This on C7. I have downloaded updated driver from Zooz gbi for this relay. I go to app Zwave firmware. I click Device Firmware Updater|Update Firmware, select the device, target shows current firmware, but when I Firmware File, nothing happens. I pick the GBL file and nothing changes.
Is the Z17 paired with S2 security or just "None" security?
Paired with none security as I recall
- deviceId: 40970
- deviceType: 28672
- firmwareVersion: 1.2
- hardwareVersion: 1
- inClusters: 0x5E,0x25,0x20,0x85,0x8E,0x59,0x55,0x86,0x72,0x5A,0x73,0x70,0x60,0x9F,0x6C,0x7A
- manufacturer: 634
- protocolVersion: 7.13
- serialNumber: B43A31FFFE4D5E02
- zwNodeInfo: D3 9C 00 04 10 00 5E 25 20 85 5C 8E 59 55 86 72 5A 73 70 60 9F 6C 7A 68 23
Huh, well, the built-in firmware updater should work then... But you can try these steps instead -- I wrote them to accomodate S2-paired devices (since the built-in updater cannot handle those), but these steps should work fine for non-S2 stuff too.
ETA -- backing up a bit first... Did you exactly follow all the steps as descibed here?
You are absolutely correct. I was not using those instructions. It is updating now. Thank you!
