaultState:true
            state "fan", label:'Fan', icon:"st.Appliances.appliances11", backgroundColor:"#00A0DC", action:"thermostat.off"
        // Outside Temp
        valueTile("outsideTemp", "device.outsideTemp", width:2, height:2, inactiveLabel: false) {
            state("val", label:'Outside: ${currentValue}°', backgroundColors:[
                // Celsius
                // Fahrenheit
        // Refresh
        standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width:2, height:2) {
            state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
        main("thermostatGeneric")
        details([
            "fanRateText",
            "fanRateSlider",
            "fanRateAuto",
            "fanRateSilence",
            "fanDirectionText",
            "modeHeat",
            "modeCool",
            "modeAuto",
            "modeFan",
            "modeDry",
            "outsideTemp",
            "refresh"])
// Generic Private Functions -------
private getHostAddress() {
    def ip = settings.ipAddress
    def port = settings.ipPort
    return ip + ":" + port
private getDNI(String ipAddress, String port){
    log.debug "Generating DNI"
    String ipHex = ipAddress.tokenize( '.' ).collect {  String.format( '%02X', it.toInteger() ) }.join()
    String portHex = String.format( '%04X', port.toInteger() )
    String newDNI = ipHex + ":" + portHex
    return newDNI
private apiGet(def apiCommand) {
    log.debug "Executing hubaction on " + getHostAddress() + apiCommand
    sendEvent(name: "hubactionMode", value: "local")
    def hubAction = new hubitat.device.HubAction(
        method: "GET",
        path: apiCommand,
        headers: [Host:getHostAddress()]
    return hubAction
private roundHalf(Double num){
    return ((num * 2).round() / 2)
private convertTemp(Double temp, Boolean isFahrenheit){
    log.debug "Converting ${temp}, Fahrenheit: ${isFahrenheit}"
    Double convertedTemp
    if (isFahrenheit) {
        convertedTemp = ((temp - 32) * 5) / 9
        return convertedTemp.round()
    convertedTemp = ((temp * 9) / 5) + 32
/*private delayAction(long time) {
    log.debug "Delay for '${time}'"
    new physicalgraph.device.HubAction("delay $time")
// Daikin Specific Private Functions -------
private parseTemp(Double temp, String method){
    log.debug "${method}-ing ${temp}"
    if (settings.displayFahrenheit.toBoolean()) {
        switch(method) {
            case "GET":
                return convertTemp(temp, false)
            case "SET":
                return convertTemp(temp, true)
    return temp
private parseDaikinResp(String response) {
    // Convert Daikin response to Groovy Map
    // Convert to JSON
    def parsedResponse = response.replace("=", "\":\"").replace(",", "\",\"")
    def jsonString = "{\"${parsedResponse}\"}"
    // Parse JSON to Map
    def results = new groovy.json.JsonSlurper().parseText(jsonString)
    return results
private updateDaikinDevice(Boolean turnOff = false){
    // "Power", either 0 or 1
    def pow = "?pow=1"
    // "Mode", 0, 1, 2, 3, 4, 6 or 7
    def mode = "&mode=3"
    // "Set Temperature", degrees in Celsius
    def sTemp = "&stemp=26"
    // "Fan Rate", A, B, 3, 4, 5, 6, or 7
    def fRate = "&f_rate=A"
    // "Fan Direction", 0, 1, 2, or 3
    def fDir = "&f_dir=3"
    // Current mode selected in smartthings
    // If turning unit off, get current mode of unit instead of desired mode
    String modeAttr = turnOff ? "currMode" : "thermostatMode"
    def currentMode = device.currentState(modeAttr)?.value
    // Convert textual mode (e.g "cool") to Daikin Code (e.g "3")
    def currentModeKey = DAIKIN_MODES.find{ it.value == currentMode }?.key
    // Current fan rate selected in smartthings
    def currentfRate = device.currentState("fanRate")?.value
    // Convert textual fan rate (e.g "lvl1") to Daikin Code (e.g "3")
    def currentfRateKey = DAIKIN_FAN_RATE.find{ it.value == currentfRate }?.key
    // Current fan direction selected in smartthings
