Hi....i think the problem you are having is because Dale, like many devs in ST, is using a hybrid method that allows you to merge the child and parent apps into one "hybrid" app. You will need to split the app into 2 separate apps for it to work in HE.
This app works great as designed. Now that summer is here however, and the app is really kicking in, it turns the fans on whether you want it or not. How can I mod it to only run when the fan has been turned using another means like a switch or app. i.e. don't turn the fan on/off only control the speed.
Any one fix this to work?
[dcoffing/KOF-CeilingFan/blob/master/smartapps/dcoffing/4-speed-ceiling-fan-thermostat-zigbee.src/4-speed-ceiling-fan-thermostat-zigbee.groovy ]
First time posting and thought I was tagging @dcoffing on the other thread. SO is there a way to make this one you modified for 4 speed?
Quoting a tag like you did in the other thread does not also tag the person again. How you did it in the post above is the correct way. A quote only alerts the person you are quoting directly. A tag (@username) alerts that person directly. I'm not sure how active Dale is in the forums these days so hopefully he chimes in to assist.
Funny, I forgot that I helped someone with this app so far back. At that time Dale was not a part of the Hubitat community. My assistance above was merely a structural fix that allowed that app to work with HE. I have no idea how anything else works within it. I also no longer use HE and hang around primarily to support my non-deprecated apps and drivers....so I would be unable to correct and test the 4 speed app you linked to above.
Cross your fingers that someone else has already done this or that Dale sees your tag above and helps out.
Stephan
Joe,
I took a stab at making the same tweaks @stephack made for the 3-speed to the 4-speed version. I haven't tested it, but it does at least load on the hub and you can create a child app without throwing errors.
At this point, I am not sure I can be much more help. I hope this gets you what you need!
Here is the Parent code
// ZigBee 4 Speed Ceiling Fan Thermostat Control
def version() {return "v0.1b.20170609" }
/* Change Log
2017-06-09 removed the delay line for LOW speed start until ST platform issues are resolved
2017-06-01 removed singleInstance since we don't use a Service Manager, move Version Info, User Guide to Parent screen
2017-05-04 fixed user manual title to 4Speed, icons moved to KOF repo, user manual content revised
bugfix, even though published and I load this from MyApps it still is using the older version code from zwave parent/child
2017-04-27 starting modifications for zigbee
2017-04-11 Added 10.0 selection for Fan Differential Temp to mimic single speed control
2016-10-19 Ver2 Parent / Child app to allow for multiple use cases with a single install - @ericvitale
definition(
name: "4 Speed Ceiling Fan Thermostat - ZigBee - Parent",
namespace: "dcoffing",
author: "Dale Coffing",
description: "Thermostat control for ZigBee 4 Speed Ceiling Fan device (Home Decorators Ceiling Fan/Light Controller MR101Z) staging each speeds with any temperature sensor.",
category: "My Apps",
iconUrl: "https://cdn.rawgit.com/dcoffing/KOF-CeilingFan/master/resources/images/3scft125x125.png",
iconX2Url: "https://cdn.rawgit.com/dcoffing/KOF-CeilingFan/master/resources/images/3scft250x250.png",
iconX3Url: "https://cdn.rawgit.com/dcoffing/KOF-CeilingFan/master/resources/images/3scft250x250.png",
preferences {
page(name: "parentPage")
page(name: "aboutPage")
def parentPage() {
return dynamicPage(name: "parentPage", title: "", nextPage: "", install: true, uninstall: true) {
section("Create a new fan automation.") {
app(name: "childApps", appName: "4 Speed Ceiling Fan Thermostat - ZigBee", namespace: "dcoffing", title: "New ZigBee Ceiling Fan Automation", multiple: true)
