Child:
Edit: forgot to edit the initialize() method...updated below
Virtual Thermostat for 3 Speed Ceiling Fan Control
Copyright 2016 SmartThings, Dale Coffing
This smartapp provides automatic control of Low, Medium, High speeds of a ceiling fan using
any temperature sensor with optional motion override.
It requires two hardware devices; any temperature sensor and a dimmer type smart fan controller
such as the GE 12730 or Leviton VRF01-1LX. Incorporates contributions from:
Eric Vitale (https://github.com/ericvitale/SmartThingsPublic/blob/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3-speed-ceiling-fan-thermostat.groovy)
Change Log
2017-04-11 Added 10.0 selection for Fan Differential Temp to mimic single speed control
2016-10-19 Ver2 Parent / Child app to allow for multiple use cases with a single install - @ericvitale
2016-06-30 added dynamic temperature display on temperature setpoint input text
2016-06-28 x.1 version update
added submitOnChange for motion so to skip minutes input next if no motion selected
changed order of inputs for better logic flow
added separate input page for Configuring Settings to reduce clutter on required inputs
change to other mode techinque to see if it will force a reevaluate of methods
renamed fanHiSpeed to fanSpeed for more generic use, added 0.0 on timer selection
changed motion detector minutes input only if motion selected submitOnChange
2016-06-03 modified the 3 second startup to 1 for low speed
2016-5-30 added dynamicPages for user guide, combined version data with aboutPage parameters which
gives a larger icon image then if used alone in paragraph mode.
2016-5-19 code clean up only
2016-5-17 fanDiffTemp input changed to use enum with preselected values to overcome range:"0.1..2.0" bug
2016-5-16 fixed typo with motion to motionSensor in hasBeenRecentMotion()
fixed IDE integration with ST by making another change to file name specifics.
2016-5-15 fixed fan differenial decimal point error by removing range: "1..99", removed all fanDimmer.setLevel(0)
added iconX3Url, reworded preferences, rename evaluate to tempCheck for clarity,
best practices to utilize initialize() method & replace motion with motionSensor,
2016-5-14 Fan temperature differential variable added, best practices to change sensor to tempSensor,
2016-5-13 best practices to replace ELSE IF for SWITCH statements on fan speeds, removed emergency temp control
2016-5-12 added new icons for 3SFC, colored text in 3SFC125x125.png and 3sfc250x250.png
2016-5-6 (e)minor changes to text, labels, for clarity, (^^^e)default to NO-Manual for thermostat mode
2016-5-5c clean code, added current ver section header, allow for multiple fan controllers,
replace icons to ceiling fan, modify name from Control to Thermostat
2016-5-5b @krlaframboise change to bypasses the temperatureHandler method and calls the tempCheck method
with the current temperature and setpoint setting
2016-5-5 autoMode added for manual override of auto control/*
2016-5-4b cleaned debug logs, removed heat-cool selection, removed multiple stages
2016-5-3 fixed error on not shutting down, huge shout out to my bro Stephen Coffing in the logic formation
I modified the SmartThngs original Virtual Thermostat code which is buggy. Known issues
-[Fixed] when SP is updated, temp control isn't evaluated immediately, an event must trigger like change in temp, motion
- if load is previously running when smartapp is loaded, it isn't evaluated immediately to turn off when SetPt>CurrTemp
- temperature control is not evaluated when making a mode change, have to wait for something to change like temp
Thanks to @krlaframboise, @MikeMaxwell for help in solving issues for a first time coder. @MichaelS for icon background
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
in compliance with the License. You may obtain a copy of the License at: www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
definition(
name: "3 Speed Ceiling Fan Thermostat",
namespace: "dcoffing",
author: "Dale Coffing",
description: "Automatic control for 3 Speed Ceiling Fan using Low, Medium, High speeds with any temperature sensor.",
category: "My Apps",
parent: "dcoffing:3 Speed Ceiling Fan Thermostat - Parent",
singleInstance: true,
iconUrl: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft125x125.png",
iconX2Url: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft250x250.png",
iconX3Url: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft250x250.png",
preferences {
