rule is so slow, its so simple too
switch on, turn outlet on and the anti version of that
you can see in log, the physical switch off at 05:47:14.665
the rule runs and turned off the lamp at 05:47:31.041
thats a long time! sometimes its faster, but i need 1 second max to be acceptable
and even 1 second is too slow...
dev:402020-05-02 05:47:31.041 pm infoOffice Torchiere Lamp was turned off [digital]
dev:1632020-05-02 05:47:14.665 pm infoOffice Torchiere Lamp Switch is off [physical]
is just ZWAVE SLOW... i did a test, paused the rule...
added the node for the outlet into association group 2 of the switch...
there is still a good delay...(2 -3 seconds)
In any event, I'd recommend running a z-wave repair. By way of comparison, my z-wave network has about 60 nodes, of which 35 are powered (i.e. they can function as z-wave repeaters). On the average, it takes about 20 minutes to complete a z-wave repair. Also, the response time for my z-wave automations is about 150-300 ms.
that you for help... my zwave network is robust... i have plenty of devices spaced out
the hub is close too, and the switch and outlet are close too (15feet tops)
i did a z-wave repair and reboot of hub (going nuts)
i can live with 300ms
the switch is a brand new GE Embrighten(jasco) the outlet is a plug in type Leviton(DZPA1-15A)
i only got 15 nodes
look at this ugly time
the rule ran, but look how long from rule log to turned on
(and in the room it was dang long)
dev:402020-05-02 06:38:30.323 pm infoOffice Torchiere Lamp was turned on [digital]
app:1932020-05-02 06:38:12.343 pm infoTurn On Office Torchiere Lamp when Office Torchiere Lamp Switch turns on Turn On
dev:1632020-05-02 06:38:12.260 pm infoOffice Torchiere Lamp Switch is on
@JohnRob, Define "Light" cause this is a light connected to an outlet
you mean a bulb that is zwave... not got that...
i have another outlet, my outdoor flood... i can try that, thats a jasco zw+ outlet
lots... only 1 battery powered device (remote)
i got 2 offline devices can that hurt?
HE needs to add stinking online/offline in the zwave details page, ugh
Do you have any Z-Wave devices on your network that are capable of producing Power Monitoring data? These devices often flood a Z-Wave network with too much data slowing everything down to a crawl. As a test, I strongly recommend you DISABLE all power monitoring features of all devices that are capable of this feature, then be sure to click SAVE, and then CONFIGURE. Afterwards, let things settle down for a few minutes and then try your test again.
Also, depending on your device being used to trigger the other device, it may only report a change of state AFTER it completes ramping up to 'on', or ramping down to 'off'. If this is the case, then the issue may be alleviated by changing the ramp duration for that dimmable device to 0 seconds.
This may easily explain what you're seeing in the following logs your posted. We can see Button 7 was seen by Hubitat at 10:55:06.874. Hubitat then toggled the "Office Torchiere" state within 123ms. That's pretty fast. The "Office Torchiere" device then responded back that it had changed its state to OFF about 2 seconds later. If the "Office Torchiere" device is a dimmer, it may have taken 2 seconds to ramp down to "Off" before it reported the change to Hubitat.
dev:402020-05-02 10:55:29.123 pm infoOffice Torchiere Lamp was turned off [digital]
app:2272020-05-02 10:55:06.997 pm infoToggle Office Torchiere Lamp when Kitchen Lights button 7 pushed Toggle
dev:1292020-05-02 10:55:06.874 pm infoKitchen Lights: Button 7 was pushed
yes, the rule seemed to run fast... the lamp reported or was turned off 22 seconds later, its just a leviton zwave on/off module (plugs into outlet) no dimmer...
in the room, it did take forever...
Ooops! My bad... Not sure how I read that as only 2 seconds. Sorry about that.
22 seconds is forever. I would suspect some device is spamming your Z-Wave mesh.
Some of the older Leviton Switch/Dimmer devices require a firmware upgrade to behave properly with Hubitat. I wonder if your plug-in outlet is the same? Not sure if @bcopeland has helped users upgrade the firmware on any Leviton devices, yet...? He has a tool to perform Z-wave device firmware upgrades directly from the Hubitat hub.
I doubt the Leviton outlet the issue... also I think the fw update is for Leviton Decora dimmers
Many times I push the wall button and it is responsive within a second or so... but enough times itβs lagged... that we sec was one of the worst... I do feel itβs the hubitat
I had a 2gig gc2 doing this stuff before Hubitat and no issues
It was all responsive...
Calling it a night... more messing with it tomorrow
Thanks for your help
i feel at times the hubitat is busy dealing with say a refresh from themostat or something
and its too busy to send out the zwave command...
its random i feel, i did reboots and nothing changed....
i pulled the brand new GE Embrighten switch out... i was using it without load, and maybe it didnt like that... so waiting for innovelli to show up... but as i stated a made the little button on my existing innovelli switch do this light... and thats where the 1 time it took 22 seconds! (ouch)
i was getting frustrated, i needed to just walk away and take a day off...
im coming from a 2gig system run by alarm.com, and it was WAY faster
i had 345mhz sensor connected to a dumb switch in wall, it would trigger on/off and turn this lamp on, always within 1 second... and im guessing it was coming from cloud
