This just in...
I find this very odd.
It is interesting that there are rules that run without any issue every day.
Still, their scheduled job list appears blank as well.
You sure? I have a rule that runs daily at sunset (that is working fine), and it has no scheduled jobs. Trigger is simply "Time is sunset".
True. I do see it when looking at "Every day at 11:59 PM". OP was talking about a sunrise rule.
I notice your example was from Simple Automation rather than RM, although I wouldn't think that would matter.
from rule manager, I assume.
How do you set up the Simple Automation?
Just found it. Will try that to see if it makes a difference.
I use simple automation for a majority of my automations. For motion lighting rules I use the motion lighting app. Any oddballs that dont fit in those then I'll use RM4 or a custom app such as Auto Lock for the perimeter doors.
Just set up Simple Automation for turning lights off at sunrise.
Still, no Scheduled Jobs listed, or Events
Setting a specific time does setup a scheduled job so there's something different about the way it is handling sunset/sunrise vs a specific time.
And when I have the rule setup to use a specific time, I still do not see schedule
You're running the public build 2.2.4.139?
That is correct
Sunrise / Sunset don't use Scheduled Jobs. Instead, they subscribe to a System (Location) event called sunrise or sunset.
Thanks for that.
Any ideas on the issues I am having?
Could the number error, that was fixed in the latest HotFix, be the reason for my rule issues?
Just applied the Hotfix; will test Rules again
When you click on error what app does it take you to?