page(name: "childStartPage")
page(name: "optionsPage")
page(name: "aboutPage")
def childStartPage() {
dynamicPage(name: "childStartPage", title: "Select your devices and settings", install: true, uninstall: true) {
section("Select a room temperature sensor to control the fan..."){
input "tempSensor", "capability.temperatureMeasurement", multiple:false, title: "Temperature Sensor", required: true, submitOnChange: true
if (tempSensor) { //protects from a null error
section("Enter the desired room temperature setpoint...\n" + "NOTE: ${tempSensor.displayName} room temp is ${tempSensor.currentTemperature}° currently"){
input "setpoint", "decimal", title: "Room Setpoint Temp", defaultValue: tempSensor.currentTemperature, required: true
else
section("Enter the desired room temperature setpoint..."){
input "setpoint", "decimal", title: "Room Setpoint Temp", required: true
section("Select the ceiling fan control hardware..."){
input "fanDimmer", "capability.switchLevel",
multiple:false, title: "Fan Control device", required: true
section("Optional Settings (Diff Temp, Timers, Motion, etc)") {
href (name: "optionsPage",
title: "Configure Optional settings",
description: none,
image: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/evap-cooler-thermostat.src/settings250x250.png",
required: false,
page: "optionsPage"
section("Name") {
label(title: "Assign a name", required: false)
section("Version Info, User's Guide") {
// VERSION
href (name: "aboutPage",
title: "3 Speed Ceiling Fan Thermostat \n"+"Version:2.170411 \n"+"Copyright © 2016 Dale Coffing",
description: "Tap to get user's guide.",
image: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft125x125.png",
required: false,
page: "aboutPage"
def optionsPage() {
dynamicPage(name: "optionsPage", title: "Configure Optional Settings", install: false, uninstall: false) {
section("Enter the desired differential temp between fan speeds (default=1.0)..."){
input "fanDiffTempString", "enum", title: "Fan Differential Temp", options: ["0.5","1.0","1.5","2.0","10.0"], required: false
section("Enable ceiling fan thermostat only if motion is detected at (optional, leave blank to not require motion)..."){
input "motionSensor", "capability.motionSensor", title: "Select Motion device", required: false, submitOnChange: true
if (motionSensor) {
section("Turn off ceiling fan thermostat when there's been no motion detected for..."){
input "minutesNoMotion", "number", title: "Minutes?", required: true
section("Select ceiling fan operating mode desired (default to 'YES-Auto'..."){
input "autoMode", "enum", title: "Enable Ceiling Fan Thermostat?", options: ["NO-Manual","YES-Auto"], required: false
section ("Change SmartApp name, Mode selector") {
mode title: "Set for specific mode(s)", required: false
def aboutPage() {
dynamicPage(name: "aboutPage", title: none, install: true, uninstall: true) {
section("User's Guide; 3 Speed Ceiling Fan Thermostat") {
paragraph textHelp()
private def appName() { return "${parent ? "3 Speed Fan Automation" : "3 Speed Ceiling Fan Thermostat"}" }
def installed() {
log.debug "def INSTALLED with settings: ${settings}"
initialize()
def updated() {
log.debug "def UPDATED with settings: ${settings}"
unsubscribe()
initialize()
handleTemperature(tempSensor.currentTemperature) //call handleTemperature to bypass temperatureHandler method
def initialize() {
log.debug "def INITIALIZE with settings: ${settings}"
subscribe(tempSensor, "temperature", temperatureHandler) //call temperatureHandler method when any reported change to "temperature" attribute
if (motionSensor) {
subscribe(motionSensor, "motion", motionHandler) //call the motionHandler method when there is any reported change to the "motion" attribute
//Event Handler Methods
def temperatureHandler(evt) {
log.debug "temperatureHandler called: $evt"
handleTemperature(evt.doubleValue)
log.debug "temperatureHandler evt.doubleValue : $evt"
def handleTemperature(temp) { //
log.debug "handleTemperature called: $evt"
def isActive = hasBeenRecentMotion()
if (isActive) {
//motion detected recently
tempCheck(temp, setpoint)
log.debug "handleTemperature ISACTIVE($isActive)"
else {
fanDimmer.off()
def motionHandler(evt) {
if (evt.value == "active") {
//motion detected
def lastTemp = tempSensor.currentTemperature
log.debug "motionHandler ACTIVE($isActive)"
if (lastTemp != null) {
tempCheck(lastTemp, setpoint)
} else if (evt.value == "inactive") { //testing to see if evt.value is indeed equal to "inactive" (vs evt.value to "active")
