I have it set when everyone leaves the house. The switch is supposed to turn OFF. This is among many other devices that are set to turn OFF when everyone leaves.
I have noticed that this Water Feature switch doesnt Always turn OFF when everyone leaves. This happens sometimes. I have No Zwave Ghosts.
Do i need to do a device Refresh or Repair?
Its not critical but i would like to address it....on what i need to do to rectify it
Or is it something sometimes that not ALL zwave devices get the signal ?
When i go into my dashboard i can Turn Off and Turn On without any problems.
Its just the automation of turning OFF is the issue
It could be that you're turning off a lot of stuff at the same time. Sometimes, things get missed. There are ways around this, but someone more knowledgeable than I would have to tell you what they are.
I would add 1s delay for a separate off command for any problematic devices.
You can also a second round of off commands with a slightly longer delay if you want to be really sure they all turn off.
Also you can use the "command only devices that are on" function in RM to cut down on extra mesh traffic.
