Zwave Logs
Hubitat C-7 running 2.3.1.128. My Zwave network seems to be working fine, but I noticed a continuous string of Zwave log entries in Settings, System Settings, Zwave Details, and at the top "Zwave Logs". The only entries are from the two same devices, a pair of GE / Jasco ZW3103 (12781) Wireless Plugin Dimmer Modules and the log entries are continuous, one right after the other. I've cleared the log and they come right back on, again, one right after the other. Anyone have an idea on this?
Do they have power reporting ability? Might need to adjust some parameters so they are not reporting as frequently.
Thanks I will need to research that. I am not sure.
The ZW3103 is a pre-plus device.. Is this possibly polling you are seeing?
That could be but it just seems so excessive. Would seem to be a whole lot of system load but maybe not. I was just surprised to see so much. There is about a line/second. I've looked at the device settings and cannot see anything I can adjust or turn off. I also thought maybe I was using the wrong driver but I cannot find a likely candidate other than the generic driver I am using.
One of the main reasons I advocate replacing old non-plus devices.. They communicate faster and report automatically.
Great info. Thanks for your help!
