Since applying the update last night, my rules to turn lights off at midnight and this morning at sunset failed to run.
Is there an update to the rule I need to do?
Anyone else having these issues?
Just a shot in the dark, but is your hub showing the right time and time zone?
Just checked, and yes.
I went in and updated each rule, and will see what happens.
When I run the actions for the rule, they do run.
Go to the rule and check the events. Scroll all the way to the bottom and see when the next scheduled event is.
Where would I find this?
Click the gear in the rule and then scroll to the bottom.
Can you post a screenshot of your rule?
Click done and then check the schedule again.
My fingers too fast for you!
Still blank.
All my rules have blank events.
Trying to see if I can replicate your problem. It'll take me a minute though.
Try a safe shutdown through settings and then pull the power for 1 minute. Plug it back in and see if the chron jobs start.
I will try. Thanks for the suggestion. Will let you know how it goes.
I have shutdown, waited, and rebooted.
What should I look for once it restarts?
Do you have an example?
I still do not see any events.
Would rebuilding the rule help, as a suggestion?
Can give it a shot.
