2.3.7.140 and unstable zigbee network
Even stranger:
I moved my hub to channel 18. My hub is "BE73".
However, in the latest channel scan, it shows that my neighbour moved to 18, and I stayed on 20.
Now, I'm really confused:
Channel scan has been seen to be somewhat confusing sometimes...for me generally pretty good at telling me where my hubs are, but you may want to wait a bit and scan again. If you see it showing changed on the Zigbee Details page then it is changed and the scan data is "old."
That looks like you are running an.old version.
Mine looks like this.
I think because he rolled back to 2.3.6.146 after he had problems on 2.3.7...
Shut down your hub, unplug the power cable for 15 mins, then plug in the power cable. the zigbee issue should clear.
Thanks for all of the help! It seems the problem was solved when I changed the Channel (I went from 20 to 15). Zigbee radio is working as expected. I need to re-pair devices to the hub but IM BACK BABY!!!
Here are some links that helped me get whole!
Link 1
Link 2
Thanks Again ALL!
