ZWave Issue C7
One of my devices stopped responding a few days ago, a powered Fibaro Smart Implant. I ended up resetting the device and re-adding this. However I still haven’t been able to get the device working:
(1) I see a continuous stream of these messages in the log:
2021-08-02 10:58:20.226 pm Z-Wave Network responded with Busy message.
2021-08-02 10:58:17.232 pm Z-Wave Network responded with Busy message.
On the ZWave details page the device looks like this:
In the Zwave Logs I see the following:
I’ve tried excluding and re-adding the device several times. Resetting and adding the device. I tried a Zwave Repair and also used the ‘remove’ option in the z-wave details page and restarted the process. I’ve rebooted the hub and also shut down the hub - rinse and repeat for a few hours..
It looks like things are now in a bad state.
Any ideas as to where I go from here?
Thanks!
Power down and then pull the power from the wall, wait 30 seconds and reboot see if that helps.
After many lost hours - I bit the bullet and reset the zwave radio and re-paired. Thankfully most of my zwave devices are on my old hub so it didn’t take too long .. so far everything seems stable :crossed_fingers:
