Zwave device trouble
I have a C7 running 2.3.8.125. Starting this afternoon, a lot of Zwave devices are not responding. The ones that are responding are taking a long time to do so. I also noticed a message saying "Last cloud backup failed. Failed steps: Z-Wave."
I've tried rebooting the hub, and doing a Zwave repair. Neither have worked.
Anyone know what to do from here?
Shutdown the hub, remove power for about 30 seconds (this will empty the zwave radio cache and force a rebuild on power up), and then plug it back in. Once you’re back up try doing a cloud backup.
Thank you. I tried the shutdown/remove power. That didn't work either, but I found this article and followed the instructions and that resolved the issue:
Update. This problem reoccurred today, with all Zwave control lost and last cloud backups have failed citing "Zwave" as the cause.
Since running this procedure in the link below 9 days ago to fix the first occurrence, I've updated to 2.3.8.133 on my C7.
I tried shutting down the hub and removing power, this time it fixed the issue.
If there is anything I can do to further troubleshoot the root cause either now or if this happens again, please let me know.
This happened again. Does anyone know about the status of a fix for this?