    def currentfDir = device.currentState("fanDirection")?.value
    // Convert textual fan direction (e.g "3d") to Daikin Code (e.g "3")
    def currentfDirKey = DAIKIN_FAN_DIRECTION.find{ it.value == currentfDir }?.key
    log.debug "${currentfDirKey}"
    // Get target temperature set in Smartthings
    def targetTemp = parseTemp(device.currentValue("targetTemp"), "SET")
    // Set power mode in HTTP call
    if (turnOff) {
        pow = "?pow=0"
    if (currentModeKey.isNumber()){
        // Set desired mode in HTTP call
        mode = "&mode=${currentModeKey}"
    if (targetTemp){
        // Set desired Target Temperature in HTTP call
        sTemp = "&stemp=${targetTemp}"
    if (currentfRateKey){
        // Set desired Fan Rate in HTTP call
        fRate = "&f_rate=${currentfRateKey}"
    if (currentfDirKey){
        // Set desired Fan Direction in HTTP call
        fDir = "&f_dir=${currentfDirKey}"
        // Send HTTP Call to update device
    apiGet("/aircon/set_control_info"+pow+mode+sTemp+fRate+fDir+"&shum=0")
        // Get mode info
    runIn(4, apiGet, [data:"/aircon/get_sensor_info"])
    runIn(2, apiGet, [data:"/aircon/get_control_info"])
        //delayAction(500),
        // Get temperature info
    return
// Utility Functions -------
private startScheduledRefresh() {
    log.debug "startScheduledRefresh()"
    // Get minutes from settings
    def minutes = settings.refreshInterval?.toInteger()
    if (!minutes) {
        log.warn "Using default refresh interval: 10"
        minutes = 10
    log.debug "Scheduling polling task for every '${minutes}' minutes"
    if (minutes == 1){
        runEvery1Minute(refresh)
    } else {
        "runEvery${minutes}Minutes"(refresh)
def setDNI(){
    log.debug "Setting DNI"
    String ip = settings.ipAddress
    String port = settings.ipPort
    String newDNI = getDNI(ip, port)
    device.setDeviceNetworkId("${newDNI}")
def updated() {
    log.debug "Updated with settings: ${settings}"
    // Prevent function from running twice on save
    if (!state.updated || now() >= state.updated + 5000){
        // Unschedule existing tasks
        unschedule()
        // Set DNI
        runIn(1, setDNI)
        runIn(5, refresh)
        // Start scheduled task
    state.updated = now()
def poll() {
    log.debug "Executing poll(), unscheduling existing"
    refresh()
def refresh() {
    log.debug "Refreshing"
    apiGet("/aircon/get_sensor_info")
        //sendHubCommand(delayAction(500)),
    return
def installed() {
    log.debug "installed()"
    sendEvent(name:'heatingSetpoint', value: '18', displayed:false)
    sendEvent(name:'coolingSetpoint', value: '28', displayed:false)
    sendEvent(name:'temperature', value: null, displayed:false)
    sendEvent(name:'targetTemp', value: null, displayed:false)
    sendEvent(name:'thermostatOperatingState', value:'idle', displayed:false)
    sendEvent(name:'outsideTemp', value: null, displayed:false)
    sendEvent(name:'currMode', value: null, displayed:false)
    sendEvent(name:'thermostatMode', value: null, displayed:false)
    sendEvent(name:'thermostatFanMode', value: null, displayed:false)
    sendEvent(name:'fanRate', value: null, displayed:false)
    sendEvent(name:'fanDirection', value: null, displayed:false)
    sendEvent(name:'fanState', value: null, displayed:false)
// Parse and Update functions
    // Parse Daikin response
    def msg = parseLanMessage(description)
    def body = msg.body
    def daikinResp = parseDaikinResp(body)
    // Debug Response
    log.debug "Parsing Response: ${daikinResp}"
    // Custom definitions
    def events = []
    def turnedOff = false
    def currMode = null
    def modeVal = null
    def targetTempVal = null
    // Define return field data we are interested in
    def devicePower = daikinResp.get("pow", null)
    def deviceMode = daikinResp.get("mode", null)
    def deviceInsideTempSensor = daikinResp.get("htemp", null)
