I'm using the internal HomeSeer 200+ dimmer driver and cannot control the status LEDs using the driver tile. This had been working using codahq's driver up until 2.2.4.141 and I can't say exactly when it stopped working.
Pls take a look.
When you look at the driver could you see if/why the dimmer indicator lights are enabled if the statues LED's are all OFF?
When the Preference "Enable Status LED's" is NOT Selected. White lights show the dim level.
When the Preference "Enable Status LED's" is selected. The above White lights show the dim level if all Status LED's are off. Then when at least one Status is set to ON, the above White lights extinguish.
Makes it difficult to meaningfully use the status lights.
This is what drove me to the codahq driver originally and even that there needed to be an additional preference added.
Pulled from github doesn't directly bother me, unless I find out there was a functional reason. Many drivers are put on github and unless there are immediate shortcomings are never updates. Likely many never need to be but if they do the author has already moved on to other projects.
I prefer to use the internal driver if possible. It is sure to survive updates and be maintained.
I have no idea what goes into the internal driver. Likely some of the community code if it follows the style of the Hubitat drivers but I could be a modified existing driver with some function enhancements.
@bcopeland FWIW when I was using the custom command setstatusLED the inputs were strings not numbers. At first I thought it was odd, however not so odd as to look to understand or change.
To add to your post, when I was running v2.2.3 and using the built-in driver, I could change the statusLED from either a Rule or Device page. Now running v.2.2.4, I get the errors in my log when attempting to change the statusLEDs from either the Device or Rule.
If this helps, I turned on the debug logging for the device control.
Here's the entry when I tried to set Lead #4 to blue... The values in the log entry are reversed (for led# and color).
Someone else mentioned that another app was controlling them correctly with the built in driver... So maybe it's just the UI for the device page that's got an error?
2020-11-22 02:50:28.010 am debugled:blue color:4 blink:on
@ArchStanton... great catch using debug. For me (as shown in my previous post), both of my errors came from the Device page and one of my Rules and both worked with v2.2.3. So based on that and you debug info, I suspect the issue is with the built-in driver but I'll defer to @bcopeland
@bcopeland... I just upgraded to v2.2.4.147 but am still getting a error (though it is different) while trying to set one of the statusLED via the Device page.
I just added more info to this post Homeseer HS-WD200+ Issues and have half my problem resolved. Going forward and to avoid confusion, I'm going to post future info on the other post.