section("Version Info, User's Guide") {
href (name: "aboutPage",
title: "4 Speed Ceiling Fan Thermostat \n"+ version() +" \n"+"Copyright Ā© 2017 Dale Coffing",
description: "Tap for SmartApp info & User's Guide",
image: "https://cdn.rawgit.com/dcoffing/KOF-CeilingFan/master/resources/images/3scft125x125.png",
required: false,
page: "aboutPage"
def aboutPage() {
dynamicPage(name: "aboutPage", title: none, install: true, uninstall: true) {
section("User's Guide; 4 Speed Ceiling Fan Thermostat - ZigBee") {
paragraph textHelp()
def installed() {
initialize()
def initialize() {
log.debug "Parent Initialized"
def initParent() {
private def textHelp() {
def text =
"This smartapp provides automatic control of 4 speeds on a"+
" ZigBee ceiling fan using any temperature sensor based on its' temperature setpoint"+
" turning on each speed automatically in 1 degree differential increments."+
" For example, if the desired room temperature setpoint is 72, speed 1 (low)"+
" turns on at 73, then speed 2 (medium) at 74, then speed 3 (med-high) at 75, then"+
" speed 4 (high) at 76. And vice versa on decreasing temperature until at 72 the ceiling"+
" fan turns off. The differential is adjustable from 0.5 to 2.0 in half degree increments. \n\n" +
"A notable feature is when low speed is initially requested from"+
" the off condition, high speed is turned on briefly to overcome the startup load"+
" then low speed is engaged. This mimics the pull chain switches that most"+
" manufacturers use by always starting in high speed. \n\n"+
"A motion option turns off automatic mode when no motion is detected. A thermostat"+
" mode option will disable the smartapp and pass control to manual control.\n\n"+
"This app written specifically for the 'KOF ZigBee Fan Controller Custom Device Handler' used"+
" in the Hampton Bay Wink Ceiling Fan MR101Z receiver in the Gardinier 52' Ceiling Fan or"+
" Universal Ceiling Fan Premier Remote from Home Depot."
and here is the Child code
/* Change Log
definition(
name: "4 Speed Ceiling Fan Thermostat - ZigBee",
parent: "dcoffing:4 Speed Ceiling Fan Thermostat - ZigBee - Parent",
singleInstance: false,
preferences {
page(name: "childStartPage")
page(name: "optionsPage")
def childStartPage() {
dynamicPage(name: "childStartPage", title: "Select your devices and settings", install: true, uninstall: true) {
section("Select a room temperature sensor to control the fan..."){
input "tempSensor", "capability.temperatureMeasurement", multiple:false, title: "Temperature Sensor", required: true, submitOnChange: true
if (tempSensor) { //protects from a null error
section("Enter the desired room temperature setpoint...\n" + "NOTE: ${tempSensor.displayName} room temp is ${tempSensor.currentTemperature}Ā° currently"){
input "setpoint", "decimal", title: "Room Setpoint Temp", defaultValue: tempSensor.currentTemperature, required: true
else
section("Enter the desired room temperature setpoint..."){
input "setpoint", "decimal", title: "Room Setpoint Temp", required: true
section("Select the Parent ceiling fan/light control hardware... (NOT the Light or Fan Speed Child )"){
// fanDimmer
input "fanSwitch", "capability.switch", multiple:false, title: "ZigBee Fan Control device", required: true
section("Optional Settings (Diff Temp, Timers, Motion, etc)") {
href (name: "optionsPage",
title: "Configure Optional settings",
description: none,
image: "https://cdn.rawgit.com/dcoffing/KOF-CeilingFan/master/resources/images/settings250x250.png",
required: false,
page: "optionsPage"
section("Name") {
label(title: "Assign a name", required: false)
/* section("Version Info, User's Guide") {
// VERSION
description: "Tap to get user's guide.",
required: false,
page: "aboutPage"
def optionsPage() {
dynamicPage(name: "optionsPage", title: "Configure Optional Settings", install: false, uninstall: false) {
section("Enter the desired differential temp between fan speeds (default=1.0)..."){
input "fanDiffTempString", "enum", title: "Fan Differential Temp", options: ["0.5","1.0","1.5","2.0","10.0"], required: false
section("Enable ceiling fan thermostat only if motion is detected at (optional, leave blank to not require motion)..."){
input "motionSensor", "capability.motionSensor", title: "Select Motion device", required: false, submitOnChange: true
if (motionSensor) {
section("Turn off ceiling fan thermostat when there's been no motion detected for..."){
input "minutesNoMotion", "number", title: "Minutes?", required: true
section("Select ceiling fan operating mode desired (default to 'YES-Auto'..."){
input "autoMode", "enum", title: "Enable Ceiling Fan Thermostat?", options: ["NO-Manual","YES-Auto"], required: false
section ("Change SmartApp name, Mode selector") {
mode title: "Set for specific mode(s)", required: false
def aboutPage() {
def installed() {
log.debug "def INSTALLED with settings: ${settings}"
initialize()
def updated() {
log.debug "def UPDATED with settings: ${settings}"
unsubscribe()
initialize()
handleTemperature(tempSensor.currentTemperature) //call handleTemperature to bypass temperatureHandler method
def initialize() {
log.debug "def INITIALIZE with settings: ${settings}"
subscribe(tempSensor, "temperature", temperatureHandler) //call temperatureHandler method when any reported change to "temperature" attribute
if (motionSensor) {
subscribe(motionSensor, "motion", motionHandler) //call the motionHandler method when there is any reported change to the "motion" attribute
//Event Handler Methods
def temperatureHandler(evt) {
log.debug "temperatureHandler called: $evt"
handleTemperature(evt.doubleValue)
log.debug "temperatureHandler evt.doubleValue : $evt"
def handleTemperature(temp) { //
log.debug "handleTemperature called: $evt"
def isActive = hasBeenRecentMotion()
if (isActive) {
//motion detected recently
tempCheck(temp, setpoint)
log.debug "handleTemperature ISACTIVE($isActive)"
else {
fanSwitch.off()
def motionHandler(evt) {
if (evt.value == "active") {
//motion detected
def lastTemp = tempSensor.currentTemperature
log.debug "motionHandler ACTIVE($isActive)"
if (lastTemp != null) {
tempCheck(lastTemp, setpoint)
} else if (evt.value == "inactive") { //testing to see if evt.value is indeed equal to "inactive" (vs evt.value to "active")
//motion stopped
def isActive = hasBeenRecentMotion() //define isActive local variable to returned true or false
log.debug "motionHandler INACTIVE($isActive)"
if (isActive) {
if (lastTemp != null) { //lastTemp not equal to null (value never been set)
else {
fanSwitch.off()
private tempCheck(currentTemp, desiredTemp)
log.debug "TEMPCHECK#1(CT=$currentTemp,SP=$desiredTemp,FS=$fanSwitch.currentSwitch,automode=$autoMode,FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
//convert Fan Diff Temp input enum string to number value and if user doesn't select a Fan Diff Temp default to 1.0
def fanDiffTempValue = (settings.fanDiffTempString != null && settings.fanDiffTempString != "") ? Double.parseDouble(settings.fanDiffTempString): 1.0
//if user doesn't select autoMode then default to "YES-Auto"
def autoModeValue = (settings.autoMode != null && settings.autoMode != "") ? settings.autoMode : "YES-Auto"
def LowDiff = fanDiffTempValue*1
def MedDiff = fanDiffTempValue*2
def MedHighDiff = fanDiffTempValue*3
def HighDiff = fanDiffTempValue*4
log.debug "TEMPCHECK#2(CT=$currentTemp,SP=$desiredTemp,FS=$fanSwitch.currentSwitch, automode=$autoMode,FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
if (autoModeValue == "YES-Auto") {
switch (currentTemp - desiredTemp) {
case { it >= HighDiff }:
