Zwave hop limit
I was told that zwave has a hop limit of 4. But after moving my hub location, I found a route going 5 hops. The device can still be controlled, but attempts at repairing just says device unreachable. Power-cycling doesn't help. This is not the first time I saw something like this, but previous times the issue resolved itself after a while. Just wondering what's going on and how long I should wait for it to fix itself.
that's a 4 hop
The reality is.. ZWave is source routed.. meaning the Hub sends a packe with the hops predefined. There is a source nodeID, and a destination nodeID with 4 "slots" for hops.
So in your case... 1A, 67, 6E and 74 are the nodeIDs that fill up the 4 possible slots.
The route is still kind of weird though. There's a direct route from 01 - > 74. But this one bounced around before reaching 74.
I can't disagree. :smiley:
I can explain the hops thing :smiley:
maybe @bcopeland can explain that routing. I can't :smiley:
:man_shrugging: This all happens at the SDK layer.. All we do here is report what the SDK is telling us.
Hey, you guys are alliance members. Go the them the 7.xx routing is wack, and that they should fix it. :slight_smile:
Do I cross my fingers and wait for it to fix itself or is there a way to force a re-route?
If it’s z-wave plus it will eventually find another route.. But you can repair the node and it will most likely update
Since repair failed I guess I just have to wait?
Hey looks like it's fixing itself as I type. I guess the waiting period is about a day or so.
