Zwave lock driver will not update status
C8 Pro- version 2.5.0.123
I have a yale assure lock 2 touch using zwave driver. I noticed i was getting a lot of the same logs for unlock/lock status updates so I switched the driver to the alfred zwave lock driver. Still worked but logs would not show which codes were used. I switched back to the generic zwave lock driver, now I do not get a status change when the lock changes.
Lock can still be controlled via hubitat, I just have to hit refresh to show the new status change. hit configure once moving back to generic zwave driver. Also pulled batteries on the lock for 30 seconds, did not fix. Also did a soft reboot, still having the same issue.
any thoughts?
well now it at least changes status with a few second delay when controlled from the hub. manual change of the lock reports no change in status back to the hub
Is your hub using ZIP or ZWJS?
Using ZWJS
If you go to this endpoint:
/hub/zwave2/ccdebug/true
Then trigger your lock manually (without hitting refresh)..
And PM me your hub id, I can likely track this down quickly..
I just excluded and re-included the lock and it works perfect. Thanks
