I know there are some Z-Wave and Zigbee threads already, but I don't think I've seen this exact issue yet so I wanted to start my own.
So I am getting a weird issue with my C8 hub with the Z-Wave radio. It seems randomly at times maybe 1-2 times a day it will just drop all Z-Wave devices and they all stop working. Just like the radio was turned off. Zigbee (as well as everything else hub related) has been solid even when Z-Wave stops working.
The two methods of fix I have observed are Z-Wave repair or a power down. It seems the reboot doesn't help for some reason. I have also noticed when it fails the Z-wave topology map goes entirely red, and the repair shows tons of failed nodes during the repair process. It seems to begin working at some point after the repair is complete. When powered down and rebooted, it seems things begin working right away after boot.
I initially setup the hub on 3/3, using the most recent firmware at the time. Not sure which one it was exactly. It seemed the failures happened daily at least, and after a few days I finally got frustrated enough and plugged the C7 back in. Used the C7 just fine for about a week, and decided to play with the C8 again since I had some more time.
When I got thinks back up and running earlier today (around 1-2pm) this was my process:
C7 is on 2.3.5.113 as of a couple days ago
Cloud (migration) backup for the C7, I do not have hub protect
Powered down C7 & unplugged
Plugged C8 back in, and performed soft reset from the diagnostic tool
Updated C8 to the 2.3.5.113 firmware
Cloud backup from the C7 to the C8
It came back online and after a little while of it getting its footing it was pretty much fine. Z-Wave and Zigbee were both responsive from the dashboard and webpage. Then around 8-9pm I noticed things were no longer working and I was seeing issues in the Z-Wave details page like I described above. Ended up doing a Z-Wave repair, and it looks like the devices I tested were fine again.
Not really sure what's going on here, if it is software related or if the radio in my hub is messed up and randomly resetting for some reason. I saw mentions of a bad antenna, but I don't think that is the case because when it is working, it works really well.