    def deviceOutsideTempSensor = daikinResp.get("otemp", null)
    def deviceTargetTemp = daikinResp.get("stemp", null)
    def devicefanRate = daikinResp.get("f_rate", null)
    def devicefanDirection = daikinResp.get("f_dir", null)
    def deviceFanSupport = device.currentValue("fanAPISupport")
    //  Get power info
    if (devicePower){
        // log.debug "pow: ${devicePower}"
        if (devicePower == "0") {
            turnedOff = true
            events.add(createEvent(name: "thermostatMode", value: "off"))
    //  Get mode info
    if (deviceMode){
        // log.debug "mode: ${deviceMode}"
        currMode = DAIKIN_MODES.get(deviceMode.toString())
        if (!turnedOff) {
            modeVal = currMode
        events.add(createEvent(name: "currMode", value: currMode))
    //  Get inside temperature sensor info
    if (deviceInsideTempSensor){
        // log.debug "htemp: ${deviceInsideTempSensor}"
        String insideTemp = parseTemp(Double.parseDouble(deviceInsideTempSensor), "GET")
        events.add(createEvent(name: "temperature", value: insideTemp))
    //  Get outside temperature sensor info
    if (deviceOutsideTempSensor){
        // log.debug "otemp: ${deviceOutsideTempSensor}"
        String outsideTemp = parseTemp(Double.parseDouble(deviceOutsideTempSensor), "GET")
        events.add(createEvent(name: "outsideTemp", value: outsideTemp))
    //  Get currently set target temperature
    if (deviceTargetTemp){
        // log.debug "stemp: ${deviceTargetTemp}"
        // Value of "M" is for modes that don't support temperature changes, make value null
        targetTempVal = deviceTargetTemp.isNumber() ? parseTemp(Double.parseDouble(deviceTargetTemp), "GET") : null
    //  Get current fan rate
    if (devicefanRate){
        // log.debug "f_rate: ${devicefanRate}"
        events.add(createEvent(name: "fanAPISupport", value: "true", displayed: false))
        events.add(createEvent(name: "fanRate", value: DAIKIN_FAN_RATE.get(devicefanRate)))
    //  Get current fan direction
    if (devicefanDirection){
        // log.debug "f_dir: ${devicefanDirection}"
        events.add(createEvent(name: "fanDirection", value: DAIKIN_FAN_DIRECTION.get(devicefanDirection)))
    // If device doesnt support API Fan functions
    if (deviceMode && !devicefanRate){
        // log.debug "Fan support: False"
        events.add(createEvent(name: "fanAPISupport", value: "false", displayed: false))
    // Update temperature and mode values if applicable (and all other values based from that)
    // Add to start of returned list for faster UI feedback
    if (modeVal || targetTempVal){
        events.add(0, updateEvents(mode: modeVal, temperature: targetTempVal, updateDevice: false))
    return events
private updateEvents(Map args){
    log.debug "Executing 'updateEvents' with ${args.mode}, ${args.temperature} and ${args.updateDevice}"
    // Get args with default values
    def mode = args.get("mode", null)
    def temperature = args.get("temperature", null)
    def updateDevice = args.get("updateDevice", false)
    // Daikin "Off" mode is handled as seperate attribute
    // Smarthings thermostat handles "Off" as another mode
    // Work around this by defining a "turnOff" boolean and set where appropiate
    def events = []
    if (!mode){
        mode = device.currentValue("thermostatMode")
    } else {
        events.add(sendEvent(name: "thermostatMode", value: mode))
    if (!temperature){
        temperature = device.currentValue("targetTemp")
    switch(mode) {
        case "fan":
            events.add(sendEvent(name: "statusText", value: "Fan Mode", displayed: false))
            events.add(sendEvent(name: "thermostatOperatingState", value: "fan only", displayed: false))
            events.add(sendEvent(name: "targetTemp", value: null))
            break
        case "dry":
            events.add(sendEvent(name: "statusText", value: "Dry Mode", displayed: false))
            break
        case "heat":
