@bravenel @gopher.ny
My LeakSmart valve has been operating without problem for many months. Tonight, I installed the 2.3.5.152 release and my LeakSmart valve closed. When I try to open it, it closes immediately as if there were a leak. I checked all of my sensors, and there is no leak anywhere that would trigger it to close.
Excerpt from HSM log:
app:9402023-06-26 23:43:45.973warnAlert Water canceled
app:9402023-06-26 23:43:43.132infoAll Disarmed
app:9402023-06-26 23:43:29.033infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:43:28.979warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:26:58.233warnAlert Water canceled
app:9402023-06-26 23:26:30.158infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:26:30.134warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:22:59.366warnAlert Water canceled
app:9402023-06-26 23:22:43.303infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:22:43.270warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:16:33.581warnAlert Water canceled
app:9402023-06-26 23:16:19.560infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:16:19.525warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:16:02.022infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:16:01.987warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:15:37.405infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:15:37.376warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:12:22.378infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:12:22.327warnAlert Water LeakSmart Valve wet
app:9402023-06-26 23:01:09.234warnAlert Water canceled
app:9402023-06-26 23:00:58.237infoWater valve: [LeakSmart Valve] closed
app:9402023-06-26 23:00:58.205warnAlert Water LeakSmart Valve wet
Excerpt from LeakSmart valve log:
dev:9112023-06-26 23:47:09.924infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:47:07.088infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:47:06.726infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:47:04.373infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:47:01.604infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:47:01.590infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:47:01.543infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:46:55.038infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:45:20.420infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:45:17.752infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:45:17.741infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:45:17.700infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:45:17.627infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:45:10.953infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:43:29.512infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:43:29.014infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:43:28.470infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:43:27.533infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:26:54.396infoLeakSmart Valve : Battery Voltage 6.3v Calc 100%
dev:9112023-06-26 23:26:33.084infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:26:30.337infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:26:30.146infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:26:29.813infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:22:43.518infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:22:43.468infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:22:43.287infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:22:42.969infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:22:42.943infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:22:39.781infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:20:54.854infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:16:19.799infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:16:19.539infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:16:19.330infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:16:19.300infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:16:19.260infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:16:15.051infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:16:02.203infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:16:02.006infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:16:01.664infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:16:01.254infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:15:37.619infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:15:37.390infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:15:37.162infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:15:37.133infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:15:37.082infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:15:33.451infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:12:22.877infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:12:22.360infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:12:21.895infoLeakSmart Valve : Received Valve:open Our State:open
dev:9112023-06-26 23:12:21.879infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:12:19.671infoLeakSmart Valve : Opening the valve
dev:9112023-06-26 23:10:54.777infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:01:01.386infoLeakSmart Valve : Received Valve:closed Our State:closed
dev:9112023-06-26 23:00:58.475infoLeakSmart Valve : Event Valve: closed
dev:9112023-06-26 23:00:58.225infoLeakSmart Valve : Closing the valve
dev:9112023-06-26 23:00:57.899infoLeakSmart Valve : Event Valve: open
dev:9112023-06-26 23:00:54.964infoLeakSmart Valve : Event Valve: closed
I reverted to 2.3.5.146 and the LeakSmart valve is staying open and not triggering an alert. This is a big problem.
