I have a RM rule that reboots the hub. It runs on the first of every month at 4:00 AM. When it ran last night, the Mode was Asleep. But after the hub rebooted, the Mode was changed to Away. I can recreate this by simply rebooting the hub via the Settings menu. This is a new problem. Reboots have not done this before. I'm not sure if it has something to do with 2.3.4.127, or something to do with the change in year. (Logs still say 2022.) Needless to say this is pretty annoying.
Also, the Hub Details page shows the date (year) and time correctly, and the pending jobs from the settings page indicate the correct year. However, the logging is showing 2022 instead of 2023 as shown in my above comment
Thanks. Clearly, a bug. It should have seen it as being in Home mode and not set it to Early Morning. I will reproduce your setup and find the problem.
I manually set it back to the correct mode. Went ahead and just rebooted to see if it did the same thing. It set it back to "Early Morning" again. If needed, I can send you my hub id if that helps troubleshoot.
In my case, this bug is pretty bad. Going to away mode upon hub reboot at 2:03 this morning also set my Ring Alarm to away mode, meaning if we get out of bed the motion in the house would trigger the alarm.
I had taken the puppy out to potty at 1:30 and was laying in bed awake when at 2:03 I heard the Ring alarm setting for away.... just a few mins ago I find the mode was still wrong
going to Evening mode at 9:18 last night was correct
Mode to away at 2:00 is the concerned mentioned here
What is Shadow mode at 7:00?
No log of mode going to away between 7:00am and 9:03am, which is when I found and set it back to home
Mode manager is setup to switch from sleep to home at 7:00am so it worked as designed
Not the platform developer. But, I believe that the shadow mode is a background mode of what Mode you would be in if you were not in away or another skipped mode so that it can return to the correct mode on a "return from away" action.
That is because it went to away at 2:03 AM on system startup and stayed there until you switched it to home at 9:03
