ZWave logs via remote access
I have remote access and can connect to my hub in a remote city. Everything is at it should be, almost. I was wanting to debug some of my ZWave issues remotely. I can't get the ZWave logs via remote access. I think I heard this had to be done on the LAN only and not remotely due to some sort of web limitation.
Is there a backdoor way to get these logs remotely? Can they be written to a file then downloaded?
Hmmm, I'll check.
Fixed!!!! Thank you.
broken again. I'm on 2.5.0.126 and now zwave logs aren't showing again via remote access. I thought this was fixed but seems broken again.
Hopefully an easy fix for @gopher.ny ...likely the flayrod got out of skew with the treddle. :smiley:
Confirmed, on it. Got to be a side effect of something.
It's fixed now, in the remote admin. No need to update hub firmware.