            events.add(sendEvent(name: "statusText", value: "Heating to ${temperature}°", displayed: false))
            events.add(sendEvent(name: "thermostatOperatingState", value: "heating", displayed: false))
            events.add(sendEvent(name: "heatingSetpoint", value: temperature, displayed: false))
            events.add(sendEvent(name: "targetTemp", value: temperature))
            break
        case "cool":
            events.add(sendEvent(name: "statusText", value: "Cooling to ${temperature}°", displayed: false))
            events.add(sendEvent(name: "thermostatOperatingState", value: "cooling", displayed: false))
            events.add(sendEvent(name: "coolingSetpoint", value: temperature, displayed: false))
            break
        case "auto":
            events.add(sendEvent(name: "statusText", value: "Auto Mode: ${temperature}°", displayed: false))
            break
        case "off":
            events.add(sendEvent(name: "statusText", value: "System is off", displayed: false))
            events.add(sendEvent(name: "thermostatOperatingState", value: "idle", displayed: false))
            turnOff = true
            break
    if (turnOff){
        events.add(sendEvent(name: "switch", value: "off", displayed: false))
    } else {
        events.add(sendEvent(name: "switch", value: "on", displayed: false))
    if (updateDevice){
        updateDaikinDevice(turnOff)
// Temperature Functions
def tempUp() {
    log.debug "tempUp()"
    def step = 0.5
    def mode = device.currentValue("thermostatMode")
    def targetTemp = device.currentValue("targetTemp")
    def value = targetTemp + step
    updateEvents(temperature: value, updateDevice: true)
def tempDown() {
    log.debug "tempDown()"
    def step = 0.5
    def value = targetTemp - step
def setThermostatMode(String newMode) {
    log.debug "Executing 'setThermostatMode'"
    def currMode = device.currentValue("thermostatMode")
    if (currMode != newMode){
        updateEvents(mode: newMode, updateDevice: true)
def setTemperature(Double value) {
    log.debug "Executing 'setTemperature' with ${value}"
def setHeatingSetpoint(Double value) {
    log.debug "Executing 'setHeatingSetpoint' with ${value}"
def setCoolingSetpoint(Double value) {
    log.debug "Executing 'setCoolingSetpoint' with ${value}"
// Daikin "Modes" ----
def auto(){
    log.debug "Executing 'auto'"
    updateEvents(mode: "auto", updateDevice: true)
def dry() {
    log.debug "Executing 'dry'"
    updateEvents(mode: "dry", updateDevice: true)
def cool() {
    log.debug "Executing 'cool'"
    // Set target temp to previously set Cool temperature
    def coolPoint = device.currentValue("coolingSetpoint")
    updateEvents(mode: "cool", temperature: coolPoint, updateDevice: true)
def heat() {
    log.debug "Executing 'heat'"
    // Set target temp to previously set Heat temperature
    def heatPoint = device.currentValue("heatingSetpoint")
    updateEvents(mode: "heat", temperature: heatPoint, updateDevice: true)
def fan() {
    log.debug "Executing 'fan'"
    updateEvents(mode: "fan", updateDevice: true)
// Switch Functions ----
def on(){
    log.debug "Executing 'on'"
    def currMode = device.currentValue("currMode")
    updateEvents(mode: currMode, updateDevice: true)
def off() {
    log.debug "Executing 'off'"
    updateEvents(mode: "off", updateDevice: true)
// Fan Actions ----
private fanAPISupported() {
    // Returns boolean based on whether API Fan actions are supported by the model
    String deviceFanSupport = device.currentValue("fanAPISupport")
    if (deviceFanSupport == "false"){
        log.debug "Fan settings not supported on this model"
        sendEvent(name: "fanDirection", value: "Not Supported")
        return false
    } else {
        return true
def setFanRate(def fanRate) {
    log.debug "Executing 'setFanRate' with ${fanRate}"
    def currFanRate = device.currentValue("fanRate")
    // Check that rate is different before setting.