// turn on fan HIGH speed4
fanSwitch.setSpeed(4)
log.debug "HI speed(CT=$currentTemp, SP=$desiredTemp, FS=$fanSwitch.currentSwitch, Speed=$currentsetFanSpeed, HighDiff=$HighDiff)"
break
case { it >= MedHighDiff }:
// turn on fan MED-HIGH speed3
fanSwitch.setSpeed(3)
break
case { it >= MedDiff }:
// turn on fan MEDIUM speed2
fanSwitch.setSpeed(2)
log.debug "MED speed(CT=$currentTemp, SP=$desiredTemp, FS=$fanSwitch.currentSwitch, MedDiff=$MedDiff)"
break
case { it >= LowDiff }:
// turn on fan LOW speed1
if (fanSwitch.currentSwitch == "off") { // if fan is OFF to make it easier on motor by
// fanSwitch.setSpeed(4) // starting fan in High speed temporarily then
// fanSwitch.setSpeed(1, [delay: 500]) // change to Low speed after 1/2 second
fanSwitch.setSpeed(1) // took out Hi speed start delay until ST platform issues are resolved causing HI speed stuck on
log.debug "LO speed after HI 3secs(CT=$currentTemp, SP=$desiredTemp, FS=$fanSwitch.currentSwitch, LowDiff=$LowDiff)"
} else {
fanSwitch.setSpeed(1) //fan is already running, not necessary to protect motor
} //set Low speed immediately
log.debug "LO speed immediately(CT=$currentTemp, SP=$desiredTemp, FS=$fanSwitch.currentSwitch, LowDiff=$LowDiff)"
break
default:
// check to see if fan should be turned off
if (desiredTemp - currentTemp >= 0 ) { //below or equal to setpoint, turn off fan, zero level
fanSwitch.off()
log.debug "below SP+Diff=fan OFF (CT=$currentTemp, SP=$desiredTemp, FS=$fanSwitch.currentSwitch, autoMode=$autoMode,)"
log.debug "autoMode YES-MANUAL? else OFF(CT=$currentTemp, SP=$desiredTemp, FS=$fanSwitch.currentSwitch, autoMode=$autoMode,)"
private hasBeenRecentMotion()
def isActive = false
if (motionSensor && minutes) {
def deltaMinutes = minutes as Long
if (deltaMinutes) {
def motionEvents = motionSensor.eventsSince(new Date(now() - (60000 * deltaMinutes)))
log.trace "Found ${motionEvents?.size() ?: 0} events in the last $deltaMinutes minutes"
if (motionEvents.find { it.value == "active" }) {
isActive = true
else {
isActive = true
isActive
def text =
Sweet! Iāll check it out. Thanks!
Dan the man!
Awesome! it works, however the fan control device is not needed and doesn't show the fan in the drop down. the Zigbee fan control device does. I tried to modify the app without success.
Yep, that may have been a cut and paste error... I have removed it above.
Same result I got. It doesn't show in the app list, however it does show in use by on device page. Also I can only add one, when I try to add another it shows the previous settings.
I'm sure it's a simple menu option change. I'm not familiar with how to change it.
Sorry. Iāve been pretty busy and havenāt had time to look at it.
I get it. Iāve been fiddling around with it. If you do get to it please let me know what the change is. Thanks for your time.
Joe,
I have tweaked the Parent Code in my post above and I believe it might be working now. Please give it a try. I created a virtual Hampton Bay Fan Controller device on my development hub and I was able to select the Parent device for the Fan. Also, you can now properly click Done after adding a child.
Close. It now saves and shows up in the apps list now. But it won't let me create any more. When I try to create another it shows the previous child and only edits it.
@joe-hennessy - OK, I figured out why it only allowed one child. I have fixed that in the child app code posted above.
Please give it one more try.
That did it. All your time and work is very much appreciated.
Is there a resource for learning how to write HE codes?
The SmartThings Classic Groovy Documentation is a good programmerās resource for the overall architecture. The Hubitat Public GitHub depository has some example code. Hubitatās documentation is valuable, especially highlighting the diffs between ST and Hubitat.
