Peculiar behaviour after update to 2.4.3.149
zwave JS stack went through an update and was left with zwave enabled but offline.
Reboot fixed the issue but the region shows as US.
all devices are working and were in EU freq before so I wonder if its a GUI issue?
Shutdown and power off for 30 seconds has not resolved the Region not staying on EU. Changing to EU completes and then GUI shows US.
Is there a way to check what actual zwave frequencies are in use?
Is the region displayed simply wrong and a GUI bug?
Thanks, only item I can find is ""isRadioUpdateNeeded":false,"region":"US","nodes":[{"zwaveManufacturer"".
This is very peculiar as the C8pro has always been set to EU. IF I try to change the region it simply jumps back to US region and frequencies. I am bewildered as my devices are still attached and working (I would think some would not work on US freq and the change would have stopped them working for now)....
Any help on getting the radio back to EU without having to re add 50 or so devices would be good.
My guess is that somehow this (the display value) no longer being populated correctly so it is defaulting to the US. May also be a ZW-IP vs ZW-JS reporting problem. The good news is that if your devices are responding correctly the radio must be set correctly and the UI is just wrong.