    // TODO: Clean messy IF statements
	if (currFanRate != fanRate){
		if (fanAPISupported()){
			sendEvent(name: "supportedThermostatFanModes", value: ["auto", "on"], displayed: false) // We don't support circulate at this time
			if (fanRate == 0){
				sendEvent(name: "fanRate", value: "Auto")
				sendEvent(name: "thermostatFanMode", value: "auto", displayed: false)
			} else {
				sendEvent(name: "fanRate", value: fanRate)
				switch (fanRate) {
					case "Auto":
						break
					default: // all other modes indicate fan on
						sendEvent(name: "thermostatFanMode", value: "on", displayed: false)
						break
			updateDaikinDevice(false)
		} else {
			sendEvent(name: "fanRate", value: "Not Supported")
def fanRateAuto(){
    log.debug "Executing 'fanRateAuto'"
    setFanRate("Auto")
def fanRateSilence(){
    log.debug "Executing 'fanRateSilence'"
    setFanRate("Silence")
def toggleFanDirection(String toggleDir){
    log.debug "Executing 'toggleFanDirection' with ${toggleDir}"
    String currentDir = device.currentValue("fanDirection")
    if (currentDir == "Off"){
        // If both directions are OFF, set to toggled value
        sendEvent(name: "fanDirection", value: toggleDir)
    } else if (currentDir == "3D"){
        // If both directions are on ("3D"), set to opposite of toggled state
        String newDir = toggleDir == "Horizontal" ? "Vertical" : "Horizontal"
        sendEvent(name: "fanDirection", value: newDir)
    } else if (currentDir != toggleDir) {
        // If one direction is on and toggled state is not currently active, turn on both
        sendEvent(name: "fanDirection", value: "3D")
    } else if (currentDir == toggleDir){
        // If toggled state is currently active, turn directional off
        sendEvent(name: "fanDirection", value: "Off")
    } else {
def fanDirectionHorizontal() {
    log.debug "Executing 'fanDirectionHorizontal'"
    toggleFanDirection("Horizontal")
def fanDirectionVertical() {
    log.debug "Executing 'fanDirectionVertical'"
    toggleFanDirection("Vertical")
def fanOn() {
    log.debug "Executing 'fanOn'"
    fanRateSilence() // Should this be made configurable to allow the user to select the default fan rate?
def fanAuto() {
    log.debug "Executing 'fanAuto'"
	fanRateAuto()
// TODO: Implement these functions if possible
 def fanCirculate() {
    log.warn "Executing 'fanCirculate' not currently supported"
    // TODO: handle 'fanCirculate' command
 def setThermostatFanMode(String value) {
    log.debug "Executing 'setThermostatFanMode' with fan mode $value"
	switch(value){
		case "auto":
			fanAuto()
			break
		case "on":
			fanOn()
			break
		case "circulate":
			fanCirculate()
			break
		default:
			log.warn "Unknown fan mode: $value"
			break
// def setSchedule() {
    // log.debug "Executing 'setSchedule'"
    // TODO: handle 'setSchedule' command
If there were other fixes necessary, you'll have to do those again as well as I didn't go through the whole thread. That will be up to you.
And the fact that it took me all of 10 minutes to find the problem and write a fix for it yet the problem has been out there for 5 months is a little shocking to me.
thanks @johnwick i tried it but it doesnt work...logs show:
java.lang.IllegalArgumentException: Name cannot be null. on line 439 (refresh)
Try this one. This driver need major overhauling. And since I don't have the device in question I have no way of testing.