//motion stopped
def isActive = hasBeenRecentMotion() //define isActive local variable to returned true or false
log.debug "motionHandler INACTIVE($isActive)"
if (isActive) {
if (lastTemp != null) { //lastTemp not equal to null (value never been set)
else {
fanDimmer.off()
private tempCheck(currentTemp, desiredTemp)
log.debug "TEMPCHECK#1(CT=$currentTemp,SP=$desiredTemp,FD=$fanDimmer.currentSwitch,FD_LVL=$fanDimmer.currentLevel, automode=$autoMode,FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
//convert Fan Diff Temp input enum string to number value and if user doesn't select a Fan Diff Temp default to 1.0
def fanDiffTempValue = (settings.fanDiffTempString != null && settings.fanDiffTempString != "") ? Double.parseDouble(settings.fanDiffTempString): 1.0
//if user doesn't select autoMode then default to "YES-Auto"
def autoModeValue = (settings.autoMode != null && settings.autoMode != "") ? settings.autoMode : "YES-Auto"
def LowDiff = fanDiffTempValue*1
def MedDiff = fanDiffTempValue*2
def HighDiff = fanDiffTempValue*3
log.debug "TEMPCHECK#2(CT=$currentTemp,SP=$desiredTemp,FD=$fanDimmer.currentSwitch,FD_LVL=$fanDimmer.currentLevel, automode=$autoMode,FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
if (autoModeValue == "YES-Auto") {
switch (currentTemp - desiredTemp) {
case { it >= HighDiff }:
// turn on fan high speed
fanDimmer.setLevel(90)
log.debug "HI speed(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, HighDiff=$HighDiff)"
break //exit switch statement
case { it >= MedDiff }:
// turn on fan medium speed
fanDimmer.setLevel(60)
log.debug "MED speed(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, MedDiff=$MedDiff)"
break
case { it >= LowDiff }:
// turn on fan low speed
if (fanDimmer.currentSwitch == "off") { // if fan is OFF to make it easier on motor by
fanDimmer.setLevel(90) // starting fan in High speed temporarily then
fanDimmer.setLevel(30, [delay: 1000]) // change to Low speed after 1 second
log.debug "LO speed after HI 3secs(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, LowDiff=$LowDiff)"
} else {
fanDimmer.setLevel(30) //fan is already running, not necessary to protect motor
} //set Low speed immediately
log.debug "LO speed immediately(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, LowDiff=$LowDiff)"
break
default:
// check to see if fan should be turned off
if (desiredTemp - currentTemp >= 0 ) { //below or equal to setpoint, turn off fan, zero level
fanDimmer.off()
log.debug "below SP+Diff=fan OFF (CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, FD=$fanDimmer.currentSwitch,autoMode=$autoMode,)"
log.debug "autoMode YES-MANUAL? else OFF(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, FD=$fanDimmer.currentSwitch,autoMode=$autoMode,)"
private hasBeenRecentMotion()
def isActive = false
if (motionSensor && minutes) {
def deltaMinutes = minutes as Long
if (deltaMinutes) {
def motionEvents = motionSensor.eventsSince(new Date(now() - (60000 * deltaMinutes)))
log.trace "Found ${motionEvents?.size() ?: 0} events in the last $deltaMinutes minutes"
if (motionEvents.find { it.value == "active" }) {
isActive = true
else {
isActive = true
isActive
private def textHelp() {
def text =
"This smartapp provides automatic control of Low, Medium, High speeds of a"+
" ceiling fan using any temperature sensor based on its' temperature setpoint"+
" turning on each speed automatically in 1 degree differential increments."+
" For example, if the desired room temperature setpoint is 72, the low speed"+
" turns on first at 73, the medium speed turns on at 74, the high speed turns"+
" on at 75. And vice versa on decreasing temperature until at 72 the ceiling"+
" fan turns off. The differential is adjustable from 0.5 to 2.0 in half degree increments. \n\n" +
"A notable feature is when low speed is initially requested from"+
" the off condition, high speed is turned on briefly to overcome the startup load"+
" then low speed is engaged. This mimics the pull chain switches that most"+
" manufacturers use by always starting in high speed. \n\n"+
"A motion option turns off automatic mode when no motion is detected. A thermostat"+
" mode option will disable the smartapp and pass control to manual control.\n\n"+
"@ChadCK's 'Z-Wave Smart Fan Control Custom Device Handler' along with hardware"+
" designed specifically for motor control such as the GE 12730 Z-Wave Smart Fan Control or"+
" Leviton VRF01-1LX works well together with this smartapp."
