Running 1.1.3.116 and noticed that whenever my Nest Cameras are enabled, my hub comes to a crawl. The web interface is sluggish, RM actions are delayed, etc. Once the streaming/motion event stops all goes back to normal. I only care to use the Nest Integration to enable / disable my cameras but it appears to be pulling in snapshots on every motion event, which is overloading the hub.
Edit:
- I am a Network Engineer, bandwidth is not the issue
- Hubitat is on a fully separate network from my cameras
- No other devices in my house show the same symptoms
- This was not an issue on the 1.1.2 train of code, only started happening in 1.1.3