 * SOFTWARE.
 *	Changelog:
    "0":    "auto",
    "1":    "auto",
    "2":    "dry",
    "3":    "cool",
    "4":    "heat",
    "6":    "fan",
    "7":    "auto",
    "off": "off",
    "A":    "Auto",
    "B":    "Silence",
    "3":    "1",
    "4":    "2",
    "5":    "3",
    "6":    "4",
    "7":    "5"
    "0":    "Off",
    "1":    "Vertical",
    "2":    "Horizontal",
    "3":    "3D"
metadata {
        capability "Switch"
        capability "Sensor"
        command "fan"
        command "dry"
        command "tempUp"
        command "tempDown"
    preferences {
    simulator {
    tiles(scale:2) {
        // Main Tile
                // Celsius
                // Fahrenheit
        // Mode Toggles
        // Outside Temp
                // Celsius
                // Fahrenheit
        // Refresh
        details([
            "fanRateText",
            "fanRateSlider",
            "fanRateAuto",
            "fanRateSilence",
            "fanDirectionText",
            "modeHeat",
            "modeCool",
            "modeAuto",
            "modeFan",
            "modeDry",
            "outsideTemp",
            "refresh"])
def getHostAddress() {
def getDNI(String ipAddress, String port){
    return newDNI
def apiGet(apiCommand) {
        method: "GET",
        path: apiCommand,
    return hubAction
def roundHalf(Double num){
def convertTemp(Double temp, Boolean isFahrenheit){
    if (isFahrenheit) {
        switch(method) {
            case "GET":
            case "SET":
    return temp
    // Convert to JSON
    return results
    def pow = "?pow=1"
    if (turnOff) {
        pow = "?pow=0"
    if (targetTemp){
        // Get mode info
        //delayAction(500),
    return
    if (!minutes) {
        minutes = 10
    if (minutes == 1){
    } else {
def setDNI(){
def updated() {
        unschedule()
        // Set DNI
        runIn(1, setDNI)
        runIn(5, refresh)
def poll() {
    refresh()
def refresh() {
    return
def installed() {
    def body = msg.body
    // Debug Response
    def events = []
    def currMode = null
    def modeVal = null
    //  Get power info
    if (devicePower){
            turnedOff = true
    //  Get mode info
    if (deviceMode){
        if (!turnedOff) {
            modeVal = currMode
    if (devicefanRate){
    return events
    def events = []
    if (!mode){
    } else {
    if (!temperature){
    switch(mode) {
        case "fan":
            break
        case "dry":
            break
        case "heat":
            break
        case "cool":
            break
        case "auto":
            break
        case "off":
            turnOff = true
            break
    if (turnOff){
    } else {
    if (updateDevice){
def tempUp() {
    def step = 0.5
def tempDown() {
    def step = 0.5
def auto(){
def dry() {
def cool() {
def heat() {
def fan() {
def on(){
def off() {
// Fan Actions ----
        return false
    } else {
        return true
			if (fanRate == 0){
			} else {
				switch (fanRate) {
					case "Auto":
						break
						break
		} else {
def fanRateAuto(){
    setFanRate("Auto")
    } else {
def fanOn() {
def fanAuto() {
	fanRateAuto()
	switch(value){
		case "auto":
			fanAuto()
			break
		case "on":
			fanOn()
			break
		case "circulate":
			fanCirculate()
			break
		default:
			break
I noticed that it is unresponsive now.
Tempup() for example has the same issue as the original driver
Picks up the temp off 22.5°C, Then I get a 0 at 2020-08-11 16:31:48.412, which I can't Identify where it's from. right after it says SET-ing 22.0. So the setting is lost.
Last thing I see is the split hubaction : 192.168.60.45:80/aircon/set_control_info?pow=1&mode=3&stemp=22.0&f_rate=A&f_dir=0&shum=0
The Device does however not respond, and I don't see why just yet
dev:332020-08-11 16:31:51.302 debugExecuting 'updateEvents' with cool, 22.0 and false
dev:332020-08-11 16:31:51.299 debugGET-ing 22.0
dev:332020-08-11 16:31:51.292 debugParsing Response: [ret:OK, pow:1, mode:3, adv:, stemp:22.0, shum:0, dt1:25.0, dt2:M, dt3:22.0, dt4:25.0, dt5:25.0, dt7:25.0, dh1:AUTO, dh2:50, dh3:0, dh4:0, dh5:0, dh7:AUTO, dhh:50, b_mode:3, b_stemp:22.0, b_shum:0, alert:255, f_rate:A, f_dir:0, b_f_rate:A, b_f_dir:0, dfr1:5, dfr2:5, dfr3:A, dfr4:5, dfr5:5, dfr6:5, dfr7:5, dfrh:5, dfd1:0, dfd2:0, dfd3:0, dfd4:0, dfd5:0, dfd6:0, dfd7:0, dfdh:0, dmnd_run:0, en_demand:0]
dev:332020-08-11 16:31:51.121 debugExecuting hubaction on 192.168.60.45:80/aircon/get_control_info
dev:332020-08-11 16:31:49.034 debugExecuting hubaction on 192.168.60.45:80/aircon/get_sensor_info
dev:332020-08-11 16:31:49.031 debugRefreshing
dev:332020-08-11 16:31:48.452 debugExecuting hubaction on 192.168.60.45:80/aircon/set_control_info?pow=1&mode=3&stemp=22.0&f_rate=A&f_dir=0&shum=0
dev:332020-08-11 16:31:48.419 debugSET-ing 22.0
dev:332020-08-11 16:31:48.412 debug0
dev:332020-08-11 16:31:48.352 debugExecuting 'updateEvents' with null, 22.5 and true
dev:332020-08-11 16:31:48.340 debugtempUp()
Sorry, I tried but someone else is going to have to fix it. I recommend not using the driver as illegal actions will clog up your system.
Still, big thanks for trying!
I made some changes and now it works for me. :slight_smile:
 *  Daikin WiFi Split System Hubitat
 * SOFTWARE.
 *	Changelog:
    "0":    "auto",
    "1":    "auto",
    "2":    "dry",
    "3":    "cool",
    "4":    "heat",
    "6":    "fan",
    "7":    "auto",
    "off": "off",
    "A":    "Auto",
    "B":    "Silence",
    "3":    "1",
    "4":    "2",
    "5":    "3",
    "6":    "4",
    "7":    "5"
    "0":    "Off",
    "1":    "Vertical",
    "2":    "Horizontal",
    "3":    "3D"
metadata {
    definition (name: "Daikin WiFi Split System Hubitat", namespace: "bendews", author: "contact@bendews.com") {
        capability "Switch"
        capability "Sensor"
        command "fan"
        command "dry"
        command "tempUp"
        command "tempDown"
    preferences {
    return newDNI
        method: "GET",
        path: apiCommand,
	log.debug hubAction
    return hubAction
    if (isFahrenheit) {
        switch(method) {
            case "GET":
            case "SET":
    return temp
    // Convert to JSON
    return results
    def pow = "?pow=1"
    log.debug "wing: ${currentfDirKey}"
    if (turnOff) {
        pow = "?pow=0"
    if (targetTemp){
    def apiCalls = [
        apiGet("/aircon/set_control_info"+pow+mode+sTemp+fRate+fDir+"&shum=0"),
        // Get mode info
	runIn(2, 'apiGet', [overwrite: false, data : "/aircon/get_control_info"]),
	runIn(4, 'apiGet', [overwrite: false, data : "/aircon/get_sensor_info"])
    return apiCalls
    if (!minutes) {
        minutes = 10
    if (minutes == 1){
    } else {
def setDNI(){
def updated() {
        unschedule()
        // Set DNI
	    runIn(1, 'setDNI',  [overwrite : false])
        runIn(5, 'refresh')
def poll() {
    refresh()
def refresh() {
    /*def apiCalls = [
        sendHubCommand(apiGet("/aircon/get_sensor_info")),
        sendHubCommand(apiGet("/aircon/get_control_info"))
    //return apiCalls*/
	runIn(2, 'apiGet', [data:"/aircon/get_sensor_info"])
        runIn(4, 'apiGet', [overwrite : false, data : "/aircon/get_control_info"])
def installed() {
    def body = msg.body
    // Debug Response
    def events = []
    def currMode = null
    def modeVal = null
    //  Get power info
    if (devicePower){
            turnedOff = true
    //  Get mode info
    if (deviceMode){
        if (!turnedOff) {
            modeVal = currMode
    if (devicefanRate){
    return events
    def events = []
    if (!mode){
    } else {
    if (!temperature){
    switch(mode) {
        case "fan":
            break
        case "dry":
            break
        case "heat":
            break
        case "cool":
            break
        case "auto":
            break
        case "off":
            turnOff = true
            break
    if (turnOff){
    } else {
    if (updateDevice){
	runIn(1, 'updateDaikinDevice', [ data : turnOff])
def tempUp() {
    def step = 0.5
def tempDown() {
    def step = 0.5
def auto(){
def dry() {
def cool() {
def heat() {
def fan() {
def on(){
def off() {
// Fan Actions ----
        return false
    } else {
        return true
			if (fanRate == 0){
			} else {
				switch (fanRate) {
					case "Auto":
						break
						break
			runIn(1, 'updateDaikinDevice', [ data : false])
		} else {
def fanRateAuto(){
    setFanRate("Auto")
    } else {
def fanOn() {
def fanAuto() {
	fanRateAuto()
	switch(value){
		case "auto":
			fanAuto()
			break
		case "on":
			fanOn()
			break
		case "circulate":
			fanCirculate()
			break
		default:
			break
Tsaaek,
That seems to be working a lot smoother than before!
I'll be using that :smile:
What exactly did you change?
Thanks!
I added a runIn-delay for "updateDaikinDevice". I think that the code ran before Hubitat had time to update all the attributes, so it fetched the old ones and sent it to the heatpump.
But I tried a lot of things before i got it working, so there might be other changes, I honestly don't know. But I am pretty sure it was the delay that solved it.
I'm pretty sure that's the case.
I searched on it myself and that seemed the only logical explanation.
I however did NOT find the way to fix it.
Thanks!
Working like a charm.
The only errors encountered are with 2 older units that don't support the fan actions hubitat is sending them. In other words, working as intended.
I can't express my thanks enough! I owe you one!
Glad it works! :slight_smile:
Working for me as well.
Any idea, though, why can't I add it to Google home? It just says device is unsupported, but when I used the same drivers on ST it used to work on GH.
Thank you!
Hi all, I’m looking to get new split systems installed. Is the daikin wifi my best bet for HE integration? (Apart from the Sensibo/IR route)
With tsaaeks tweaks, it is.
I've looked into other methods, but found no useable ones so far.
Having them in there would be awesome, I didn't think it possible to be honest.
That means making the driver compatible with the hubitat google home integration, right?
I have a Daikin Airbase BRP15B61 connected to a zone system.
Initially the driver would not work, but once I replaced all references to /aircon/ with /skyfi/aircon/ it seems to function well. There is no zone control, but it is a good start!
As stated, it doesn't work automatically with the driver. However, @mbudnek created a kickass integration that will make this possible. Add a device type thermostat as thermostat to google. Check it out! [Alpha] Community-maintained Google Home integration
zone control could be achieved by giving the possibility to link more than one device to one thermostat template. that'd be awesome.
I am in the process of migrating from Smartthings to HE. I have gotten this driver to work, thank you very much. My question is this device will not connect to google home. It worked fine with smartthings. Any ideas on how to get this to connect to google home for voice control?
